Problem with external na call- CISCO 2801 -pbx
hello ,
I have configure cisco 2801 for Voip service.The network has 10 phones 6921 and they all were register . The problem is this: I can call and foreign and local numbers but I can not accept call from an external number. Which commands show and debbug can find where is the problem?
2 ACCEPTED SOLUTIONS
Hall of Fame Super Gold
Re: Problem with external na call- CISCO 2801 -pbx
You can simply add your PSTN number, as it appears in "debug ccsip message" with "term mon", as a secondary number on the ephone-dn that you want to receive external calls
Other call handling choices would require different configuration.
Please remember that when you expose a problem in a technical forum, you need to mention all the relevant facts.
Not anybody can understand that saying "the invitation to accept" you mean SIP INVITE on a SIP trunk.
You created outgoing translation rule to replace the calling number from 20x to 38112719xxxx
Now, you create another translation rule for incoming calls which replace the called 38112719xxxx to 20x as below
voice translation-rule 2
rule 1 /38112719xxxx/ /201/
rule 2 /38112719xxxx/ /202/
voice translation-profile SIP-INCOMING
translate called 2
dial-peer voice xxx voip
translation-profile incoming SIP-INCOMING
Note: the secondary number is not needed here, the call will land to the respective inetrnal number.
Selvarathnam
but I can not accept the invitation to accept an external number.
In simple words, what that means?
sorry, my misteke. I meen :I can not accept call from an external number
You did not even said which type of phone lines you have.
It is SIP TRUNK.
this is my configuration :
voice service voip
ip address trusted list
  ipv4 10.0.0.18 255.255.255.255
gcid
callmonitor
no cti shutdown
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fall
h323
  call start slow
modem passthrough nse codec g711alaw
sip
  header-passing
  registrar server expires max 1200 min 60
  early-offer forced
  midcall-signaling passthru
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
voice translation-rule 1
rule 1 /201/ /38112719xxxx/
rule 2 /202/ /38112719xxxx/
rule 4 /204/ /38112719xxxx/
rule 5 /205/ /38112719xxxx/
rule 6 /206/ /38112719xxxx/
rule 7 /207/ /38112719xxxx/
rule 8 /208/ /38112719xxxx/
rule 9 /209/ /38112719xxxx/
rule 10 /210/ /38112719xxxx/
voice translation-profile SIP-OUTGOING
translate calling 1
class-map match-all L3-to-L2_VoIP-Cntrl
match ip dscp af31
class-map match-all L3-to-L2_VoIP-RTP
match ip dscp ef
class-map match-all SIP
match protocol sip
class-map match-all RTP
match protocol rtp
policy-map output-L3-to-L2
class L3-to-L2_VoIP-RTP
  set cos 5
class L3-to-L2_VoIP-Cntrl
  set cos 3
policy-map EthOut
class RTP
dial-peer cor list POZIV
member medjunarodni
sip-ua
credentials number 38112719xxxx username
38112719xxxx@ims.telek
ekomsrbija.com
registrar dns:ims.telekomsrbija.com expires 3600
sip-server ipv4:10.0.0.18:5060
host-registrar
refer-ood enable
handle-replaces
voice service voip
gcid
callmonitor
no cti shutdown
h323
  call start slow
sip
  header-passing
  early-offer forced
voice class codec 1
rule 1 /201/ /xxxxx/
rule 2 /202/ /xxxx/
rule 4 /204/ /xxxxxx/
rule 5 /205/ /xxxxxx/
rule 6 /206/ /xxxxxx/
translate calling 1
match ip dscp af31
match ip dscp ef
match protocol sip
match protocol rtp
  set cos 5
  set cos 3
policy-map EthOut
class RTP
sip-ua
credentials number xxxxxxxxxx username USERNAME  mmmmmm
registrar dns:ims.nnnnnnnnn.com expires 3600
host-registrar
refer-ood enable
handle-replaces
my service provider says that does not forward calls to me because I reject them, and returns a '487 request canced'
Take "debug ccsip message" with "term mon".
BTe, you have many commands that are not needed..
Also, you would do good in makeing your DID numberssame as PSTN numbers.
resault of ddebug ccsip message:
Aug 22 10:01:31.381: //3572/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 403 Forbidden
Via: SIP/2.0/UDP 10.x.x.110:5060;branch=z9hG4bKDD03C
To: <>204@ims.nnnnnnnnnn.com>;tag=1cba941c05e242a30adb173dca9e914
Call-ID: AC1D9F02-9B511E3-8006AECC-63706A48
Timestamp: 1377165691
CSeq: 312 REGISTER
Content-Length: 0
P-Charging-Vector: icid-value=1cba941c05e242a30adb173dca60b42
SIP/2.0 487 Request Cancelled
how to configure routet to accest call?
I think that is the problem ,router answer on incoming call with a request to call and that's why does not accept it.
You have posted only a fragment, not the complete trace as needed, and it is from a registation attempt, not a call.
It indicated that you negleted cto configure no-reg for the ephone-dn, so they try to register to ITSP unnecessarily.
As indicated abouve, you should configure your PSTN number a secondary to an ephone-dn, and register to ITSP.
Ruter#debug ccsip error
SIP Call error tracing is enabled
RuterPozarevac#
Aug 22 23:46:30.265: //-1/E70A39B082C5/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
MF: Not a Forked SIP leg..
SIP: (6762) Attribute mid, level 1 instance 1 not found.
Aug 22 23:46:30.265: //6762/E70A39B082C5/SIP/Error/sipSPI_ipip_update_codec_params_in_channelInfo:
failed to update call entry
Aug 22 23:46:30.265: //6762/E70A39B082C5/SIP/Error/sipSPI_ipip_update_call_entry:
Aug 22 23:46:30.265: //-1/xxxxxxxxxxxx/SIP/Error/sipSPI_ipip_set_channel_count:
Unable to set CHANNEL_COUNT for callid 6762
Aug 22 23:46:30.265: //6762/E70A39B082C5/SIP/Error/sip_iwf_sip_copy_sdp_to_channelInfo:
Channel count is not set at this point. Not SIP-SIP or SET_MODE is not done.
Aug 22 23:46:30.281: //6763/E70A39B082C5/SIP/Error/ccsip_ipip_media_forking_read_from_TDContainer:
MF: Unable to read data from TD Container..
Aug 22 23:46:30.281: //6763/E70A39B082C5/SIP/Error/ccsip_ipip_media_forking_forked_leg_config:
MF: TD container cannot be read/container is NULL. Setting of forked call leg failed..
Aug 22 23:46:30.285: //6763/E70A39B082C5/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Aug 22 23:46:30.285: //6763/E70A39B082C5/SIP/Error/sip_iwf_sip_copy_channelInfo_to_sdp:
We are either escalating, orno stream found for this m-line index:1
Aug 22 23:46:30.285: //6763/E70A39B082C5/SIP/Error/sipSPI_ipip_set_history_info_header:
ccb->src_addr_str is NULL
SIP: (6763) Group (a= group line) attribute, level 65535 instance 1 not found.
Aug 22 23:46:30.297: //-1/xxxxxxxxxxxx/SIP/Error/get_content_length:
Could not get Content-length
Aug 22 23:46:30.325: //6764/E70A39B082C5/SIP/Error/ccsip_ipip_media_forking_read_from_TDContainer:
Aug 22 23:46:30.325: //6764/E70A39B082C5/SIP/Error/ccsip_ipip_media_forking_forked_leg_config:
Aug 22 23:46:30.325: //6764/E70A39B082C5/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Aug 22 23:46:30.325: //6764/E70A39B082C5/SIP/Error/sip_iwf_sip_copy_channelInfo_to_sdp:
SIP: (6764) Group (a= group line) attribute, level 65535 instance 1 not found.
Aug 22 23:46:30.333: //-1/xxxxxxxxxxxx/SIP/Error/get_content_length:
Aug 22 23:46:40.185: //6765/000000000000/SIP/Error/ccsip_api_register_result_ind:
Message Code Class 4xx Method Code 100 received for REGISTER
Aug 22 23:46:40.185: //6765/000000000000/SIP/Error/sipSPIRegPthruProcessResponse:
Error NO RPCB
Aug 22 23:46:40.277: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_set_release_source_for_peer:
Failed AV set
Aug 22 23:46:41.013: //6766/000000000000/SIP/Error/ccsip_api_register_result_ind:
Aug 22 23:46:41.013: //6766/000000000000/SIP/Error/sipSPIRegPthruProcessResponse:
Error NO RPCB
My conf on router :
voice-card 0
voice service voip
gcid
callmonitor
no cti shutdown
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
  call start slow
sip
  header-passing
  early-offer forced
voice class codec 1
translate calling 1
application
service toroute flash0:toroute.tcl
dial-peer cor custom
name mobilni
name fiksni
dial-peer cor list POZIVmobilni
member mobilni
dial-peer cor list POZIVfiksni
member fiksni
dial-peer cor list Mobil
member mobilni
member fiksni
dial-peer voice 1000 voip
corlist incoming Mobil
service toroute
destination-pattern [0-9]T
session protocol sipv2
session target sip-server
incoming called-number 38112719xxxx
voice-class codec 1
voice-class sip dtmf-relay force rtp-nte
dtmf-relay rtp-nte
no vad
sip-ua
credentials number 38112719xxxx username 38112719xxxx@ims.nnnnnnn.com password 7 010107520F53515E75 realm ims.nnnnnnnn.com
registrar dns:ims.nnnnn.com expires 3600
host-registrar
refer-ood enable
handle-replaces
ephone-dn  1  dual-line
number 201
label 201
name office
ephone  1
device-security-mode none
video
mac-address B4E9.B001.xxx
max-calls-per-button 2
username "user1" password 201
type 6921
button  1:1
Please post only the debug requested above, and nothing else.
Ruter#debug ccsip mess
SIP Call messages tracing is enabled
RuterPozarevac#
Aug 23 10:57:41.482: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:38112719xxxx@10.1.7.110:5060 SIP/2.0
Via: SIP/2.0/UDP 10.0.0.18:5060;branch=z9hG4bKk3p5jk100051nnc7g4o1.1
To: "firma"<>;cscf
From: <>0642947904@tssbg01.telekomsrbija.com;user=phone>;tag=279605674-1377248266952-
Call-ID: BW105746951230813315702207@10.10.1.143
CSeq: 355624293 INVITE
Max-Forwards: 8
Content-Length: 238
Contact: <064294XXXX>
Content-Type: application/sdp
Allow: ACK, BYE, CANCEL, INFO, INVITE, OPTIONS, PRACK, REFER, NOTIFY
Accept: multipart/mixed
Accept: application/media_control+xml
Accept: application/sdp
Accept: application/x-hotsip-FileTransfer+xml
Supported: timer
P-Asserted-Identity: <64294XXXX>phone-context=+381@tssbg01.telekomsrbija.com;user=phone>
Privacy: none
P-Charging-Vector: icid-value=65685546060b32380adb6cda6173155
Min-SE: 180
Session-Expires: 1800
P-Called-Party-ID: <>
v=0
o=BroadWorks 80540950 1 IN IP4 10.0.0.18
s=-
c=IN IP4 10.0.0.18
t=0 0
a=sendrecv
m=audio 30964 RTP/AVP 8 18 98
a=rtpmap:8 PCMA/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:98 telephone-event/8000
a=fmtp:98 0-15
Aug 23 10:57:41.494: //9292/AA8F88F98342/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
From: <>064294xxxx@tssbg01.telekomsrbija.com;user=phone>;tag=279605674-1377248266952-
To: "firma"<>;cscf
Date: Fri, 23 Aug 2013 10:57:41 GMT
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-15.2.4.M3
Content-Length: 0
Aug 23 10:57:41.506: //9293/AA8F88F98342/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:100@10.0.0.18:5060 SIP/2.0
Via: SIP/2.0/UDP 10.1.7.110:5060;branch=z9hG4bK23FB1668
Remote-Party-ID: <064294XXXX>;party=calling;screen=no;privacy=off
From: sip:064294xxxx@tssbg01.telekomsrbija.com;tag=8AE2F98-146A
To: <100>
Call-ID: AA91F999-B1911E3-8348AECC-63706A48@10.1.7.110
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 2861533433-0186192355-2202185420-1668311624
User-Agent: Cisco-SIPGateway/IOS-15.2.4.M3
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1377255461
Expires: 180
Max-Forwards: 7
Cisco-Gcid: AA8F88F9-0B19-11E3-8345-AECC63706A48
Content-Disposition: session;handling=required
Content-Length: 290
v=0
o=CiscoSystemsSIP-GW-UserAgent 6890 5773 IN IP4 10.1.7.110
s=SIP Call
c=IN IP4 10.1.7.110
t=0 0
m=audio 16644 RTP/AVP 8 100 101
c=IN IP4 10.1.7.110
a=rtpmap:100 X-NSE/8000
a=fmtp:100 192-194
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=ptime:20
Aug 23 10:57:41.510: //9293/AA8F88F98342/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <100>
CSeq: 101 INVITE
Aug 23 10:57:41.538: //9293/AA8F88F98342/SIP/Msg/ccsipDisplayMsg:
Received:
To: <100>;tag=832601292-1377248267013
CSeq: 101 INVITE
Content-Length: 0
P-Charging-Vector: icid-value=f13ab6fa060987e10adb6cda65459f2
Aug 23 10:57:41.546: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:100@10.0.0.18:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Aug 23 10:57:41.550: //9294/AA8F88F98342/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:100@ims.telekomsrbija.com:5060 SIP/2.0
Via: SIP/2.0/UDP 10.1.7.110:5060;branch=z9hG4bK23FC9C1
Remote-Party-ID: <0642947904>;party=calling;screen=no;privacy=off
From: sip:064294xxxx@tssbg01.telekomsrbija.com;tag=8AE2FC4-A3C
To: <>100@ims.telekomsrbija.com>
Call-ID: AA98145A-B1911E3-834AAECC-63706A48@79.101.99.70
Min-SE:  1800
CSeq: 101 INVITE
Call-Info: <10.1.7.110:5060>;method="NOTIFY;Event=telephone-event;Duration=2000"
Expires: 180
Max-Forwards: 7
Content-Length: 314
v=0
o=CiscoSystemsSIP-GW-UserAgent 6362 7239 IN IP4 10.1.7.110
s=SIP Call
c=IN IP4 10.1.7.110
t=0 0
m=audio 16646 RTP/AVP 8 100 101 19
c=IN IP4 10.1.7.110
a=fmtp:100 192-194
a=fmtp:101 0-15
a=rtpmap:19 CN/8000
a=ptime:20
Aug 23 10:57:41.554: //9294/AA8F88F98342/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Aug 23 10:57:41.582: //9294/AA8F88F98342/SIP/Msg/ccsipDisplayMsg:
Received:
To: <>100@ims.telekomsrbija.com>;tag=1297836501-1377248267055
CSeq: 101 INVITE
Content-Length: 0
P-Charging-Vector: icid-value=f8615e8b05ee31d10adb6cda67a645b
Aug 23 10:57:41.586: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:100@ims.telekomsrbija.com:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Aug 23 10:57:51.502: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CANCEL sip:38112719xxxx@10.1.7.110:5060 SIP/2.0
CSeq: 355624293 CANCEL
To: "firma"<>;cscf
Max-Forwards: 8
Content-Length: 0
Aug 23 10:57:51.502: //9292/AA8F88F98342/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: "firma"<>;cscf
Date: Fri, 23 Aug 2013 10:57:51 GMT
Content-Length: 0
Aug 23 10:57:51.506: //9292/AA8F88F98342/SIP/Msg/ccsipDisplayMsg:
Sent:
To: "firma"<>;cscf;tag=8AE56A8-2407
Reason: Q.850;cause=16
Content-Length: 0
Aug 23 10:57:51.510: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:381127195224@10.1.7.110:5060 SIP/2.0
CSeq: 355624293 ACK
Max-Forwards: 8
Content-Length: 0
Ruter#debug ccsip call
Aug 23 11:37:48.010: //9457/44ED61D0835E/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x0x23809A88
State of The Call        : STATE_DEAD
TCP Sockets Used         : NO
Calling Number           : 064294xxxx
Called Number            : 100
Source IP Address (Sig  ): 10.1.7.110
Destn SIP Req Addr:Port  : 10.0.0.18:5060
Destn SIP Resp Addr:Port : 10.0.0.18:5060
Destination Name         : ims.telekomsrbija.com
Aug 23 11:37:48.010: //9457/44ED61D0835E/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream             : 1
Negotiated Codec         : No Codec
Negotiated Codec Bytes   : 0
Nego. Codec payload      : 255 (tx), 255 (rx)
Negotiated Dtmf-relay    : 0
Dtmf-relay Payload       : 0 (tx), 0 (rx)
Source IP Address (Media): 10.1.7.110
Source IP Port    (Media): 16656
Destn  IP Address (Media):  -
Destn  IP Port    (Media): 0
Orig Destn IP Address:Port (Media): [ - ]:0
Disconnect Cause (CC)    : 57
Disconnect Cause (SIP)   : 403
Aug 23 11:37:48.054: //9458/44ED61D0835E/SIP/Call/sipSPICallInfo:
Call Control Block (CCB) : 0x0x238218E8
Called Number            : 100
Destination Name         : 10.0.0.18
Aug 23 11:37:48.054: //9458/44ED61D0835E/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 1
Source IP Port    (Media): 16658
Aug 23 11:37:57.990: //9456/44ED61D0835E/SIP/Call/sipSPICallInfo:
Call Control Block (CCB) : 0x0x2380FA20
Called Number            : 38112719xxxx
Aug 23 11:37:57.990: //9456/44ED61D0835E/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 1
Negotiated Codec         : g711alaw
Negotiated Codec Bytes   : 160
Nego. Codec payload      : 8 (tx), 8 (rx)
Negotiated Dtmf-relay    : 6
Dtmf-relay Payload       : 98 (tx), 98 (rx)
Source IP Port    (Media): 16654
Destn  IP Address (Media): 10.0.0.18
Destn  IP Port    (Media): 34918
Disconnect Cause (CC)    : 16
Disconnect Cause (SIP)   : 487
As indicated above already, you need to configure 38112719xxxx as secondary number to the phone where you want the call to ring.
ok, can you help me with that?
Just do what is indicated above.
how to configure secondary number to the phone?
Using 'secondary' in 'number' command.
You can reference the mnual for more information.
translate called 2
Selvarathnam
The point is: secondary number configuration allow to avoid all translations with a single, simple command.
Normally, translation is used when there is a range of DID, but often SIP trunk subscribers only have few discontinuous numbers, so the secondary approach if preferable.
Then each one can choose what he wants.
I remove my old dial-peer voice 5000 voip an add:
translate called 2
dial-peer voice 999 voip
I still have a problem:
Ruter#
Aug 23 19:07:14.288: //-1/0E1D6E6283AC/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
SIP: (11163) Attribute mid, level 1 instance 1 not found.
Aug 23 19:07:14.288: //11163/0E1D6E6283AC/SIP/Error/sipSPI_ipip_update_codec_params_in_channelInfo:
Aug 23 19:07:14.288: //11163/0E1D6E6283AC/SIP/Error/sipSPI_ipip_update_call_entry:
Aug 23 19:07:14.288: //-1/xxxxxxxxxxxx/SIP/Error/sipSPI_ipip_set_channel_count:
Unable to set CHANNEL_COUNT for callid 11163
Aug 23 19:07:14.288: //11163/0E1D6E6283AC/SIP/Error/sip_iwf_sip_copy_sdp_to_channelInfo:
Aug 23 19:07:14.300: //11163/0E1D6E6283AC/SIP/Error/sipSPI_ipip_set_history_info_header:
Not SIP2SIP mode
Aug 23 19:07:29.304: //11163/0E1D6E6283AC/SIP/Error/sipSPI_ipip_set_history_info_header:
Not SIP2SIP mode
Aug 23 19:07:29.308: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_set_release_source_for_peer:
Failed AV set
Aug 23 19:07:29.308: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIGetContentQSIG:
No Inbound Container Created !!!
Aug 23 19:07:29.308: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIGetContentQ931:
Aug 23 19:07:52.532: //11165/000000000000/SIP/Error/ccsip_api_register_result_ind:
Aug 23 19:07:52.532: //11165/000000000000/SIP/Error/sipSPIRegPthruProcessResponse:
Error NO RPCB
Aug 23 19:07:52.532: //11166/000000000000/SIP/Error/ccsip_api_register_result_ind:
Aug 23 19:07:52.532: //11166/000000000000/SIP/Error/sipSPIRegPthruProcessResponse:
Error NO RPCB
Aug 23 19:07:52.536: //11167/000000000000/SIP/Error/ccsip_api_register_result_ind:
Aug 23 19:07:52.536: //11167/000000000000/SIP/Error/sipSPIRegPthruProcessResponse:
Error NO RPCB
Aug 23 19:07:52.568: //11168/000000000000/SIP/Error/ccsip_api_register_result_ind:
Aug 23 19:07:52.568: //11168/000000000000/SIP/Error/sipSPIRegPthruProcessResponse:
Error NO RPCB
Aug 23 19:07:52.624: //11169/000000000000/SIP/Error/ccsip_api_register_result_ind:
Aug 23 19:07:52.624: //11169/000000000000/SIP/Error/sipSPIRegPthruProcessResponse:
Error NO RPCB
Aug 23 19:07:52.804: //11170/000000000000/SIP/Error/ccsip_api_register_result_ind:
Aug 23 19:07:52.804: //11170/000000000000/SIP/Error/sipSPIRegPthruProcessResponse:
Error NO RPCB
Ruter#DEBUG CCSIP CALL
SIP Call statistics tracing is enabled
Ruter#
Aug 23 19:26:13.128: //11244/ABF6220D83B3/SIP/Call/sipSPICallInfo:
Aug 23 19:26:13.128: //11244/ABF6220D83B3/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 1
Negotiated Codec         : g729r8
Negotiated Codec Bytes   : 20
Nego. Codec payload      : 18 (tx), 18 (rx)
Source IP Port    (Media): 16686
Destn  IP Port    (Media): 32562
Disconnect Cause (SIP)   : 302
and I added a command
  voice service voip
   no supplementary-service sip moved-temporarily
and finally I established a connection.
I am so happy
Now I have another problem. When I call number 38112719xxxb it rings on both phones 38112719xxxa (201) and  38112719xxxb (202)
rule 1 /38112719xxxa/ /201/
rule 2 /38112719xxxb/ /202/
translate called 2
name mobilni
member mobilni
incoming called-number 381127195xxxa
dial-peer voice 991 voip
incoming called-number 38112719xxxb
number 201
label 201
description  201
name Info 201
ephone-dn  2  dual-line
number 202
label 202
description  202
name Office 202
ephone  1
video
mac-address B4E9.B001.cccc
type 6921
button  1:1
ephone  2
video
mac-address B4E9.B001.yyyy
username "user2" password 202
type 6921
button  1:2
Why you required two dial-peer 999 and 991
no need of incoming called-number command or change it to incoming called-number 38112719....
see how many dial-peer it is created:
#show telephony-service dial-peer
I remove dial-peer 991 and change incoming number to 38112719....
but still the same problem
Rute#sh telephony-service dial-peer
dial-peer voice 20001 pots
destination-pattern 201$
huntstop
progress_ind setup enable 3
port 50/0/1
dial-peer voice 20002 pots
destination-pattern 202$
huntstop
port 50/0/2
Please, provide us with the full running-configuration of the router.
ip dhcp pool VOICE
network 10.10.108.0 255.255.255.0
default-router 10.10.108.1
option 150 ip 10.10.108.1
ip domain name ims.nnnnnnnnn.com
ip host ims.nnnnnnnn.com 10.0.0.18
no ipv6 cef
voice-card 0
voice service voip
gcid
callmonitor
no cti shutdown
h323
  call start slow
sip
  header-passing
  early-offer forced
voice class codec 1
rule 2 /202/ /38112719xxx1/
rule 3 /203/ /38112719xxx2/
rule 4 /204/ /38112719xxx3/
rule 5 /205/ /38112719xxx4/
rule 6 /206/ /38112719xxx5/
rule 7 /207/ /38112719xxx6/
rule 8 /208/ /38112719xxx7/
rule 9 /209/ /38112719xxx8/
rule 10 /210/ /38112719xxx9/
rule 11 /211/ /38112719xx10/
rule 2 /38112719xxx1/ /202/
rule 3 /38112719xxx2/ /201/
rule 4 /38112719xxx3/ /204/
rule 5 /38112719xxx4/ /205/
rule 6 /38112719xxx5/ /206/
rule 7 /38112719xxx6/ /207/
rule 8 /38112719xxx7/ /208/
rule 9 /38112719xxx8/ /209/
rule 10 /38112719xxx9/ /210/
rule 11 /38112719xx10/ /211/
translate called 2
translate calling 1
match ip dscp af31
match ip dscp ef
match protocol sip
match protocol rtp
  set cos 5
  set cos 3
policy-map EthOut
class RTP
name medjunarodni
name mobilni
name fiksni
name lokalni
name besplatni
name igrenasrecu
name sanaplatom
name hitnesluzbe
name servisnesluzbe
dial-peer cor list POZIVmedjunarodni
member medjunarodni
member mobilni
member fiksni
dial-peer cor list POZIVlokalni
member lokalni
dial-peer cor list POZIVbesplatni
member besplatni
dial-peer cor list POZIVsanaplatom
member sanaplatom
dial-peer cor list POZIVigrenasrecu
member igrenasrecu
dial-peer cor list POZIVhitnesluzbe
member hitnesluzbe
dial-peer cor list POZIVservisnesluzbe
member servisnesluzbe
dial-peer cor list SviPozivi
member medjunarodni
member mobilni
member fiksni
member lokalni
member besplatni
member igrenasrecu
member sanaplatom
member hitnesluzbe
member mobilni
member fiksni
member lokalni
member besplatni
member hitnesluzbe
dial-peer cor list Fiksni
member fiksni
member lokalni
member besplatni
member hitnesluzbe
dial-peer voice 1001 voip
corlist outgoing POZIVmedjunarodni
destination-pattern 00T
session target dns:ims.nnnnnnn.com
dtmf-relay sip-notify rtp-nte
codec g711alaw
dial-peer voice 1002 voip
corlist outgoing POZIVfiksni
translation-profile outgoing SIP-OUTGOING
destination-pattern 0[1-3]T
codec g711alaw
fax rate disable
no vad
dial-peer voice 1003 voip
corlist outgoing POZIVigrenasrecu
destination-pattern 0[4-5]T
session target dns:ims.nnnnn.com
codec g711alaw
dial-peer voice 1004 voip
corlist outgoing POZIVmobilni
destination-pattern 06T
session target dns:imsn.nnnnnn.com
codec g711alaw
dial-peer voice 1005 voip
corlist outgoing POZIVsanaplatom
destination-pattern 0[79]T
session target dns:ims.nnnnnnnnn.com
codec g711alaw
dial-peer voice 1006 voip
corlist outgoing POZIVbesplatni
destination-pattern 0[8]T
session target dns:ims.nnnnnnnn.com
codec g711alaw
dial-peer voice 1007 voip
corlist outgoing POZIVlokalni
destination-pattern [1-8]T
session target dns:ims.tnnnnnnn.com
codec g711alaw
dial-peer voice 1008 voip
corlist outgoing POZIVhitnesluzbe
destination-pattern 9[2-4]T
codec g711alaw
dial-peer voice 1009 voip
corlist outgoing POZIVservisnesluzbe
destination-pattern 9[5-8]T
session target dns:ims.nnnnnn.com
codec g711alaw
sip-ua
credentials number 38112719xxxx username 38112719xxxx@ims.tnnnnnnnnn.com password 7 010107520F53515E75 realm ims.nnnnnnn.com
host-registrar
refer-ood enable
handle-replaces
gatekeeper
no shutdown
telephony-service
no auto-reg-ephone
pin 11319 override
max-ephones 24
max-dn 72
ip source-address 10.10.108.1 port 2000
calling-number initiator
service phone videoCapability 1
timeouts interdigit 5
system message MESSAGE
cnf-file location flash:
time-zone 28
time-format 24
date-format dd-mm-yy
max-conferences 8 gain -6
call-forward pattern .T
moh "music-on-hold.au"
dn-webedit
time-webedit
transfer-system full-consult dss
create cnf-files version-stamp 7960 Aug 21 2013 22:05:22
number 201
label 201
description  201
name 201
number 202
label 202
description OFFICE 202
name Office 202
ephone-dn  3  dual-line
number 203
label 203
ephone-dn  4  dual-line
number 204
label 204
ephone-dn  5  dual-line
number 205
label 205
description  205
name 205
ephone-dn  6  dual-line
number 206
label 206
description 206
ephone-dn  7  dual-line
number 207
label 207
name 207
ephone-dn  8  dual-line
number 208
label 208
description 208
name 208
ephone-dn  9  dual-line
number 209
label 209
description 209
name 209
ephone-dn  10  dual-line
number 210
label 210
description 210
name 210
ephone-dn  11  dual-line
number 211
label 211
description 211
name 211
ephone  1
video
mac-address B4E9.B001.xxxx
type 6921
button  1:1
ephone  2
video
mac-address B4E9.B001.vvvv
type 6921
button  1:2
ephone  3
video
username "user3" password 203
ephone  4
video
mac-address B4E9.B001.gggg
username "user4" password 204
type 6921
button  1:4
ephone  5
video
mac-address B4E9.B001.hhhh
username "user5" password 205
type 6921
button  1:5
ephone  7
video
mac-address B4E9.B001.jjjjj
username "user7" password 207
type 6921
button  1:7
ephone  8
video
username "user8" password 208
type 6921
button  1:8
ephone  9
video
mac-address B4E9.B001.jiii
username "user9" password 209
type 6921
button  1:9
ephone  10
video
mac-address B4E9.B001.rrrr
username "user10" password 210
type 6921
button  1:10
ephone  11
video
username "user11" password 211
type 6921
line con 0
login local
line aux 0
line 2
--More--
1274
