Problem with external na call- CISCO 2801 -pbx
acazarkov
hello ,
I have configure cisco 2801 for Voip service.The network has 10 phones 6921 and they all were register . The problem is this: I can call and foreign and local numbers but I can not accept call from an external number. Which commands show and debbug can find where is the problem?
31 Replies 31
As indicated above already, you need to configure 38112719xxxx as secondary number to the phone where you want the call to ring.
ok, can you help me with that?
Just do what is indicated above.
how to configure secondary number to the phone?
Using 'secondary' in 'number' command.
You can reference the mnual for more information.
You created outgoing translation rule to replace the calling number from 20x to 38112719xxxx
Now, you create another translation rule for incoming calls which replace the called 38112719xxxx to 20x as below
voice translation-rule 2
rule 1 /38112719xxxx/ /201/
rule 2 /38112719xxxx/ /202/
voice translation-profile SIP-INCOMING
translate called 2
dial-peer voice xxx voip
translation-profile incoming SIP-INCOMING
Note: the secondary number is not needed here, the call will land to the respective inetrnal number.
Selvarathnam
The point is: secondary number configuration allow to avoid all translations with a single, simple command.
Normally, translation is used when there is a range of DID, but often SIP trunk subscribers only have few discontinuous numbers, so the secondary approach if preferable.
Then each one can choose what he wants.
I remove my old dial-peer voice 5000 voip an add:
translate called 2
dial-peer voice 999 voip
corlist incoming Mobil
session protocol sipv2
session target sip-server
incoming called-number 38112719xxxx
I still have a problem:
Ruter#debug ccsip error
SIP Call error tracing is enabled
Ruter#
Aug 23 19:07:14.288: //-1/0E1D6E6283AC/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
MF: Not a Forked SIP leg..
SIP: (11163) Attribute mid, level 1 instance 1 not found.
Aug 23 19:07:14.288: //11163/0E1D6E6283AC/SIP/Error/sipSPI_ipip_update_codec_params_in_channelInfo:
failed to update call entry
Aug 23 19:07:14.288: //11163/0E1D6E6283AC/SIP/Error/sipSPI_ipip_update_call_entry:
Aug 23 19:07:14.288: //-1/xxxxxxxxxxxx/SIP/Error/sipSPI_ipip_set_channel_count:
Unable to set CHANNEL_COUNT for callid 11163
Aug 23 19:07:14.288: //11163/0E1D6E6283AC/SIP/Error/sip_iwf_sip_copy_sdp_to_channelInfo:
Channel count is not set at this point. Not SIP-SIP or SET_MODE is not done.
Aug 23 19:07:14.300: //11163/0E1D6E6283AC/SIP/Error/sipSPI_ipip_set_history_info_header:
Not SIP2SIP mode
Aug 23 19:07:29.304: //11163/0E1D6E6283AC/SIP/Error/sipSPI_ipip_set_history_info_header:
Not SIP2SIP mode
Aug 23 19:07:29.308: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_set_release_source_for_peer:
Failed AV set
Aug 23 19:07:29.308: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIGetContentQSIG:
No Inbound Container Created !!!
Aug 23 19:07:29.308: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIGetContentQ931:
Aug 23 19:07:52.532: //11165/000000000000/SIP/Error/ccsip_api_register_result_ind:
Message Code Class 4xx Method Code 100 received for REGISTER
Aug 23 19:07:52.532: //11165/000000000000/SIP/Error/sipSPIRegPthruProcessResponse:
Error NO RPCB
Aug 23 19:07:52.532: //11166/000000000000/SIP/Error/ccsip_api_register_result_ind:
Aug 23 19:07:52.532: //11166/000000000000/SIP/Error/sipSPIRegPthruProcessResponse:
Error NO RPCB
Aug 23 19:07:52.536: //11167/000000000000/SIP/Error/ccsip_api_register_result_ind:
Aug 23 19:07:52.536: //11167/000000000000/SIP/Error/sipSPIRegPthruProcessResponse:
Error NO RPCB
Aug 23 19:07:52.568: //11168/000000000000/SIP/Error/ccsip_api_register_result_ind:
Aug 23 19:07:52.568: //11168/000000000000/SIP/Error/sipSPIRegPthruProcessResponse:
Error NO RPCB
Aug 23 19:07:52.624: //11169/000000000000/SIP/Error/ccsip_api_register_result_ind:
Aug 23 19:07:52.624: //11169/000000000000/SIP/Error/sipSPIRegPthruProcessResponse:
Error NO RPCB
Aug 23 19:07:52.804: //11170/000000000000/SIP/Error/ccsip_api_register_result_ind:
Aug 23 19:07:52.804: //11170/000000000000/SIP/Error/sipSPIRegPthruProcessResponse:
Error NO RPCB
Ruter#DEBUG CCSIP CALL
SIP Call statistics tracing is enabled
Ruter#
Aug 23 19:26:13.128: //11244/ABF6220D83B3/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x0x23809A88
State of The Call        : STATE_DEAD
TCP Sockets Used         : NO
Calling Number           : 064294xxxx
Called Number            : 38112719xxxx
Source IP Address (Sig  ): 10.1.7.110
Destn SIP Req Addr:Port  : 10.0.0.18:5060
Destn SIP Resp Addr:Port : 10.0.0.18:5060
Destination Name         : 10.0.0.18
Aug 23 19:26:13.128: //11244/ABF6220D83B3/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream             : 1
Negotiated Codec         : g729r8
Negotiated Codec Bytes   : 20
Nego. Codec payload      : 18 (tx), 18 (rx)
Negotiated Dtmf-relay    : 0
Dtmf-relay Payload       : 0 (tx), 0 (rx)
Source IP Address (Media): 10.1.7.110
Source IP Port    (Media): 16686
Destn  IP Address (Media): 10.0.0.18
Destn  IP Port    (Media): 32562
Orig Destn IP Address:Port (Media): [ - ]:0
Disconnect Cause (CC)    : 16
Disconnect Cause (SIP)   : 302
and I added a command
  voice service voip
   no supplementary-service sip moved-temporarily
and finally I established a connection.
I am so happy
Now I have another problem. When I call number 38112719xxxb it rings on both phones 38112719xxxa (201) and  38112719xxxb (202)
rule 1 /38112719xxxa/ /201/
rule 2 /38112719xxxb/ /202/
translate called 2
dial-peer cor custom
name mobilni
dial-peer cor list Mobil
member mobilni
incoming called-number 381127195xxxa
dial-peer voice 991 voip
incoming called-number 38112719xxxb
ephone-dn  1  dual-line
number 201
label 201
description  201
name Info 201
ephone-dn  2  dual-line
number 202
label 202
description  202
name Office 202
ephone  1
device-security-mode none
video
mac-address B4E9.B001.cccc
max-calls-per-button 2
username "user1" password 201
type 6921
button  1:1
ephone  2
video
mac-address B4E9.B001.yyyy
username "user2" password 202
type 6921
button  1:2
Why you required two dial-peer 999 and 991
no need of incoming called-number command or change it to incoming called-number 38112719....
see how many dial-peer it is created:
#show telephony-service dial-peer
I remove dial-peer 991 and change incoming number to 38112719....
but still the same problem
Rute#sh telephony-service dial-peer
dial-peer voice 20001 pots
destination-pattern 201$
huntstop
progress_ind setup enable 3
port 50/0/1
dial-peer voice 20002 pots
destination-pattern 202$
huntstop
port 50/0/2
Please, provide us with the full running-configuration of the router.
ip dhcp pool VOICE
network 10.10.108.0 255.255.255.0
default-router 10.10.108.1
option 150 ip 10.10.108.1
ip domain name ims.nnnnnnnnn.com
ip host ims.nnnnnnnn.com 10.0.0.18
no ipv6 cef
voice-card 0
voice service voip
ip address trusted list
  ipv4 10.0.0.18 255.255.255.255
gcid
callmonitor
no cti shutdown
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
  call start slow
modem passthrough nse codec g711alaw
sip
  header-passing
  registrar server expires max 1200 min 60
  early-offer forced
  midcall-signaling passthru
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
voice translation-rule 1
rule 1 /201/ /38112719xxxx/
rule 2 /202/ /38112719xxx1/
rule 3 /203/ /38112719xxx2/
rule 4 /204/ /38112719xxx3/
rule 5 /205/ /38112719xxx4/
rule 6 /206/ /38112719xxx5/
rule 7 /207/ /38112719xxx6/
rule 8 /208/ /38112719xxx7/
rule 9 /209/ /38112719xxx8/
rule 10 /210/ /38112719xxx9/
rule 11 /211/ /38112719xx10/
rule 2 /38112719xxx1/ /202/
rule 3 /38112719xxx2/ /201/
rule 4 /38112719xxx3/ /204/
rule 5 /38112719xxx4/ /205/
rule 6 /38112719xxx5/ /206/
rule 7 /38112719xxx6/ /207/
rule 8 /38112719xxx7/ /208/
rule 9 /38112719xxx8/ /209/
rule 10 /38112719xxx9/ /210/
rule 11 /38112719xx10/ /211/
translate called 2
voice translation-profile SIP-OUTGOING
translate calling 1
class-map match-all L3-to-L2_VoIP-Cntrl
match ip dscp af31
class-map match-all L3-to-L2_VoIP-RTP
match ip dscp ef
class-map match-all SIP
match protocol sip
class-map match-all RTP
match protocol rtp
policy-map output-L3-to-L2
class L3-to-L2_VoIP-RTP
  set cos 5
class L3-to-L2_VoIP-Cntrl
  set cos 3
policy-map EthOut
class RTP
name medjunarodni
name mobilni
name fiksni
name lokalni
name besplatni
name igrenasrecu
name sanaplatom
name hitnesluzbe
name servisnesluzbe
dial-peer cor list POZIVmedjunarodni
member medjunarodni
dial-peer cor list POZIVmobilni
member mobilni
dial-peer cor list POZIVfiksni
member fiksni
dial-peer cor list POZIVlokalni
member lokalni
dial-peer cor list POZIVbesplatni
member besplatni
dial-peer cor list POZIVsanaplatom
member sanaplatom
dial-peer cor list POZIVigrenasrecu
member igrenasrecu
dial-peer cor list POZIVhitnesluzbe
member hitnesluzbe
dial-peer cor list POZIVservisnesluzbe
member servisnesluzbe
dial-peer cor list SviPozivi
member medjunarodni
member mobilni
member fiksni
member lokalni
member besplatni
member igrenasrecu
member sanaplatom
member hitnesluzbe
member mobilni
member fiksni
member lokalni
member besplatni
member hitnesluzbe
dial-peer cor list Fiksni
member fiksni
member lokalni
member besplatni
member hitnesluzbe
dial-peer voice 1001 voip
corlist outgoing POZIVmedjunarodni
destination-pattern 00T
session target dns:ims.nnnnnnn.com
dtmf-relay sip-notify rtp-nte
codec g711alaw
dial-peer voice 1002 voip
corlist outgoing POZIVfiksni
translation-profile outgoing SIP-OUTGOING
destination-pattern 0[1-3]T
codec g711alaw
fax rate disable
no vad
dial-peer voice 1003 voip
corlist outgoing POZIVigrenasrecu
destination-pattern 0[4-5]T
session target dns:ims.nnnnn.com
codec g711alaw
dial-peer voice 1004 voip
corlist outgoing POZIVmobilni
destination-pattern 06T
session target dns:imsn.nnnnnn.com
codec g711alaw
dial-peer voice 1005 voip
corlist outgoing POZIVsanaplatom
destination-pattern 0[79]T
session target dns:ims.nnnnnnnnn.com
codec g711alaw
dial-peer voice 1006 voip
corlist outgoing POZIVbesplatni
destination-pattern 0[8]T
session target dns:ims.nnnnnnnn.com
codec g711alaw
dial-peer voice 1007 voip
corlist outgoing POZIVlokalni
destination-pattern [1-8]T
session target dns:ims.tnnnnnnn.com
codec g711alaw
dial-peer voice 1008 voip
corlist outgoing POZIVhitnesluzbe
destination-pattern 9[2-4]T
codec g711alaw
dial-peer voice 1009 voip
corlist outgoing POZIVservisnesluzbe
destination-pattern 9[5-8]T
session target dns:ims.nnnnnn.com
codec g711alaw
sip-ua
credentials number 38112719xxxx username 38112719xxxx@ims.tnnnnnnnnn.com password 7 010107520F53515E75 realm ims.nnnnnnn.com
registrar dns:ims.nnnnn.com expires 3600
sip-server ipv4:10.0.0.18:5060
host-registrar
refer-ood enable
handle-replaces
gatekeeper
no shutdown
telephony-service
no auto-reg-ephone
pin 11319 override
max-ephones 24
max-dn 72
ip source-address 10.10.108.1 port 2000
calling-number initiator
service phone videoCapability 1
timeouts interdigit 5
system message MESSAGE
cnf-file location flash:
time-zone 28
time-format 24
date-format dd-mm-yy
max-conferences 8 gain -6
call-forward pattern .T
moh "music-on-hold.au"
dn-webedit
time-webedit
transfer-system full-consult dss
create cnf-files version-stamp 7960 Aug 21 2013 22:05:22
number 201
label 201
description  201
name 201
number 202
label 202
description OFFICE 202
name Office 202
ephone-dn  3  dual-line
number 203
label 203
ephone-dn  4  dual-line
number 204
label 204
ephone-dn  5  dual-line
number 205
label 205
description  205
name 205
ephone-dn  6  dual-line
number 206
label 206
description 206
ephone-dn  7  dual-line
number 207
label 207
name 207
ephone-dn  8  dual-line
number 208
label 208
description 208
name 208
ephone-dn  9  dual-line
number 209
label 209
description 209
name 209
ephone-dn  10  dual-line
number 210
label 210
description 210
name 210
ephone-dn  11  dual-line
number 211
label 211
description 211
name 211
ephone  1
video
mac-address B4E9.B001.xxxx
type 6921
button  1:1
ephone  2
video
mac-address B4E9.B001.vvvv
type 6921
button  1:2
ephone  3
video
username "user3" password 203
ephone  4
video
mac-address B4E9.B001.gggg
username "user4" password 204
type 6921
button  1:4
ephone  5
video
mac-address B4E9.B001.hhhh
username "user5" password 205
type 6921
button  1:5
ephone  7
video
mac-address B4E9.B001.jjjjj
username "user7" password 207
type 6921
button  1:7
ephone  8
video
username "user8" password 208
type 6921
button  1:8
ephone  9
video
mac-address B4E9.B001.jiii
username "user9" password 209
type 6921
button  1:9
ephone  10
video
mac-address B4E9.B001.rrrr
username "user10" password 210
type 6921
button  1:10
ephone  11
video
username "user11" password 211
type 6921
line con 0
login local
line aux 0
line 2
--More--
