Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Problem with international calls
I am hitting a problem where with one particular carrier, I am not able to send international calls out. I am using a H.323 IOS gateway and the dial peer is standard with prefix 011.
dial-peer voice 22 pots
description International Dialing
preference 1
destination-pattern 9011T
port 1/0/0:23
prefix 011
When I was troubleshooting, the service provider said their switch does not support 011 from our equipment since they are flagging 011 at their side. they wanted me to strip 011 when sending out through their PRI. I removed 011 from the dial-peer and sent the call. It does not work still. Any idea of what it could be?
given below are the q931 logs with prefix and without prefix.
with prefix 011 - Call Failed
Apr 6 11:13:13.138: ISDN Se1/0/0:23 Q931: pak_private_number: Invalid type/plan 0x0 0x0 may be overriden; sw-type 13
Apr 6 11:13:13.138: ISDN Se1/0/0:23 Q931: Sending SETUP callref = 0x0643 callID = 0x89BF switch = primary-ni interface = User
Apr 6 11:13:13.138: ISDN Se1/0/0:23 Q931: TX -> SETUP pd = 8 callref = 0x0643
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98397
Exclusive, Channel 23
Calling Party Number i = 0x0081, '1145'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x91, '011919710421438'
Plan:ISDN, Type:International
Apr 6 11:13:13.202: ISDN Se1/0/0:23 Q931: RX <- CALL_PROC pd = 8 callref = 0x8643
Apr 6 11:13:13.206: ISDN Se1/0/0:23 Q931: RX <- PROGRESS pd = 8 callref = 0x8643
Cause i = 0x829F - Normal, unspecified
Progress Ind i = 0x8488 - In-band info or appropriate now available
Apr 6 11:13:20.699: ISDN Se1/0/0:23 Q931: TX -> DISCONNECT pd = 8 callref = 0x0643
Cause i = 0x8090 - Normal call clearing
Apr 6 11:13:20.719: ISDN Se1/0/0:23 Q931: RX <- RELEASE pd = 8 callref = 0x8643
Apr 6 11:13:20.723: ISDN Se1/0/0:23 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x0643^Z
_______________________________________________________________________________________________________________________________
without prefix 011 - Call Failed
Apr 6 11:16:17.106: ISDN Se1/0/0:23 Q931: Applying typeplan for sw-type 0xD is 0x0 0x0, Calling num 1145
Apr 6 11:16:17.106: ISDN Se1/0/0:23 Q931: Sending SETUP callref = 0x0645 callID = 0x89C1 switch = primary-ni interface = User
Apr 6 11:16:17.110: ISDN Se1/0/0:23 Q931: TX -> SETUP pd = 8 callref = 0x0645
Standard = CCITT
Channel ID i = 0xA98396
Exclusive, Channel 22
Called Party Number i = 0x80, '919710421438'
Apr 6 11:16:17.146: ISDN Se1/0/0:23 Q931: RX <- CALL_PROC pd = 8 callref = 0x8645
Apr 6 11:16:17.366: ISDN Se1/0/0:23 Q931: RX <- PROGRESS pd = 8 callref = 0x8645
Progress Ind i = 0x8281 - Call not end-to-end ISDN, may have in-band info
Apr 6 11:16:20.606: %ISDN-6-DISCONNECT: Interface Serial1/0/0:22 disconnected from 18188424056 , call lasted 96 seconds
Apr 6 11:16:20.610: ISDN Se1/0/0:23 Q931: TX -> DISCONNECT pd = 8 callref = 0x0644
Apr 6 11:16:20.638: ISDN Se1/0/0:23 Q931: RX <- RELEASE pd = 8 callref = 0x8644
Apr 6 11:16:20.638: ISDN Se1/0/0:23 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x0644^Z
Re: Problem with international calls
Also the career says that they are unable to see any digits coming through if I strip 011 before sending through their crkt. If I add 011, they are able to see the entire digits including 011.
Hall of Fame Super Gold
try:
interface serial x/y:23
isdn map address . plan unknown type unknown
Silver
Isn`t the plan, type already set to unknown as per the debug ? Perhaps changing it to International ?
It is not set to unknown as it should be:
Silver
Sorry I was looking at the failed call without the 011
Without 011, and plan/type isdn/international, the call would succeed. But it is not practical to configure so.
HI
Try to remove ( if you have ) the "isdn sending-complete" under the BRI interface configurantion
I had the same problem and its Solve to me
I applied the command. Now it says I must dial a 1 and the area code followed by number. When I see the debug, I am sending only the international country code followed by the international number without any prefix 011 so that the service provider can add the 011 international flag bit. It still does not seem to work. Any ideas?
I created a new dial-peer for this alone.
dial-peer voice 9739 pots
preference 1
destination-pattern 9011919710421438
port 1/0/0:23
forward-digits 12
Apr 9 09:55:26.511: ISDN Se1/0/0:23 Q931: Applying typeplan for sw-type 0xD is 0x0 0x0, Calling num 1145
Apr 9 09:55:26.511: ISDN Se1/0/0:23 Q931: Sending SETUP callref = 0x0A3C callID = 0x8DB8 switch = primary-ni interface = User
Apr 9 09:55:26.511: ISDN Se1/0/0:23 Q931: TX -> SETUP pd = 8 callref = 0x0A3C
Standard = CCITT
Apr 9 09:55:26.563: ISDN Se1/0/0:23 Q931: RX <- CALL_PROC pd = 8 callref = 0x8A3C
Apr 9 09:55:26.571: ISDN Se1/0/0:23 Q931: RX <- PROGRESS pd = 8 callref = 0x8A3C
Apr 9 09:55:27.299: %ISDN-6-CONNECT: Interface Serial1/1:5 is now connected to 3123429678 N/A
Apr 9 09:55:34.967: %ISDN-6-CONNECT: Interface Serial1/0:22 is now connected to 7449258 N/A
Apr 9 09:55:39.579: ISDN Se1/0/0:23 Q931: TX -> DISCONNECT pd = 8 callref = 0x0A3C
Apr 9 09:55:39.603: ISDN Se1/0/0:23 Q931: RX <- RELEASE pd = 8 callref = 0x8A3C
Apr 9 09:55:39.603: ISDN Se1/0/0:23 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x0A3C
Apr 9 09:55:44.051: %ISDN-6-DISCONNECT: Interface Serial1/1:2 disconnected from 2017950422 , call lasted 432 seconds
You need to send 011. Remove forward-digits command, and use:
destination-pattern 9011........T
prefix 011
or
destination-pattern 9[0][1][1]........T
My service provider does not want me to send 011. They say they will add 011. they seem to have some kind of limitation in their telco switch.I use destination pattern 9011T and prefix 011 for all service providers and it works fine. Only this service provider does not seem to accept when I send as 011 followed by international number.
Try anyway, and show us the trace if doesn't work.
you might download the pri debugger trial on the pippinsoftware.com site. It makes the process a little easier if you're trying to look real time
Hi kraghavansag,
Did you ever find a resolution to this?
I am currently in a migrate from Avaya to Cisco and will have the same requirement our long distance PRIs.
463
