Problem with MTP Registration
I am trying to register an IOS S/W MTP from a 2811 to the CallManager, but it won't register. In CM, I have:
Media Termination Point: mtp001794608e30
Media Termination Point Type Cisco IOS Enhanced Software Media Termination Point
In the gateway, I have:
voice-card 0
no dspfarm
dsp services dspfarm
sccp local Vlan210
sccp ccm X.X.X.X identifier 1
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate profile 1 register mtp001794608e30
dspfarm profile 1 mtp
codec g711ulaw
maximum sessions software 500
associate application SCCP
RTR#sh sccp
*Nov 9 23:44:49.475: %SYS-5-CONFIG_I: Configured from console by console
SCCP Admin State: UP
Gateway IP Address: X.X.X.X, Port Number: 2000
IP Precedence: 5
User Masked Codec list: None
Call Manager: X.X.X.X, Port Number: 2000
Priority: N/A, Version: 3.1, Identifier: 1
Software MTP Oper State: ACTIVE_IN_PROGRESS - Cause Code: NOT_REGIS_WITH_CCM
Active Call Manager: X.X.X.X, Port Number: 2000
TCP Link Status: CONNECTED, Profile Identifier: 1
Reported Max Streams: 1000, Reported Max OOS Streams: 0
Supported Codec: g711ulaw, Maximum Packetization Period: 30
Supported Codec: rfc2833 dtmf, Maximum Packetization Period: 30
//Show Diag:
PVDM Slot 0:
32-channel (G.711) Voice/Fax PVDMII DSP SIMM PVDM daughter card
Hardware Revision : 3.1
Part Number : 73-8539-03
Board Revision : A0
Deviation Number : 0
Fab Version : 03
PCB Serial Number : FOC08321BU1
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Processor type : 00
Product (FRU) Number : PVDM2-32
Version Identifier : NA
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF 40 03 EE 41 03 01 82 49 21 5B 03 42 41 30
0x10: 88 00 00 00 00 02 03 C1 8B 46 4F 43 30 38 33 32
0x20: 31 42 55 31 03 00 81 00 00 00 00 04 00 09 00 CB
0x30: 88 50 56 44 4D 32 2D 33 32 89 4E 41 20 20 D9 02
0x40: 40 C1 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
WIC Slot 0:
T1 (1 port) Multi-Flex Trunk WAN daughter card
Hardware revision 1.0 Board revision F0
Serial number 33087017 Part number 800-03568-03
FRU Part Number VWIC-1MFT-T1=
Test history 0x0 RMA number 00-00-00
Connector type PCI
EEPROM format version 1
0x20: 01 20 01 00 01 F8 DE 29 50 0D F0 03 00 00 00 00
0x30: 78 00 00 00 04 12 20 00 FF FF FF FF FF FF FF FF
WIC Slot 1:
Serial 1T WAN daughter card
Hardware revision 1.0 Board revision J0
Serial number 19618527 Part number 800-01514-01
FRU Part Number WIC-1T=
Connector type Wan Module
0x20: 01 02 01 00 01 2B 5A DF 50 05 EA 01 00 00 00 00
0x30: 98 00 00 00 00 05 15 01 FF FF FF FF FF FF FF FF
//sh ver:
Cisco IOS Software, 2800 Software (C2800NM-ADVENTERPRISEK9_IVS-M), Version 12.4(8c), RELEASE SOFTWARE (fc3)
Re: Problem with MTP Registration
The main caveat with IOS resources is ensuring that the MTP name within CallManager is the same name assigned to the MTP profile, which I believe from your post it is.
I would also try specifying the CCM version after the following command:-
Allan.
HTH.
Thanks Allan, you fixed my issue! The lack of a version number prevented my S/W MTP from registering with CCM.
Good to see that previous posts are still providing the necessary help. Glad to see that it resolved your problem. Best of luck.
Allan.
Green
I believe I've done everything except for
gateway
timer receive-rtp seconds
And I don't think those are required in this situation. Also, I have no problems registering the hardware DSPs, just the software IOS MTP. I am trying to use it for SIP RFC2833.
I have notice from the configuration you provided in an earlier post that under the voice-card configuration you have 'no dspfarm'.
To add a specified voice card to those participating in a digital signal processor (DSP) resource pool, use the dspfarm command in voice-card configuration mode.
voice-card 0
dspfarm
I have had similar issue with profiles registering in the past with 12.4(9)T1, and after configuring the voice-card as above they register successfully.
Take a look at the following link, it provides examples for troubleshooting DSP Farm registration.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080108fe6.shtml
Allan.
1047
