problem with H323 gateway
Hi pro,
My topology is: IP Phone==CCM5.1==H323 Gateway (FXO)===PSTN.
When IP Phone receive a call from PSTN, it rings 3 times and disconnect. If I answer the call, it operate normally.
so what is the most cause of this issue?
Thank you very much!
Re: problem with H323 gateway
Well, Check the phone in CCM, most likely your global Ring No Answer duration is set to 12 seconds, and on the phones you have no voicemail or forwarding set on Call Forward Ring No Answer. if you just want it to keep ringing, on the phone set the Call Forward Ring No Answer Duration up to whatever you want. 4 seconds per ring, the max is 120 seconds. TO clarify this setting it on the DN on the phone...
HTH, please rate useful posts.
Chad
thank you for you quickly respone. I have another problem.
I have configured disconnect tone on my FXO port, it works fine if I configure my gateway using MGCP (IP phone stop ringing if the PSTN phone hang up), but does not work with H323 gateway.
What should I do to solve this issue?
would you mind pasting me a
sh run
and
sh ver
Cheers,
Chad
voice class custom-cptone vn
dualtone disconnect
frequency 450
cadence 200 200
Output Omitted
interface FastEthernet0/0
###connected to CCM
ip address 192.168.99.150 255.255.224.0
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip bind srcaddr 192.168.99.150
Output omitted
voice-port 0/1/0
supervisory disconnect dualtone mid-call
supervisory custom-cptone vn
no battery-reversal
cptone AT
timeouts call-disconnect 1
timeouts wait-release 1
timing hookflash-out 500
impedance complex2
caller-id enable
voice-port 0/1/1
dial-peer voice 8000 voip
destination-pattern 8...
session target ipv4:192.168.100.234
dtmf-relay h245-alphanumeric h245-signal cisco-rtp
codec g711ulaw
no vad
dial-peer voice 100 pots
destination-pattern 9T
progress_ind setup enable 3
progress_ind progress enable 8
port 0/1/0
140
