Attention: The Cisco Support Community site will be in read only mode on Dec14, 2017 from 12:01am PST to 11:30am for standard maintenance. Sorry for the inconvenience.
Problem with Extension Mobility and IPCC
I had running Extension Mobility in my CM 4.0 but after installing the IPCC 3.5, co-resident my Extension Mobility stops working. i know this a known issue but i can`t find the answer. Any idea? Thanks
Bronze
Re: Problem with Extension Mobility and IPCC
What is not working in EM after the install? I know about some tomcat issues with co resident ipcc, but the symptoms are different. Please describe the symptoms.
Regards, Avner.
Yes, the extension mobility is not working. I just press the button and nothing happens. any idea?
thanks for ur reply
Bronze
Try following this instructions, might be related:
http://www.ciscotaccc.com/kaidara-advisor/voice/showcase?case=K13407029
Let us know, Avner.
I already tried ur suggestion, but i can`t find the file SERVER.MCDVD.xml, i just found the file SERVER.XML and locate the port 8009 and changed for 8010, and restarted the server. but seems like i still having the same problem. even if i go to
http://x.x.x./manager/list
i can see the tomcat services up and running
Callmanager version 4.0.2a
Any suggestion??
125
