Community Member
Problem with fxo port on CME router 2811
Hey pros,
i have a router 2811 with cue module, and 2 cards FXO (4 ports each)
i have the configuration as follow:
voice-port 0/0/0
connection plar opx 700
caller-id enable
voice-port 0/0/1
caller-id enable
voice-port 0/0/2
caller-id enable
voice-port 0/0/3
caller-id enable
voice-port 0/1/0
caller-id enable
voice-port 0/1/1
caller-id enable
voice-port 0/1/2
caller-id enable
voice-port 0/1/3
caller-id enable
700 is the number of my AA.
Actually i have only 4 lines connected on that.for example :
555-555-xxx1
555-555-xxx2
555-555-xxx3
555-555-xxx4
But it seems i cant pass 4 calls in same time, i hear the busy tone...
please someone can help me
thanks a lot
VIP Purple
Re: Problem with fxo port on CME router 2811
Check the maximum sessions setup for the auto attendant in CUE.
Brandon
Community Member
ccn application autoattendant
description "autoattendant"
enabled
maxsessions 8
script "aa.aef"
parameter "busOpenPrompt" "AABusinessOpen.wav"
parameter "holidayPrompt" "AAHolidayPrompt.wav"
parameter "busClosedPrompt" "AABusinessClosed.wav"
parameter "allowExternalTransfers" "false"
parameter "MaxRetry" "3"
parameter "operExtn" "1001"
parameter "welcomePrompt" "AAWelcome.wav"
parameter "businessSchedule" "systemschedule"
end application
Community Member
enabled
maxsessions 8
script "aa.aef"
end application
Community Member
my maxsessions value is 8.
Do you see any other problems ?
VIP Purple
Can you post your config?
Brandon
Community Member
ok i found my own error... :-P
thanks for help tho
my dial-peer voice x pots was incorrect.
533
