Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Problem with installation CUCM 7.0 on 7815-I1 - Critical Error
I’m try to install CUCM 7.0 (7.0.1.11000-2) on MCS 7815-I1-CC2/IPC3 (2 GB RAM, 80GB HDD SATA). After first part of installation, server reboot and shows:
Cirital Error
The installation has encountered a unrecoverable internal error. For futher assistance report the following information to your support provider.
Command
"/usr/local/bin/base_scripts/pmNormalizeGeneric/tmp/ipmWorkFile" has exceeded timed threshold of 90 seconds
The System will now halt.
CONTINUE”
I,m try to upgrade manually BIOS with FWUCD-2.1.1-I, FWUCD-2.4.1-I, FWUCD-2.2.1-I. but no result...
1 REPLY
Re: Problem with installation CUCM 7.0 on 7815-I1 - Critical Err
It looks like you could be hitting:
CSCsg78450 - Install fails when pmNormalizeGeneric exceeds 90 second threshold
Symptom:
Install fails with an error about /usr/local/bin/base_scripts/pmNormalizeGeneric has exceeded timed threshold
Conditions:
This  happens when there is a media error on the DVD that prevents reading  the DVD.  We have also seen it happen during an network outage when  installing over then network.
Workaround:
Please  try a different DVD or CD drive.  Or, if installing over the network  please review all firewall, MTU, NAT or other applicable settings.
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsg78450
Hope this helps
Jay
795
