Problem with fxs port
We are using FXS port for external paging,it is conected to speakers.It is hanging multiple times, it is going to off-hook state when user stops paging again it is not comming to on-hook state,when i shut and unshut the port it is comming back to on-hook.
Help me  to debug why the port or slot is going to hanging mode.
FXS model : PID: VIC3-2FXS/DID and 3945 model router with 8.6 CME.
Green
Seen problems with this before.
The issue may be voltage levels
Can you try adding this the fxs voice port
voice-port x/x/x
shut
idle-voltage high
no shut
Then monitor to see if this helps
Alex
Regards, Alex. Please rate useful posts.
Hi Alex,
Thankyou for your reply,But I couldn,t find command under voice-port.Kindly suggest me on this.
we are using PID: VIC3-2FXS/DID type module
(config)#voice-port 1/0/1
(config-voiceport)#sh
(config-voiceport)#idl
(config-voiceport)#idl?
% Unrecognized command
(config-voiceport)#id?
Green
Sorry, the command is not supported on VIC3-2fxs cards
Can you try this instead
voice-port 1/0/1
supervisory disconnect lcfo
Alex
Hi Alex
I hope u r doing good.Still port is hanging..kindly let me know how to debug if there is any problem with  FXS module ?..I changed the port also but still it is going to hung mode(Off-hook),it is not comming to on-hook state after droping call..
        IN       OUT
PORT            CH   SIG-TYPE   ADMIN OPER STATUS   STATUS   EC
1/0/1           --         fxs-ls               up    up        off-hook    idle             y
Green
Sorry for the delay in responses.
Can we go back to basics.
Ensure that the wiring from the FXS port is 2 wire only.
FXS PORT RJ11                                           TELE KIT
3 --------------------------------------------------------------------------- TIP
4 --------------------------------------------------------------------------- RING
No other wires should be connected
Try testing the port with a POTS type telephone or linesmans butt
Alex
436
