Problem with outward calls sip phones
I have a problem with the UC500 SIP phones, they can make and receive calls, but when trying to make an outside call is not possible. Now the same is happening with ATA and SPA using SIP.
The configuration is:
voice service voip
ip address trusted list
  ipv4 0.0.0.0 0.0.0.0
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
fax protocol none
no fax-relay sg3-to-g3
sip
  bind control source-interface Vlan1
  bind media source-interface Vlan1
  header-passing
  registrar server expires max 3600 min 600
  no update-callerid
  sip-profiles 1000
  no call service stop
voice register global
mode cme
source-address 192.168.1.9 port 5060
no outbound-proxy
max-dn 56
max-pool 80
authenticate register
timezone 21
time-format 24
date-format D/M/Y
hold-alert
voicemail 399
tftp-path flash:
file text
create profile sync 0164458440065732
voice register dn  6
number 180
allow watch
name linksys
no-reg
label linksys
voice register dn  7
number 171
allow watch
name SPA2-LINE2
no-reg
voice register pool  6
id mac 000E.08D6.BA8E
type ATA
number 6 dn 6
dtmf-relay rtp-nte
username 180 password XXXXXXXXXXXXX
description linksys
codec g711ulaw
no vad
voice register pool  7
id mac 000E.0820.A2F7
type ATA
number 7 dn 7
dtmf-relay rtp-nte
username 171 password XXXXXXXXXXXXX
description SPA2-LINE2
codec g711ulaw
no vad
Someone could guide me to rectify the problem.
best regards
Everyone's tags (2)
VIP Super Bronze
Are you using a sip trunk to the PSTN or E1? Can you attach your full config (sh run) and also send a debug ccsip messages...if you rae using a sip trunk
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Hello Aokanlawon,
In relation to SIP or PSTN E1 TRUNK, tell you that not only use a SIP trunk but with a VOIP provider via internet.
I leave a link of the configuration file (sh run) and debug, I deleted and obfuscated information on phones and other irrelevant information for the detection of the problem.
SH RUN ->  https://dl.dropboxusercontent.com/u/6992364/290713.conf
DEBUG -> https://dl.dropboxusercontent.com/u/6992364/debug_ccsip_messages.txt
best regards
Aokanlawon,
Indeed the extension is configured in the UC500, tell you that this is precisely the problem we have extension 180, in this case can not make outgoing calls.
Can you think of what could be the reason?
Best Regards
VIP Super Bronze
Can you do another test call and send ne the following debug..
debug voip ccapi inout
I've made ​​another test call, I attached the log file.
https://dl.dropboxusercontent.com/u/6992364/debug_voip_ccaou_inout.txt
best regards
VIP Super Bronze
I dont see any voip dial-peer matched for the outbound leg of the call. If you are using a sip trunk then you need to configure a valid dial-peer with the correct ip address provided by your provider.
The only dial-peer that is matched for the called number is:
dial-peer voice 74 pots
corlist outgoing call-national-plus
description **CCA*Spain*Mobile**
translation-profile outgoing OUTGOING_TRANSLATION_PROFILE2
destination-pattern 06........
port 0/3/3
forward-digits all
no sip-register
Clarify that a SIP TRUNK but there are also analog and digital lines as you indicate the call should go out that dial-peer has indicated, the issue is still not out the call.
Need anything else that might help?
Best Regards
313
