problem with outgoing calls
          Good morning,  I 've a voice-gw with 2 ISDN PRI. I need to send outgoing calls from extesions 62xx and 63xx oalways oone of these primary.
I' ve configured voice translation rules, but  not all calls are correclty sent to required PRI
Each one have suggestions?
Thanks in advance
giancarlo
1 ACCEPTED SOLUTION
okay, what do we have here. CallManager Expres? Or, CUCM?
Signaling: MGCP? SIP? H.323?
G.
VIP Super Bronze
Can you explain a little bit more. Do you want to send calls to a specific PRI?
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Yes on my voice-gtdw I've two isdn PRI  0 and 1
I want that alla calls from extension 63xx will be sen on PRI 0
G.
I've a callamanger 7.1 and the signaling is H323.
VIP Super Bronze
Re: problem with outgoing calls
There are two options you can use to achieve this...
1. Use answer-address on your inbound dial-peer to  match the calling number, then prefix a digit for outbound calls..
The configuration for this is demonstrated below
voice translation rule 1
rule 1 /\(.+\)/ /8\1/
voice translation profile PRI0
translate called 1
dial-peer voice 6 voip
answer-address 63..
translation-profile incoming PRI0
no vad
dtmf-relay h245-alpha
Next configure a seperate dial-peer to route calls to PRI0
dial-peer voice 7 pots
destination-pattern 8T
port 0/0/0:15
For this to work, you need to ensure that you dont have (incoming called number .) on your gateway...
2. The second option is to use a different route pattern in cucm and then prefix a digit at the route list level..
You then need to configure a dial-peer to  match the the prefixed digit and point to PRI 0
118
