Problem with integration between Nortel Cisco 2901 Broadsoft with sip trunk
Hello Estimated,
We have a problem with this integration:
phone1----PSTN------Nortel--sip trunk----2901---sip trunk----Broadsoft------phone2
when the phone1 call to the phone2, the phone2 ringing but in the phone1 the call is disconnected, however the phone 2 still ringing but spend 10 secons aprox and then the phone2 disconnect the call, this are the configuration and the debbugs:
######################config GW##########################
BW_NORTEL#sh run
Building configuration...
Current configuration : 2009 bytes
! Last configuration change at 12:47:25 UTC Wed Nov 13 2013 by admin
version 15.1
hostname BW_NORTEL
boot-start-marker
boot-end-marker
no aaa new-model
no ipv6 cef
ip source-route
ip cef
voice-card 0
voice service voip
allow-connections sip to sip
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729r8
codec preference 4 g729br8
license udi pid CISCO2901/K9 sn FTX153984FZ
license accept end user agreement
license boot module c2900 technology-package uck9
username admin privilege 15 password 0 soportecom
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address 172.30.3.149 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
description Red BW
ip address 10.1.105.46 255.255.255.0 (PBX BROADSOFT)
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 172.30.3.1
control-plane
mgcp profile default
dial-peer voice 1 voip
description llamadas_hacia_Broadsoft
destination-pattern 2.......
session protocol sipv2
session target ipv4:10.1.105.20 (PBX BROADSOFT)
incoming called-number .
voice class codec 1
dial-peer voice 2 voip
description llamadas_hacia_nextel
destination-pattern 5...
session target ipv4:10.120.146.10 (PBX NORTEL)
voice class codec 1
sip-ua
sip-server ipv4:10.1.105.20
gatekeeper
no shutdown
line con 0
logging synchronous
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
login local
transport input all
scheduler allocate 20000 1000
end
#########################debugs ccapi inout and ccsip messages#########################################
BW_NORTEL#
Nov 13 13:00:41.403: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:26861407;phone-context=SIP_cdp.SIP_udp@sip.nextel.nextel.cl:5060;maddr=10.1.105.46;transport=udp;user=phone;x-nt-redirect=redirect-server SIP/2.0
From: <sip:978078898;phone-context=+56@sip.nextel.nextel.cl;user=phone>;tag=59eb24a0-a92780a-13c4-40030-629b3f-5f8a359a-629b3f
To: <sip:26861407;phone-context=SIP_cdp.SIP_udp@sip.nextel.nextel.cl;user=phone>
Call-ID: 59d6ecc0-a92780a-13c4-40030-629b3f-6624a03c-629b3f
CSeq: 1 INVITE
Via: SIP/2.0/UDP 10.120.146.10:5060;branch=z9hG4bK-629b3f-812e6f54-7a2cfde4
Max-Forwards: 70
Supported: 100rel,x-nortel-sipvc,replaces,timer
User-Agent: Nortel CS1000 SIP GW release_5.0 version_sse-5.50.12
P-Asserted-Identity: <sip:978078898;phone-context=+56@sip.nextel.nextel.cl;user=phone>
Privacy: none
x-nt-e164-clid: +978078898@sip.nextel.nextel.cl;user=phone
History-Info: <sip:26861407;phone-context=SIP_cdp.SIP_udp@sip.nextel.nextel.cl;user=phone>;index=1
x-nt-corr-id: 000052a40a061f0d0b@001ecaf80e71-642ef922
Contact: <sip:978078898;phone-context=+56@sip.nextel.nextel.cl:5060;maddr=10.120.146.10;transport=udp;user=phone>
Min-SE: 0
Allow: INVITE,ACK,BYE,REGISTER,REFER,NOTIFY,CANCEL,PRACK,OPTIONS,INFO,SUBSCRIBE,UPDATE
Content-Type: multipart/mixed;boundary=unique-boundary-1
Content-Length: 1147
--unique-boundary-1
Content-Type: application/sdp
v=0
o=- 17289 1 IN IP4 10.120.146.10
s=-
t=0 0
m=audio 5202 RTP/AVP 18 8 0 101 111
c=IN IP4 10.120.146.16
a=fmtp:18 annexb=no
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=rtpmap:111 X-nt-inforeq/8000
a=ptime:20
a=sendrecv
m=audio 5202 RTP/SAVP 18 8 0 101 111
a=crypto:1 AES_CM_128_HMAC_SHA1_80 inline:5NJiAVkDmzzTJznSPsFAG06a87Mo8ko/laALmKhD|2^031|002302929206:004
a=fmtp:18 annexb=no
a=fmtp:101 0-15
a=ptime:20
a=sendrecv
--unique-boundary-1
Content-Type: application/x-nt-mcdn-frag-hex;version=sse-5.50.12;base=x2611
Content-Disposition: signal;handling=optional
0500b601
0107130081900000a200
09090f00e9a0830001003600
131e070011fd1800a1160201010201a1300e8005300380010181020007850104
1315070011fa0f00a10d02010102020100cc04a105482300
460e01000a0001000100010000000000
--unique-boundary-1
Content-Type: application/x-nt-epid-frag-hex;version=sse-5.50.12;base=x2611
011201
00:14:5e:84:23:88
--unique-boundary-1--
Nov 13 13:00:41.411: //-1/6F35000D8051/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=978078898
   ----- ccCallInfo IE subfields -----
   cisco-ani=978078898
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=26861407
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Nov 13 13:00:41.411: //-1/6F35000D8051/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x31123730, Call Info(
   Calling Number=978078898,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=26861407(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=1, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=35
Nov 13 13:00:41.411: //-1/6F35000D8051/CCAPI/ccCheckClipClir:
   In: Calling Number=978078898(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Out: Calling Number=978078898(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Nov 13 13:00:41.411: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Nov 13 13:00:41.411: :cc_get_feature_vsa malloc success
Nov 13 13:00:41.411:  cc_get_feature_vsa count is 1
Nov 13 13:00:41.411: :FEATURE_VSA attributes are: feature_name:0,feature_time:711422872,feature_id:19
Nov 13 13:00:41.411: //35/6F35000D8051/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=978078898(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=26861407(TON=Unknown, NPI=Unknown))
Nov 13 13:00:41.411: //35/6F35000D8051/CCAPI/cc_process_call_setup_ind:
   Event=0x312CAEC8
Nov 13 13:00:41.411: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 26861407
Nov 13 13:00:41.411: //35/6F35000D8051/CCAPI/ccCallSetContext:
   Context=0x2B8B1C84
   >>>>CCAPI handed cid 35 with tag 1 to app "_ManagedAppProcess_Default"
Nov 13 13:00:41.411: //35/6F35000D8051/CCAPI/ccCallProceeding:
Nov 13 13:00:41.415: //35/6F35000D8051/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=1, Params=0x2B8B30EC, Progress Indication=NULL(0)
Nov 13 13:00:41.415: //35/6F35000D8051/CCAPI/ccCheckClipClir:
   Destination Pattern=2......., Called Number=26861407, Digit Strip=FALSE
   Redirect Number=, Display Info=
   Account Number=978078898, Final Destination Flag=TRUE,
   Guid=6F35000D-4B9A-11E3-8051-B0FF0333B59F, Outgoing Dial-peer=1
Nov 13 13:00:41.415: //35/6F35000D8051/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-ani=978078898
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=26861407
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Nov 13 13:00:41.415: //35/6F35000D8051/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x31123730, Interface Type=3, Destination=, Mode=0x0,
   Call Params(Calling Number=978078898,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=26861407(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=1, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Nov 13 13:00:41.415: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Nov 13 13:00:41.415: :cc_get_feature_vsa malloc success
Nov 13 13:00:41.415:  cc_get_feature_vsa count is 2
Nov 13 13:00:41.415: :FEATURE_VSA attributes are: feature_name:0,feature_time:711422648,feature_id:20
Nov 13 13:00:41.415: //36/6F35000D8051/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
Nov 13 13:00:41.415: //36/6F35000D8051/CCAPI/ccCallSetContext:
   Context=0x2B8B309C
Nov 13 13:00:41.415: //35/6F35000D8051/CCAPI/ccSaveDialpeerTag:
Nov 13 13:00:41.415: //36/6F35000D8051/CCAPI/cc_api_call_proceeding:
   Interface=0x31123730, Progress Indication=NULL(0)
Nov 13 13:00:41.419: //35/6F35000D8051/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Wed, 13 Nov 2013 13:00:41 GMT
CSeq: 1 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
Nov 13 13:00:41.419: //36/6F35000D8051/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:26861407@10.1.105.20:5060 SIP/2.0
Via: SIP/2.0/UDP 10.1.105.46:5060;branch=z9hG4bK1A442
Remote-Party-ID: <sip:978078898@10.1.105.46>;party=calling;screen=no;privacy=off
To: <sip:26861407@10.1.105.20>
Call-ID: 6F36D51E-4B9A11E3-8057B0FF-333B59F@10.1.105.46
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 1865744397-1268388323-2152837375-0053720479
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1384347641
Contact: <sip:978078898@10.1.105.46:5060>
Expires: 180
Max-Forwards: 69
Content-Disposition: session;handling=required
Content-Length: 212
v=0
o=CiscoSystemsSIP-GW-UserAgent 1906 9513 IN IP4 10.1.105.46
s=SIP Call
c=IN IP4 10.1.105.46
t=0 0
m=audio 17340 RTP/AVP 0 19
a=rtpmap:0 PCMU/8000
a=rtpmap:19 CN/8000
a=ptime:20
Nov 13 13:00:41.423: //36/6F35000D8051/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via:SIP/2.0/UDP 10.1.105.46:5060;branch=z9hG4bK1A442
To:<sip:26861407@10.1.105.20>
Call-ID:6F36D51E-4B9A11E3-8057B0FF-333B59F@10.1.105.46
CSeq:101 INVITE
Content-Length:0
Nov 13 13:00:41.619: //36/6F35000D8051/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
To:<sip:26861407@10.1.105.20>;tag=1393761760-1384347947561
CSeq:101 INVITE
Allow:ACK,BYE,CANCEL,INFO,INVITE,OPTIONS,PRACK,REFER,NOTIFY
Supported:
Contact:<sip:10.1.105.20:5060>
RSeq:684239124
P-Asserted-Identity:"Nicolas Soto"<sip:26861407@voip.adexus.cl;user=phone>
Privacy:none
Require:100rel
Content-Length:0
Nov 13 13:00:41.619: //36/6F35000D8051/CCAPI/cc_api_call_alert:
   Interface=0x31123730, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
   Call Entry(Retry Count=0, Responsed=TRUE)
Nov 13 13:00:41.619: //35/6F35000D8051/CCAPI/ccCallAlert:
Nov 13 13:00:41.623: //35/6F35000D8051/CCAPI/ccCallAlert:
   Call Entry(Responsed=TRUE, Alert Sent=TRUE)
Nov 13 13:00:41.623: //36/6F35000D8051/SIP/Msg/ccsipDisplayMsg:
Sent:
PRACK sip:10.1.105.20:5060 SIP/2.0
Via: SIP/2.0/UDP 10.1.105.46:5060;branch=z9hG4bK1B1375
To: <sip:26861407@10.1.105.20>;tag=1393761760-1384347947561
CSeq: 102 PRACK
RAck: 684239124 101 INVITE
Max-Forwards: 70
Content-Length: 0
Nov 13 13:00:41.623: //35/6F35000D8051/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
To: <sip:26861407;phone-context=SIP_cdp.SIP_udp@sip.nextel.nextel.cl;user=phone>;tag=248DE0-256E
CSeq: 1 INVITE
Require: 100rel
RSeq: 7617
Remote-Party-ID: <sip:26861407@172.30.3.149>;party=called;screen=no;privacy=off
Contact: <sip:26861407@172.30.3.149:5060>
Content-Length: 0
Nov 13 13:00:41.643: //36/6F35000D8051/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Via:SIP/2.0/UDP 10.1.105.46:5060;branch=z9hG4bK1B1375
CSeq:102 PRACK
Content-Length:0
Nov 13 13:00:41.887: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 1 INVITE
Max-Forwards: 70
Privacy: none
Min-SE: 0
--unique-boundary-1
v=0
s=-
t=0 0
a=fmtp:18 annexb=no
a=fmtp:101 0-15
a=ptime:20
a=sendrecv
a=fmtp:18 annexb=no
a=fmtp:101 0-15
a=ptime:20
a=sendrecv
--unique-boundary-1
0500b601
--unique-boundary-1
011201
00:14:5e:84:23:88
Nov 13 13:00:41.891: //35/6F35000D8051/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
CSeq: 1 INVITE
Require: 100rel
RSeq: 7617
Content-Length: 0
Nov 13 13:00:42.123: //35/6F35000D8051/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
CSeq: 1 INVITE
Require: 100rel
RSeq: 7617
Content-Length: 0
Nov 13 13:00:42.891: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 1 INVITE
Max-Forwards: 70
Privacy: none
Min-SE: 0
--unique-boundary-1
v=0
s=-
t=0 0
a=fmtp:18 annexb=no
a=fmtp:101 0-15
a=ptime:20
a=sendrecv
a=fmtp:18 annexb=no
a=fmtp:101 0-15
a=ptime:20
a=sendrecv
--unique-boundary-1
0500b601
--unique-boundary-1
011201
00:14:5e:84:23:88
Nov 13 13:00:42.891: //35/6F35000D8051/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
Date: Wed, 13 Nov 2013 13:00:42 GMT
CSeq: 1 INVITE
Require: 100rel
RSeq: 7617
Content-Length: 0
Nov 13 13:00:43.123: //35/6F35000D8051/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
CSeq: 1 INVITE
Require: 100rel
RSeq: 7617
Content-Length: 0
Nov 13 13:00:44.887: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 1 INVITE
Max-Forwards: 70
Privacy: none
Min-SE: 0
--unique-boundary-1
v=0
s=-
t=0 0
a=fmtp:18 annexb=no
a=fmtp:101 0-15
a=ptime:20
a=sendrecv
a=fmtp:18 annexb=no
a=fmtp:101 0-15
a=ptime:20
a=sendrecv
--unique-boundary-1
0500b601
--unique-boundary-1
011201
00:14:5e:84:23:88
Nov 13 13:00:44.891: //35/6F35000D8051/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
Date: Wed, 13 Nov 2013 13:00:44 GMT
CSeq: 1 INVITE
Require: 100rel
RSeq: 7617
Content-Length: 0
Nov 13 13:00:45.123: //35/6F35000D8051/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
CSeq: 1 INVITE
Require: 100rel
RSeq: 7617
Content-Length: 0
Nov 13 13:00:49.123: //35/6F35000D8051/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
CSeq: 1 INVITE
Require: 100rel
RSeq: 7617
Content-Length: 0
Nov 13 13:00:53.123: //35/6F35000D8051/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
CSeq: 1 INVITE
Require: 100rel
RSeq: 7617
Content-Length: 0
Nov 13 13:00:57.123: //35/6F35000D8051/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
CSeq: 1 INVITE
Require: 100rel
RSeq: 7617
Content-Length: 0
Nov 13 13:01:01.123: //35/6F35000D8051/CCAPI/cc_api_call_disconnected:
   Cause Value=102, Interface=0x31123730, Call Id=35
   Call Entry(Responsed=TRUE, Cause Value=102, Retry Count=0)
Nov 13 13:01:01.123: //36/6F35000D8051/CCAPI/ccCallDisconnect:
   Cause Value=102, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
   Cause Value=102, Call Entry(Responsed=TRUE, Cause Value=102)
Nov 13 13:01:01.123: //35/6F35000D8051/CCAPI/ccCallDisconnect:
   Cause Value=102, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=102)
Nov 13 13:01:01.123: //35/6F35000D8051/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 504 Gateway Timeout
CSeq: 1 INVITE
Reason: Q.850;cause=102
Content-Length: 0
Nov 13 13:01:01.123: //36/6F35000D8051/SIP/Msg/ccsipDisplayMsg:
Sent:
CANCEL sip:26861407@10.1.105.20:5060 SIP/2.0
CSeq: 101 CANCEL
Max-Forwards: 70
Timestamp: 1384347661
Content-Length: 0
Nov 13 13:01:01.131: //36/6F35000D8051/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq:101 CANCEL
Content-Length:0
Nov 13 13:01:01.131: //36/6F35000D8051/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x31123730, Tag=0x0, Call Id=36,
   Call Entry(Disconnect Cause=102, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
Nov 13 13:01:01.131: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Nov 13 13:01:01.131: :cc_free_feature_vsa freeing 2A6772B0
Nov 13 13:01:01.131:  vsacount in free is 1
Nov 13 13:01:01.135: //36/6F35000D8051/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 487 Request terminated
CSeq:101 INVITE
Content-Length:0
Nov 13 13:01:01.135: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:26861407@10.1.105.20:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Nov 13 13:01:01.623: //35/6F35000D8051/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 1 INVITE
Content-Length: 0
Nov 13 13:01:02.623: //35/6F35000D8051/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 1 INVITE
Content-Length: 0
Nov 13 13:01:04.623: //35/6F35000D8051/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 1 INVITE
Content-Length: 0
How can resolve this issue? thanks for help
1 REPLY
was routing problem
564
