Community Member
Problem with MLA Backup
I have a 4.1(3) system on which I am attempting to backup the MLA DB. MLA is version "MultiLevelAdmin.dll 1.0.0.1". I am getting error messages when the "c:\ciscowebs\MLA\install\backup.bat" batch job executes the step for "isql"
C:\CiscoWebs\MLA\install>isql -i backup.sql -U sa -P ********
1> 2> 3> 4> 5> 6> Msg 170, Level 15, State 1, Server SA26-CM-1, Line 4
Line 4: Incorrect syntax near '-'.
Msg 170, Level 15, State 1, Server SA26-CM-1, Line 5
Line 5: Incorrect syntax near '-'.
1>
"isql" is an executable, so I don't know how to go about debugging it. Any ideas?
Thx.
Silver
Re: Problem with MLA Backup
Use the following procedure to back up the MLA
Step 1 Go to C:\Ciscowebs\MLA\install directory.
Step 2 Run the backup.bat with the directory and filename where you want the database to be backed up. Use the SQL system administrator user password (sa).
Example: backup.bat c:\backup MLADBbkup ****
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/3_3_3/mla122/mla_i.html
Community Member
As an FYI: I was informed by Cisco TAC on this that separate MLA Backups are no longer required after UCM 3.3. It will be covered in both BARS and DMA.
116
