02-24-2014 07:13 AM - edited 03-16-2019 09:52 PM
I have a problem with IOS of Router 3825 that not display the interface fxo in "show Run" . But when i do the "show version " , FXO interface founded .
I think i have a problem with the IOS that not support FXO Interface . I need a IOS that is support voip and FXO Interface .
Please find attach the show ver & show run
Thanks for your help .
Best Regards .
Solved! Go to Solution.
02-24-2014 07:39 AM
Hi zakariaa,
Can you provide the show inventory? Do you have PVDM cards installed on this router? You will need them in order for fxo ports to be recognized.
Sree
02-24-2014 12:37 PM
Hi Zakariaa
1- Please find the supported cards as the below
2- Please check your PVDM .
3- If the problem is not regarding your PVDM , so i think you can use ipvoicek9-mz.124-21a.bin
Please rate all useful information
02-24-2014 07:39 AM
Hi zakariaa,
Sree
02-25-2014 07:06 AM
Hi Sreekanth
Thanks for your help .the problem has resolved by changing the PVDM cards .
Thanks & Regards
02-25-2014 07:14 AM
That's great Zakariaa. Thanks for updating.
Sreekanth
02-24-2014 12:37 PM
Hi Zakariaa
