09-27-2013 12:46 AM - edited 03-16-2019 07:34 PM
I'm experiencing the following problem:
I have this scenario: PSTN - SIP GW - CUCM6.1 - SIP TRUNK - CUM8.6
Phone A (extension 33476761834) is registered on CUCM8.6, with external forwarding to the PSTN.
If someone from CUCM8.6 calls - it works.
If someone from CUCM6.1 or from PSTN calls - fast busy. Error in CUCM traces:
19:20:47.056 |//SIP/SIPTcp/wait_SdlSPISignal: Outgoing SIP TCP message to 145.245.235.201 on port 36615 index 3295
[1925279,NET]
SIP/2.0 500 Internal Server Error
Via: SIP/2.0/TCP 145.245.235.201:5100;branch=z9hG4bK3744a3159aed8f
From: <sip:1767@145.245.235.201>;tag=e1d37fe6-cb7b-46e7-a868-6fe81d6bb391-40319184
To: <sip:1834@145.245.116.26>;tag=907605~2b367b5a-23ed-4193-a18b-e8c2f777615e-62999964
Date: Thu, 26 Sep 2013 17:20:46 GMT
Call-ID: f9a33080-24416cee-339879-c9ebf591@145.245.235.201
CSeq: 101 INVITE
Allow-Events: presence
Reason: Q.850;cause=100
Content-Length: 0
|2,100,63,1.580442^145.245.235.232^*
Any idea? Thanks a lot!
(Attaching the complete trace).
09-27-2013 01:44 AM
Alicia,
I have looked at your traces and here are my observations..
1. It looks as if you have enabled EO on the CUCM8.6 sip trunk, hence cucm tryies to allocate a MTP device for EO. Here we can see that MTP_4 was allocated
18:59:16.564 |MediaResourceManager::waiting_MrmAllocateMtpResourceRes - CI=62999932 deviceName=MTP_4 deviceCap=57 count=1|3,100,63,1.95460^145.245.235.201^*
18:59:16.564 |MRM::updateMtpCounter devName=MTP_4, countChange=1|3,100,63,1.95460^145.245.235.201^*
18:59:16.564 |MRM::updateXcodeCounter devName=MTP_4, countChange=1|3,100,63,1.95460^145.245.235.201^
2. While cucm was computitng the SDP needed to send EO, something goes wrong. It is not clear what went wrong but we can see CUCM de-allocating the selected MTP device..
18:59:16.753 |SIG-MediaManager-(17782) - eoCleanup - Deallocated MTP - resourceCI(62999932), MRM(3,1)|2,100,63,1.580390^145.245.235.232^*
3. CUCM then says that an invalid disconnect cause happened. It didnt tell us exactly what happened
18:59:16.755 |//SIP/SIPCdpc(3,74,20955)/ci=62999928/ccbId=907589/scbId=0/appendReasonHdr: appendReasonHdr - Invalid Disconnect Cause(cause=100), No Reason Header Appended|2,100,63,1.580390^145.245.235.232^*
18:59:16.755 |//SIP/SIPCdpc(3,74,20955)/ci=62999928/ccbId=907589/scbId=0/addTransparencyInfo: Transparency info is NULL. Not attaching anything.|2,100,63,1.580390^145.245.235.232^*
18:59:16.755 |//SIP/SIPCdpc(3,74,20955)/ci=62999928/ccbId=907589/scbId=0/appendRPIDHdrForOriginalCalledParty: SIP device does not Support Orig Dialled Phone nego: 0|2,100,63,1.580390^145.245.235.232^*
Its a little difficult to tell whats going on here but here are my thoughts
1. It is possible CUCM is unable to do DO-EO over two sip trunks from different CUCM clusters
2. There may be a problem with the selected MTP device..
Suggestions...
1. Try and enable EO on the sip trunk on CUCM6.1 or
2. Try to disable EO on CUCM8.6 or
3. Remove MTP_4 from your MRG and see if another MTP device will work for DO-EO
Let m know if any of the suggestions work
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
10-02-2013 07:52 AM
Making some tests regarding the problem we saw this:
Received:
INVITE sip:0034638139199@145.245.242.121:5060 SIP/2.0
Date: Tue, 01 Oct 2013 23:02:22 GMT
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, PUBLISH
From: <sip:00034661616350@145.245.235.201>;tag=e1d37fe6-cb7b-46e7-a868-6fe81d6bb391-40468009
Supported: timer,replaces
Min-SE: 1800
Diversion: " Elodie" " <sip:33476768900@145.245.108.29>;reason=unconditional;privacy=off;screen=yes
Remote-Party-ID: <sip:00034661616350@145.245.235.201>;party=calling;screen=yes;privacy=off
Content-Length: 0
User-Agent: Cisco-CUCM6.1
To: <sip:0034638139199@145.245.242.121>
Contact: <00034661616350>00034661616350>
Expires: 180
Call-ID: 86455880-24b1547e-33edda-c9ebf591@145.245.235.201
Via: SIP/2.0/TCP 145.245.235.201:5060;branch=z9hG4bK3863af2fe80489
CSeq: 101 INVITE
Session-Expires: 1800
Max-Forwards: 67
Oct 1 23:02:22: //350172/5D95E6C38917/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 400 Bad Request - 'Malformed CC-Diversion/Diversion/CC-Redirect Header'
To: <sip:0034638139199@145.245.242.121>;tag=DA70FE78-21AE
CSeq: 101 INVITE
Content-Length: 0
The problem is because in the redirect header, the comma "," is not a valid parameter so in the alerting name I removed the comma after the surname (i.e. "Elodie, Mary" to "Elodie Mary" and now is working.
We will change the alerting name by the moment and I will also investigate if there is a parameter to just not divert this name because is not needed this info in forwarded calls.
Anyway the problem is solved
