Problem with g711 to g729 transcode using sip & 2811 dspfarm
bobl12345
Hello-
I would like to connect a generic g711 SIP endpoint to a generic g729r8 or g729br8 endpoint using transcoder on 2811 dspfarm.
I have multiple PVDM2-64s installed on 2811.
The 2811 is registered to a CME on a different router.
My dial-peers are targeted at a generic non-cisco sip server.
Everything works fine as long as its g711 to g711, or g729 to g729 but I can't seem to force g711 to g729.
If I set dial-peer 100 codec to g729  and dial-peer 101 codec to g711
I send a sip INVITE to 101@server  with G729
The 2811 sends back unsupported, 501 not implemented Q.850 cause code 65.
I suspect the problem is with dial-peer setup and codec preferences/classes or I need to point my session target at CME?
Thanks very much for helping!
Here is my 2811 config.
#show sdspfarm units
mtp-1 Device: TCP socket:[-1]  UNREGISTERED
actual_stream:0 max_stream 0 IP:0.0.0.0  0  Unknown 0 keepalive 0
max-mtps:4, max-streams:16, alloc-streams:0, act-streams:0
# running config snip
sccp local FastEthernet0/0
sccp ccm xxxxx identifier 1 version 5.0.
sccp
sccp ccm group 1
bind interface FastEthernet0/0
associate ccm 1 priority 1
associate profile 1 register 123456
keepalive retries 5
switchover method immediate
switchback method immediate
switchback interval 5
dspfarm profile 1 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
maximum sessions 5
associate application SCCP
dial-peer voice 100 voip
service session
session protocol sipv2
session target ipv4:192.168.0.3
incoming called-number 100
dial-peer voice 101 voip
destination-pattern 101
codec g711alaw
gateway
timer receive-rtp 1200
sip-ua
Dspfarm Profile Configuration
Profile ID = 1, Service = TRANSCODING, Resource ID = 1
Profile Description :
Profile Admin State : UP
Profile Operation State : ACTIVE
Application : SCCP   Status : ASSOCIATED
Resource Provider : FLEX_DSPRM   Status : UP
Number of Resource Configured : 5
Number of Resource Available : 5
Codec Configuration
Codec : g711ulaw, Maximum Packetization Period : 30
Codec : g711alaw, Maximum Packetization Period : 30
Codec : g729ar8, Maximum Packetization Period : 60
Codec : g729abr8, Maximum Packetization Period : 60
Codec : g729r8, Maximum Packetization Period : 60
SLOT DSP VERSION  STATUS CHNL USE   TYPE   RSC_ID BRIDGE_ID PKTS_TXED PKTS_RXED
1    3   25.0.256 UP     N/A  FREE  xcode  1      -         -         -
Total number of DSPFARM DSP channel(s) 5
#show sccp all
SCCP Admin State: UP
Gateway IP Address: xxxxxxx, Port Number: 2000
IP Precedence: 5
User Masked Codec list: None
Call Manager: xxxxxxxx, Port Number: 2000
                Priority: N/A, Version: 5.0.1, Identifier: 1
Transcoding Oper State: ACTIVE - Cause Code: NONE
Active Call Manager: xxxxxxx, Port Number: 2000
TCP Link Status: CONNECTED, Profile Identifier: 1
Reported Max Streams: 10, Reported Max OOS Streams: 0
Supported Codec: g711ulaw, Maximum Packetization Period: 30
Supported Codec: g711alaw, Maximum Packetization Period: 30
Supported Codec: g729ar8, Maximum Packetization Period: 60
Supported Codec: g729abr8, Maximum Packetization Period: 60
Supported Codec: g729r8, Maximum Packetization Period: 60
Supported Codec: rfc2833 dtmf, Maximum Packetization Period: 30
Supported Codec: rfc2833 pass-thru, Maximum Packetization Period: 30
Supported Codec: inband-dtmf to rfc2833 conversion, Maximum Packetization Period: 30
SCCP Application Service(s) Statistics:
Profile Identifier: 1, Service Type: Transcoding
TCP packets rx 165, tx 167
Unsupported pkts rx 0, Unrecognized pkts rx 0
Register tx 1, successful 1, rejected 0, failed 0
KeepAlive tx 162, successful 162, failed 0
OpenReceiveChannel rx 0, successful 0, failed 0
CloseReceiveChannel rx 0, successful 0, failed 0
StartMediaTransmission rx 0, successful 0, failed 0
StopMediaTransmission rx 0, successful 0, failed 0
PortReq rx 0
PortRes tx 0, successful 0, failed 0
PortClose rx 0
QosListen rx 0
QosPath rx 0
QosTeardown rx 0, send 0, recv 0, sendrecv 0
QosResvNotify tx 0, send 0, recv 0, sendrecv 0
QosErrorNotify tx 0, send 0, recv 0, sendrecv 0
   err0 0, err1 0, err2 0, err3 0, err4 0, err5 0,
   err6 0, err7 0, err8 0, err9 0, err10 0, err11 0,
   err12 0
QosModify rx 0, send 0, recv 0, sendrecv 0
UpdateDscp rx 0
Reset rx 0, successful 0, failed 0
MediaStreamingFailure rx 0
MediaStreamingFailure tx 0
Switchover 0, Switchback 0
CCM Group Identifier: 1
Description: None
Binded Interface: FastEthernet0/0, IP Address: xxxxxxxxxxxxx
Associated CCM Id: 1, Priority in this CCM Group: 1
Associated Profile: 1, Registration Name: 123456
Registration Retries: 3, Registration Timeout: 10 sec
Keepalive Retries: 5, Keepalive Timeout: 30 sec
CCM Connect Retries: 3, CCM Connect Interval: 10 sec
Switchover Method: IMMEDIATE, Switchback Method: IMMEDIATE
Switchback Interval: 5 sec, Switchback Timeout: 0 sec
Signaling DSCP value: cs3, Audio DSCP value: ef
Total number of active session(s) 0, and connection(s) 0
Total number of active session(s) 0, connection(s) 0, and callegs 0
SCCP Application Service(s) Statistics Summary:
Total Conferencing Sessions: 0, Connections: 0
Total Transcoding Sessions: 0, Connections: 0
Total MTP Sessions: 0, Connections: 0
Total ALG-Phone Sessions: 0, Connections: 0
Total BRI-Phone Sessions: 0, Connections: 0
Total SCCP Sessions: 0, Connections: 0
Total active sessions 0, connections 0, rsvp sessions 0
25 Replies 25
David Smith
Hey Bob,
I'm a little confused.
What do you mean by you have the 2811 registered on a remote CME?
To what router is the transcoder registered to?  Is it locally registered on the 2811 using "telephony-service" locally?  Or is it registered to the far end CME router, using the remote DSP resources?
Could you please clarify a little?
Also, is the call coming in on a dial-peer on the 2811 and going out over another outbound dial-peer on the 2811?
From the gateway that the call is traversing, ie: coming in on an inbound dial-peer and going out on an outbound dial-peer, please recreate the problem and send:
conf t
no logging console
logging buffered 10000000 deb
service sequence
exit
debug voip ccapi inout
debug ccsip message
sho run
sho version
Thank you very much, -Dave
Dave-
Thanks so much for your reply. Here is my set-up.
                        | CME |
| 100 |<--- g729 ---> |   2811   |<--- g711  ---> | 101 |
+-----+     sip       |  PVDM-64 |      sip       +-----+
100@192.168.0.3       +----------+                101@192.168.0.3
                        |sip srv | session target 192.168.0.3
                        +--------+ (also hosts the two soft phones 100 @ 101)
The endpoints are generic SIP “soft” phones hosted on 192.168.0.3. This machine also hosts a generic SIP server which is set up to be the session “target” for the 100 @ 101 dial-peers.
I followed the instructions in the Cicso Unified manager Express System Admin Guide – configuring Transcoder Resources.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmetrnsc.html#wp1010333
If there is a way to do this without involving CME I would be delighted.  I want the transcoding on the 2811 box. The CME seems to be sort of a fifth wheel in the setup.  All calls ingress and egress on 2811.
-Bob
Syslog logging: enabled (11 messages dropped, 1 messages rate-limited,
                0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
    Console logging: disabled
    Monitor logging: level debugging, 0 messages logged, xml disabled,
                     filtering disabled
    Buffer logging:  level debugging, 139 messages logged, xml disabled,
                     filtering disabled
    Logging Exception size (4096 bytes)
    Count and timestamp logging messages: disabled
    Persistent logging: disabled
    Trap logging: level informational, 58 message lines logged
Log Buffer (10000000 bytes):
000094: *Aug 26 14:18:03.931: %SYS-5-CONFIG_I: Configured from console by vty0 (xxx.xxx.21.96)
000095: *Aug 26 14:21:00.583: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:101@192.168.0.3 SIP/2.0
Via: SIP/2.0/UDP 192.168.0.3;branch=z9hG4bKtest0
To: <101>
Call-ID: test-192.168.0.3:1234
CSeq: 1 INVITE
Contact: <100>
User-Agent: Abcd
Allow: INVITE
Allow: ACK
Allow: CANCEL
Allow: BYE
Allow: INFO
Max-Forwards: 70
Content-Type: application/sdp
Content-Length: 179
v=0
o=test 19128 14203282290 IN IP4 192.168.0.3
s=test session
c=IN IP4 192.168.0.3
t=0 0
m=audio 19128 RTP/AVP 18
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=ptime:20
000096: *Aug 26 14:21:00.587: //27/xxxxxxxxxxxx/CCAPI/cc_api_caps_ind:
   Call Entry Is Not Found
000097: *Aug 26 14:21:00.591: //-1/FC492B81804C/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=100
   ----- ccCallInfo IE subfields -----
   cisco-ani=100
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=101
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
000098: *Aug 26 14:21:00.591: //-1/FC492B81804C/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x462C5D00, Call Info(
   Calling Number=100,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=101(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=0, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=27
000099: *Aug 26 14:21:00.591: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000100: *Aug 26 14:21:00.591: :cc_get_feature_vsa malloc success
000101: *Aug 26 14:21:00.591: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000102: *Aug 26 14:21:00.591:  cc_get_feature_vsa count is 1
000103: *Aug 26 14:21:00.591: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000104: *Aug 26 14:21:00.591: :FEATURE_VSA attributes are: feature_name:0,feature_time:1182534488,feature_id:27
000105: *Aug 26 14:21:00.591: //27/FC492B81804C/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=100(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=101(TON=Unknown, NPI=Unknown))
000106: *Aug 26 14:21:00.595: //27/FC492B81804C/CCAPI/cc_process_call_setup_ind:
   Event=0x467CF978
000107: *Aug 26 14:21:00.599: //27/FC492B81804C/CCAPI/ccCallSetContext:
   Context=0x478BD7F0
000108: *Aug 26 14:21:00.599: //27/FC492B81804C/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 27 with tag 0 to app "_ManagedAppProcess_Default"
000109: *Aug 26 14:21:00.599: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To: <101>
Date: Thu, 26 Aug 2010 14:21:00 GMT
Server: Cisco-SIPGateway/IOS-12.x
CSeq: 1 INVITE
Allow-Events: telephone-event
Content-Length: 0
000110: *Aug 26 14:21:00.603: //27/FC492B81804C/CCAPI/ccCallProceeding:
000111: *Aug 26 14:21:00.603: //27/FC492B81804C/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=101, Params=0x478BC9C8, Progress Indication=NULL(0)
000112: *Aug 26 14:21:00.603: //27/FC492B81804C/CCAPI/ccCheckClipClir:
   In: Calling Number=100(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
000113: *Aug 26 14:21:00.603: //27/FC492B81804C/CCAPI/ccCheckClipClir:
   Out: Calling Number=100(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
000114: *Aug 26 14:21:00.603: //27/FC492B81804C/CCAPI/ccCallSetupRequest:
   Destination Pattern=101, Called Number=101, Digit Strip=FALSE
000115: *Aug 26 14:21:00.603: //27/FC492B81804C/CCAPI/ccCallSetupRequest:
   Redirect Number=, Display Info=
   Account Number=100, Final Destination Flag=TRUE,
   Guid=FC492B81-B053-11DF-804C-90A0E9FADC8A, Outgoing Dial-peer=101
000116: *Aug 26 14:21:00.603: //27/FC492B81804C/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=100
   cisco-ani=100
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=101
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
000117: *Aug 26 14:21:00.607: //27/FC492B81804C/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x462C5D00, Interface Type=3, Destination=, Mode=0x0,
   Call Params(Calling Number=100,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=101(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=101, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
000118: *Aug 26 14:21:00.607: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000119: *Aug 26 14:21:00.607: :cc_get_feature_vsa malloc success
000120: *Aug 26 14:21:00.607: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000121: *Aug 26 14:21:00.607:  cc_get_feature_vsa count is 2
000122: *Aug 26 14:21:00.607: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000123: *Aug 26 14:21:00.607: :FEATURE_VSA attributes are: feature_name:0,feature_time:1182534272,feature_id:28
000124: *Aug 26 14:21:00.607: //28/FC492B81804C/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
000125: *Aug 26 14:21:00.607: //28/FC492B81804C/CCAPI/ccCallSetContext:
   Context=0x478BC978
000126: *Aug 26 14:21:00.607: //27/FC492B81804C/CCAPI/ccSaveDialpeerTag:
000127: *Aug 26 14:21:00.607: //28/FC492B81804C/CCAPI/cc_api_call_disconnected:
   Cause Value=65, Interface=0x462C5D00, Call Id=28
000128: *Aug 26 14:21:00.607: //28/FC492B81804C/CCAPI/cc_api_call_disconnected:
   Call Entry(Responsed=TRUE, Cause Value=65, Retry Count=0)
000129: *Aug 26 14:21:00.611: //28/FC492B81804C/CCAPI/cc_api_call_disconnected:
   Cause Value=47, Interface=0x462C5D00, Call Id=28
000130: *Aug 26 14:21:00.611: //28/FC492B81804C/CCAPI/cc_api_call_disconnected:
   Call Entry(Responsed=TRUE, Cause Value=47, Retry Count=0)
000131: *Aug 26 14:21:00.611: //27/xxxxxxxxxxxx/CCAPI/ccCallReleaseResources:
   release reserved xcoding resource.
000132: *Aug 26 14:21:00.611: //28/FC492B81804C/CCAPI/ccCallSetAAA_Accounting:
   Accounting=0, Call Id=28
000133: *Aug 26 14:21:00.611: //28/FC492B81804C/CCAPI/ccCallDisconnect:
   Cause Value=65, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=47)
000134: *Aug 26 14:21:00.611: //28/FC492B81804C/CCAPI/ccCallDisconnect:
   Cause Value=47, Call Entry(Responsed=TRUE, Cause Value=47)
000135: *Aug 26 14:21:00.611: //28/FC492B81804C/CCAPI/cc_api_call_disconnect_done:
   Disposition=-11, Interface=0x462C5D00, Tag=0x0, Call Id=28,
   Call Entry(Disconnect Cause=47, Voice Class Cause Code=0, Retry Count=0)
000136: *Aug 26 14:21:00.611: //28/FC492B81804C/CCAPI/cc_api_call_disconnect_done:
   Call Disconnect Event Sent
000137: *Aug 26 14:21:00.611: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
000138: *Aug 26 14:21:00.611: :cc_free_feature_vsa freeing 467C0A78
000139: *Aug 26 14:21:00.611: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
000140: *Aug 26 14:21:00.611:  vsacount in free is 1
000141: *Aug 26 14:21:00.615: //27/FC492B81804C/CCAPI/ccCallDisconnect:
   Cause Value=65, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
000142: *Aug 26 14:21:00.615: //27/FC492B81804C/CCAPI/ccCallDisconnect:
   Cause Value=65, Call Entry(Responsed=TRUE, Cause Value=65)
000143: *Aug 26 14:21:00.619: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 501 Not Implemented
To: <101>;tag=7935888-E67
CSeq: 1 INVITE
Reason: Q.850;cause=65
Content-Length: 0
000144: *Aug 26 14:21:01.119: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 1 INVITE
Content-Length: 0
000145: *Aug 26 14:21:02.119: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 1 INVITE
Content-Length: 0
000146: *Aug 26 14:21:04.119: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 1 INVITE
Content-Length: 0
000147: *Aug 26 14:21:08.119: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 1 INVITE
Content-Length: 0
000148: *Aug 26 14:21:12.119: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 1 INVITE
Content-Length: 0
000149: *Aug 26 14:21:16.119: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 1 INVITE
Content-Length: 0
000150: *Aug 26 14:21:20.119: //27/FC492B81804C/CCAPI/cc_api_call_disconnect_done:
   Disposition=-11, Interface=0x462C5D00, Tag=0x0, Call Id=27,
   Call Entry(Disconnect Cause=65, Voice Class Cause Code=0, Retry Count=0)
000151: *Aug 26 14:21:20.119: //27/FC492B81804C/CCAPI/cc_api_call_disconnect_done:
000152: *Aug 26 14:21:20.119: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
000153: *Aug 26 14:21:20.119: :cc_free_feature_vsa freeing 467C0B50
000154: *Aug 26 14:21:20.119: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
000155: *Aug 26 14:21:20.119:  vsacount in free is 0
000156: *Aug 26 14:24:20.123: //-1/xxxxxxxxxxxx/CCAPI/ccAppShutdownMode:
   ccAppShutdownMode: remove it from the queue
Building configuration...
Current configuration : 3162 bytes
version 12.4
service sequence-numbers
hostname xxxxxx103
boot-start-marker
boot system flash c2800nm-ipvoicek9-mz.124-15.T5.bin
boot system flash c2800nm-ipvoice-mz
boot-end-marker
card type e1 1 1
no logging console
enable secret 5 $1$40e6$6DTSj.6Ls/N1FRIHK/9N00
no aaa new-model
network-clock-participate slot 1
dot11 syslog
ip cef
no ip domain lookup
isdn switch-type primary-ni
voice-card 0
no dspfarm
voice-card 1
dspfarm
dsp services dspfarm
voice call carrier capacity active
voice dsp crash-dump file-limit 4
voice dsp crash-dump destination flash:DSPcrash.log
voice service pots
voice service voip
allow-connections sip to sip
sip
  no call service stop
voice class codec 1
codec preference 1 g729r8
voice hpi capture buffer 10000000
archive
log config
  hidekeys
controller E1 1/0
framing NO-CRC4
clock source internal
ds0-group 1 timeslots 7 type e&m-immediate-start dtmf dnis
description Cabled to GL Card #5 for subjective test.
controller E1 1/1
shutdown
description LVCC Voice LAN
ip address xxxxxxxxx202.233 255.255.254.0
duplex auto
speed auto
interface FastEthernet0/1
ip address 192.168.0.20 255.255.255.0
duplex auto
speed auto
ip default-gateway xxxxxxxxx202.1
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 xxxxxxxxx202.1
ip http server
no ip http secure-server
control-plane
voice-port 1/0:1
sccp ccm xxxxxxxxx202.238 identifier 1 version 5.0.1
sccp
sccp ccm group 1
keepalive retries 5
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
maximum sessions 5
dial-peer voice 2001 pots
destination-pattern 2001
dial-peer voice 5010 voip
destination-pattern 5010
no modem passthrough
session target ipv4:xxxxxxxxx202.231
dtmf-relay rtp-nte
playout-delay nominal 30
playout-delay minimum low
playout-delay mode fixed
codec g711alaw bytes 80
no vad
dial-peer voice 4722 pots
destination-pattern xxxxxx7334722
port 1/0:1
dial-peer voice 2003 pots
destination-pattern 2003
service session
codec g711alaw
gateway
sip-ua
telephony-service
sdspfarm units 4
sdspfarm transcode sessions 8
max-conferences 8 gain -6
transfer-system full-consult
line con 0
exec-timeout 0 0
privilege level 15
password cisco
line aux 0
password nvs
line vty 0 4
exec-timeout 0 0
privilege level 15
password cisco
no login
scheduler allocate 20000 1000
end
Cisco IOS Software, 2800 Software (C2800NM-IPVOICEK9-M), Version 12.4(15)T5, RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Wed 30-Apr-08 14:17 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
xxxxxx103 uptime is 1 day, 11 hours, 45 minutes
System returned to ROM by reload at 03:00:53 UTC Wed Aug 25 2010
System image file is "flash:c2800nm-ipvoicek9-mz.124-15.T5.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 2811 (revision 53.51) with 247808K/14336K bytes of memory.
Processor board ID FTX1202A2M7
2 FastEthernet interfaces
2 Channelized E1/PRI ports
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
I corrected the above drawing to show correct g711/g729 endpoints in the setup.
                        | CME |
Hey Bob,
OK, thanks, here's what I see:
First off, you're not matching an incoming dial-peer, it's using dial-peer 0...which is the default IOS dial-peer.  This will break transcoding.
Here are your corrected dial-peer configs:
description ***To ext. 100***
no service session <------Remove this configuration, never want to use "service session".
destination-pattern 100
incoming called-number 101
codec g729r8
no vad
description ***To ext. 101***
codec g711alaw
no vad
I'm assuming in this test bed 100 and 101 are your only extensions right now...so 100 is calling 101, and 101 is calling 100.
What the above config will do is ensure that everytime 100 calls 101, that incoming leg uses g729...then the outbound leg to 101 uses g711alaw.  Calls from 101 to 100 will use g711alaw on the inbound leg and g729 on the outbound leg to 100.  This will invoke a transcoder.  You need to traverse two dial-peers using dissimilar codecs in order to invoke your transcoder.  The above config should work.
Second, you're missing the "sdspfarm tag" command under telephony-service...for the transcoder.  Please add the below config:
conf t
telephony-service
sdspfarm tag 1 123456
exit
no sccp
sccp
exit
After adding the "sdspfarm tag" config,  just bounce SCCP to make sure everything regsiters correctly.
Let me know if that works.
Dave-
Thanks very much for your help.
You are correct regarding call flow.
Thanks for the pointer on the dial-peer 0.
Still getting 501 not implemented per below...
-Bob
mtp-1 Device:123456 TCP socket:[-1]  UNREGISTERED
Current configuration : 3301 bytes!
version 12.4
hostname xxxxxxx103
boot-start-marker
boot-end-marker
card type e1 1 1
no logging console
no aaa new-model
dot11 syslog
ip cef
no ip domain lookup
voice-card 0
no dspfarm
voice-card 1
dspfarm
voice service pots
voice service voip
sip
voice class codec 1
archive
log config
  hidekeys
controller E1 1/0
framing NO-CRC4
controller E1 1/1
shutdown
ip address xxxxxxxxx.202.233 255.255.254.0
duplex auto
speed auto
duplex auto
speed auto
ip default-gateway xxxxxxxxx.202.1
ip route 0.0.0.0 0.0.0.0 xxxxxxxxx.202.1
ip http server
control-plane
voice-port 1/0:1
sccp ccm xxxxxxxxx.202.238 identifier 1 version 5.0.1
sccp
sccp ccm group 1
keepalive retries 5
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
maximum sessions 5
session target ipv4:xxxxxxxxx.202.231
dtmf-relay rtp-nte
no vad
destination-pattern xxxxxxxxx7334722
port 1/0:1
description ***To Ext 100***
no vad
description **** To ext 101*****
codec g711alaw
no vad
gateway
sip-ua
telephony-service
sdspfarm units 4
line con 0
exec-timeout 0 0
privilege level 15
password cisco
line aux 0
password nvs
line vty 0 4
exec-timeout 0 0
privilege level 15
password cisco
no login
End
000283: *Aug 26 16:16:31.098: //31/138CF5268056/CCAPI/cc_api_call_disconnect_done:
   Disposition=-11, Interface=0x462C5D00, Tag=0x0, Call Id=31,
000284: *Aug 26 16:16:31.098: //31/138CF5268056/CCAPI/cc_api_call_disconnect_done:
000285: *Aug 26 16:16:31.098: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
000286: *Aug 26 16:16:31.098: :cc_free_feature_vsa freeing 467C0B50
000287: *Aug 26 16:16:31.098: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
000288: *Aug 26 16:16:31.098:  vsacount in free is 0
000289: *Aug 26 16:19:31.102: //-1/xxxxxxxxxxxx/CCAPI/ccAppShutdownMode:
000290: *Aug 26 16:25:01.694: %SYS-5-CONFIG_I: Configured from console by vty0 (xxxxxxxxx.21.96)
000291: *Aug 26 16:26:02.738: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <101>
Call-ID: test-192.168.0.3:abcd
CSeq: 1 INVITE
Contact: <100>
User-Agent: XXXXXX
Allow: INVITE
Allow: ACK
Allow: CANCEL
Allow: BYE
Allow: INFO
Max-Forwards: 70
Content-Length: 178
v=0
o=test 19128 1167143870 IN IP4 192.168.0.3
s=test session
t=0 0
a=fmtp:18 annexb=no
a=ptime:20
000292: *Aug 26 16:26:02.746: //33/xxxxxxxxxxxx/CCAPI/cc_api_caps_ind:
000293: *Aug 26 16:26:02.746: //-1/73EBDC0F805B/CCAPI/cc_api_display_ie_subfields:
   cisco-username=100
   cisco-ani=100
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=101
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
000294: *Aug 26 16:26:02.746: //-1/73EBDC0F805B/CCAPI/cc_api_call_setup_ind_common:
   Incoming Dial-peer=100, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=33
000295: *Aug 26 16:26:02.746: //-1/73EBDC0F805B/CCAPI/ccCheckClipClir:
000296: *Aug 26 16:26:02.746: //-1/73EBDC0F805B/CCAPI/ccCheckClipClir:
000297: *Aug 26 16:26:02.746: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000298: *Aug 26 16:26:02.746: :cc_get_feature_vsa malloc success
000299: *Aug 26 16:26:02.746: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000300: *Aug 26 16:26:02.746:  cc_get_feature_vsa count is 1
000301: *Aug 26 16:26:02.746: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000302: *Aug 26 16:26:02.750: :FEATURE_VSA attributes are: feature_name:0,feature_time:1182534488,feature_id:33
000303: *Aug 26 16:26:02.750: //33/73EBDC0F805B/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
000304: *Aug 26 16:26:02.750: //33/73EBDC0F805B/CCAPI/cc_process_call_setup_ind:
   Event=0x467CF978
000305: *Aug 26 16:26:02.754: //33/73EBDC0F805B/CCAPI/ccCallSetContext:
   Context=0x478C2EC0
000306: *Aug 26 16:26:02.754: //33/73EBDC0F805B/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 33 with tag 100 to app "_ManagedAppProcess_Default"
000307: *Aug 26 16:26:02.758: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To: <101>
Date: Thu, 26 Aug 2010 16:26:02 GMT
CSeq: 1 INVITE
Content-Length: 0
000308: *Aug 26 16:26:02.758: //33/73EBDC0F805B/CCAPI/ccCallProceeding:
000309: *Aug 26 16:26:02.758: //33/73EBDC0F805B/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=101, Params=0x478C2098, Progress Indication=NULL(0)
000310: *Aug 26 16:26:02.762: //33/73EBDC0F805B/CCAPI/ccCheckClipClir:
000311: *Aug 26 16:26:02.762: //33/73EBDC0F805B/CCAPI/ccCheckClipClir:
000312: *Aug 26 16:26:02.762: //33/73EBDC0F805B/CCAPI/ccCallSetupRequest:
000313: *Aug 26 16:26:02.762: //33/73EBDC0F805B/CCAPI/ccCallSetupRequest:
   Guid=73EBDC0F-B065-11DF-805B-90A0E9FADC8A, Outgoing Dial-peer=101
000314: *Aug 26 16:26:02.762: //33/73EBDC0F805B/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=100
   cisco-ani=100
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=101
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
000315: *Aug 26 16:26:02.762: //33/73EBDC0F805B/CCAPI/ccIFCallSetupRequestPrivate:
000316: *Aug 26 16:26:02.762: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000317: *Aug 26 16:26:02.762: :cc_get_feature_vsa malloc success
000318: *Aug 26 16:26:02.762: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000319: *Aug 26 16:26:02.762: cc_get_feature_vsa count is 2
000320: *Aug 26 16:26:02.762: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000321: *Aug 26 16:26:02.762: :FEATURE_VSA attributes are: feature_name:0,feature_time:1182534272,feature_id:34
000322: *Aug 26 16:26:02.762: //34/73EBDC0F805B/CCAPI/ccIFCallSetupRequestPrivate:
000323: *Aug 26 16:26:02.762: //34/73EBDC0F805B/CCAPI/ccCallSetContext:
   Context=0x478C2048
000324: *Aug 26 16:26:02.762: //33/73EBDC0F805B/CCAPI/ccSaveDialpeerTag:
000325: *Aug 26 16:26:02.766: //34/73EBDC0F805B/CCAPI/cc_api_call_disconnected:
   Cause Value=65, Interface=0x462C5D00, Call Id=34
000326: *Aug 26 16:26:02.766: //34/73EBDC0F805B/CCAPI/cc_api_call_disconnected:
000327: *Aug 26 16:26:02.766: //34/73EBDC0F805B/CCAPI/cc_api_call_disconnected:
   Cause Value=47, Interface=0x462C5D00, Call Id=34
000328: *Aug 26 16:26:02.766: //34/73EBDC0F805B/CCAPI/cc_api_call_disconnected:
000329: *Aug 26 16:26:02.766: //33/xxxxxxxxxxxx/CCAPI/ccCallReleaseResources:
000330: *Aug 26 16:26:02.766: //34/73EBDC0F805B/CCAPI/ccCallSetAAA_Accounting:
   Accounting=0, Call Id=34
000331: *Aug 26 16:26:02.766: //34/73EBDC0F805B/CCAPI/ccCallDisconnect:
000332: *Aug 26 16:26:02.766: //34/73EBDC0F805B/CCAPI/ccCallDisconnect:
000333: *Aug 26 16:26:02.770: //34/73EBDC0F805B/CCAPI/cc_api_call_disconnect_done:
   Disposition=-11, Interface=0x462C5D00, Tag=0x0, Call Id=34,
000334: *Aug 26 16:26:02.770: //34/73EBDC0F805B/CCAPI/cc_api_call_disconnect_done:
000335: *Aug 26 16:26:02.770: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
000336: *Aug 26 16:26:02.770: :cc_free_feature_vsa freeing 467C0A78
000337: *Aug 26 16:26:02.770: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
000338: *Aug 26 16:26:02.770:  vsacount in free is 1
000339: *Aug 26 16:26:02.774: //33/73EBDC0F805B/CCAPI/ccCallDisconnect:
000340: *Aug 26 16:26:02.774: //33/73EBDC0F805B/CCAPI/ccCallDisconnect:
000341: *Aug 26 16:26:02.774: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <101>;tag=805D1D4-1E0D
CSeq: 1 INVITE
Content-Length: 0
Where is this IP?  What is this IP that your registering the dspfarm to?
sccp
Aren't you trying to use the DSP's on this local gateway for transcoding?  This would make the most sense, but I don't see this IP anywhere on this GW.
Also, under telephony-service, I just noticed...it's not active yet, you need to add at least 1 DN and one ephone:
telephony-service
sdspfarm units 4
Add:
max-dn 1
max-ephone 1
Thanks, -Dave
(edited to correct typos & IP adresses, codecs below)
Dave-
OK - made the additional config changes and no joy with exact same 501 error per above.  I noticed that the docs say to use the mac address as the sdspfarm tag so I used that in the associated dspfarm profile and and sdspfarm tag below. I imagine it is just a convention but not sure.
My 2811 address is x.202.233.  my CME address is x.202.238.  I don't have CME running on my 2811.  I have been assuming that there is a way to have CME use a specific transcoder on my specific 2811 - do I need to set up ephone on the CME router to make this happen?
Is my understanding correct here (skiping the SIP  callflow)?
CM.238 is CME at x.x.x.238
2811.233 is 2811 at x.x.x.233
1. 100 dials into 2811 inviting 101 using g729
2. 2811.233 sends the 100 dial-peer info to CME.238  saying that it uses only g729
3. 2811.233 sends the 101 dial-peer info to CME.238 saying that it uses only g711
4. CME.238 looks at the two dial-peeers and says - ok, you can do that on dsps located at 2811.233
5 CME.238 sends back the messages needed to set up the g729 to g711 and g711 to g729 transcode channels internal to the 2811.233 (the end user is not aware of this, and SIP just issues a g711 INVITE to 101 endpoint)
6. The media starts flowing...?
My soft phones are just very simple, generic (non-cisco) sip clients.
I really appreciate your help here.  I'm just coming up to speed. Conceptually its a simple configuration. If there is a way to ditch CME.238 and hardwire the transcoding on the 2811.233 between these two endpoints, I'd be all for it :-)
-Bob
telephony-service
sdspfarm units 4
sdspfarm tag 1 mtp001e7ae14148
max-ephones 1
max-dn 1
Codec Configuration
Bob,
Yes, you need you run CME to get the transcoder to register to itself locally.
You don't need to use the MAC address; it is convention that carries over from a requirement on older platforms.  It just needs to match what you specify in the sdspfarm spot under telephony-service.
Is your transcoder registered?  Does 'sh sccp' show it in an ACTIVE state?
If not, in addition to what Dave had you add, I think you need to actually add a bogus DN and ephone, too, like:
ephone-dn 1
number AAAA
ephone 1
mac cccc.cccc.cccc
button 1:1
And then build the config files:
telephony-service
cre cnf
If the issue still occurs, please collect this output:
sh run | s sccp|ccm|telephony|dspfarm|nterface
sh sccp
And then get these debugs for a call failure:
debug ccsip all
Thanks, Dave -  Here is my config.  Regarding adding bogus ephone  -  do I do this on the CME router or my 2811 gateway?
-Bob
edited to add:  I thought I would test to see if the 2811.238 actually had a version of CME that I didn't know about as a hail mary, which is why that shows up as a sccp address. There are no dspfarm profiles associated with it, however.
Codec Configuration
Gateway IP Address: xxxxxxx.202.233, Port Number: 2000
IP Precedence: 5
Call Manager: xxxxxxx.202.233, Port Number: 2000
                Priority: N/A, Version: 3.1, Identifier: 2
Call Manager: xxxxxxx.202.238, Port Number: 2000
Active Call Manager: xxxxxxx.202.238, Port Number: 2000
Bob,
I don't entirely understand how/why CCME works into this, you have a 2811 which hosts the DSP resources, then you have two SIP softphones registered to the sip server on your pc at the 192.168.0.3.  The call comes in from ext. 100 at 192.168.0.3 destined for 101 at 192.168.0.3.  You don't need CCME here at all.
Your transcoder should be registered locally, not have anything to do with a remote CCME.
You only need telephony-service (which enables CCME function) configured on the 2811 locally...so that you can host an SCCP engine to register the xcoder to.
Do this, all on the 2811:
conf t
no sccp
dspfarm profile 1
shut
no sccp ccm group 1
no sccp ccm xxxxxxxxx.202.238 identifier 1 version 5.0.1  (remove the .238 address)
sccp ccm xxxxxxxxx.202.233 id 1 version 5.0.1 (add the .233 LOCAL address)
sccp ccm  group 1
keepalive   retries 5
conf t
dspfarm profile 1
no shut
sccp
telephony-service
sdspfarm units 4
max-dn 1
max-ephone 1
This is abbreviated, but those are the steps you need.  This removes the remote CCME entirely, it's not needed.
This then registers the transcoder locally.
After doing this can you send a new:
sho run
sho sccp all
sho dspfarm profile 1
Thanks, -Dave
In addition to my above reply, I almost forgot, under telephony-service you need the "ip source-address" config:
telephony-service
max-dn 1
max-ephone  1
ip source-address xxxxxxxxx.202.233 port 2000
sdspfarm units 4
Dave - We have joy.   Here is a thing of beauty.... :-)
I saw that the docs mentiion the ip source-addr but it only discusses this in context of "unified cisco phones". I had no clue what the implication of that is with my own server/phones.
The callflow below shows both legs of the call.
I am going to try a few more things to see if I can get it to accept g729br8 (i.e. annex b with vad) .  But first I will try to remember how to tftp the config and then burn it into flash.
That's at least one virtual pint i owe you!
For clarity - the spew below is from my sip server.
To: <101>
Call-ID: test-192.168.0.3:9128-19128
CSeq: 1 INVITE
Contact: <100>
User-Agent: Zzzzz Zzzzz
Allow: INVITE
Allow: ACK
Allow: CANCEL
Allow: BYE
Allow: INFO
Max-Forwards: 70
Content-Length: 179
v=0
o=test 19128 19478920320 IN IP4 192.168.0.3
s=test session
t=0 0
a=fmtp:18 annexb=no
a=ptime:20
00:00:01.522 DEBUG    sipRecv:166
SIP/2.0 100 Trying
To: <101>
Date: Thu, 26 Aug 2010 19:49:47 GMT
CSeq: 1 INVITE
Content-Length: 0
00:00:01.540 DEBUG    sipRecv:166
INVITE sip:101@192.168.0.3:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.0.20:5060;branch=z9hG4bK1B16F9
Remote-Party-ID: <100>;party=calling;screen=no;privacy=off
To: <101>
Call-ID: EA93A467-B08111DF-808D90A0-E9FADC8A@192.168.0.20
Supported: 100rel,timer,resource-priority,replaces
Min-SE:  1800
Cisco-Guid: 3935304414-2961248735-2156433568-3925531786
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1282852187
Contact: <100>
Expires: 180
Max-Forwards: 69
Content-Disposition: session;handling=required
Content-Length: 191
v=0
o=CiscoSystemsSIP-GW-UserAgent 2106 4030 IN IP4 192.168.0.20
s=SIP Call
c=IN IP4 192.168.0.20
t=0 0
m=audio 19082 RTP/AVP 8
a=rtpmap:8 PCMA/8000
a=ptime:20
478920320
00:00:01.655 DEBUG    sipSend:128
SIP/2.0 200 OK
To: <101>;tag=5879f420test1
CSeq: 101 INVITE
Contact: <100>
Allow: INVITE
Allow: ACK
Allow: CANCEL
Allow: BYE
Allow: INFO
Content-Length: 177
v=0
o=test 9128 6358968291 IN IP4 192.168.0.3
s=test session
t=0 0
m=audio 9128 RTP/AVP 8 13
a=rtpmap:13 CN/8000
a=ptime:20
00:00:01.668 DEBUG    sipRecv:166
ACK sip:100@192.168.0.3:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.0.20:5060;branch=z9hG4bK1C21ED
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
00:00:01.675 DEBUG    sipRecv:166
SIP/2.0 200 OK
To: <101>;tag=8C05C14-5FA
CSeq: 1 INVITE
Remote-Party-ID: <101>;party=called;screen=no;privacy=off
Contact: <100>
Supported: replaces
Content-Length: 214
v=0
o=CiscoSystemsSIP-GW-UserAgent 7542 9828 IN IP4 192.168.0.20
s=SIP Call
t=0 0
m=audio 17834 RTP/AVP 18
a=fmtp:18 annexb=no
a=ptime:20
00:00:01.675 DEBUG    sipSend:128
ACK sip:101@192.168.0.3 SIP/2.0
Via: SIP/2.0/UDP 192.168.0.3;branch=z9hG4bKtest1
CSeq: 1 ACK
Contact: <100>
Allow: INVITE
Allow: ACK
Allow: CANCEL
Allow: BYE
Allow: INFO
Max-Forwards: 70
Content-Length: 0
Message was edited by: bobl12345 - edited for clarity
Dave-
My 2811 sccp status isn't happy unless it registers with CME.238.    I don't have a local CME on the 233 machine.  It really seems like if you don't have CME hosted somewhere on your LAN (along with a dsp farm) you are out of luck for transcoding.
-Bob
IP Precedence: 5
Transcoding Oper State: ACTIVE_IN_PROGRESS - Cause Code: TCP_CONN_ERROR
Active Call Manager: NONE
TCP Link Status: NOT_CONNECTED, Profile Identifier: 1
TCP packets rx 0, tx 0
Register tx 0, successful 0, rejected 0, failed 0
KeepAlive tx 0, successful 0, failed 0
PortReq rx 0
PortClose rx 0
QosListen rx 0
QosPath rx 0
   err12 0
UpdateDscp rx 0
Description: None
Binded Interface: FastEthernet0/0, IP Address: xxxxxxx.202.233
Profile Operation State : ACTIVE IN PROGRESS
Application : SCCP   Status : ASSOCIATION IN PROGRESS
Codec Configuration
Hey Bob,
When you configure "telephony-service" like you have on the 2811, this is CCME...you are configuring the telephon-service SCCP engine which runs CCME.
From your 2811 send me a new:
sho run
Thanks, -Dave
