05-14-2008 07:14 AM - edited 03-15-2019 10:39 AM
Dear all,
Please I have a problem with my H.323 Voice Gateway. I use a cisco 2801 with VIC2 - BRI-NT/TE and FXO cards. when i debug isdn q931, i get the follwing error message:
- *May 14 15:13:18.359: ISDN BR0/1/1 Q931: Applying typeplan for sw-type 0x1 is 0x
0 0x0, Called num.
Could you please let me know what can cause this problem ?
thanks in adavance,
05-14-2008 07:22 AM
It is only a message, doesn;t cause any problem, and it happens all the time, nothing to worry about.
05-14-2008 09:31 AM
but the problem is that i cannot not make any outgoing calls ???
how to resolve the issue?
05-14-2008 09:43 AM
with just that message there is no way to tell, post the whole config and explain the problem as detailed as possible
javalenc
05-14-2008 09:44 AM
Collect and send "debug isdn q931" with "term mon". Also specify if you have CME, CM h.323 or MGCP or what else.
05-15-2008 09:09 AM
05-15-2008 09:20 AM
Are your BRI circuits in group ? If so you will need "isdn static-tei 0" under each interface. Then I suggest you configure said BRIs in trunk-group to simplify configuration.
As an appreciation to those providing answers, please rate useful posts with the scrollbox below!
05-15-2008 09:34 AM
thanks for your prompt feedback. I have added this commande and i see the isdn status : channel0: MULTIPLE_FRAME_ESTABLISHED
channel1: TEI_ASSIGNED
When i debug isdn q931, i cannot see anything for incoming/outgoing calls ??
However, I get some traffic when i debug voice ccapi inout. what can cause this ?
05-15-2008 09:36 AM
Your pots DP are strange. Make thyem something reasonable like patterns of number you are calling. Place interface in trunk-group so you have only on Dp to configure referencing the trunk group.
05-15-2008 09:40 AM
I have configured the DP 4 to route calls to my mobile (just for testing). could you please explain if it's a problem of config or others ? this configuration was working before.
thanks,
05-15-2008 10:04 AM
I will just add, when i debug isdn q931 and csim start command (to my mobile matched by DP number 4), i cannot see any isdn messages??? just :
0 0x0, Called num mynumber and
ISDN BRI0/0/0 q931: L3_Shutdown: Shutting down ISDN Layer 3 ??
Appreciate your help and assistance,
05-15-2008 10:13 AM
You DP 4 is absorbing all the digits because you did not configure "forward-digits all" or "no strip-digits". Hence, null called number and no call.
