Problem with putting users on hold when a 2nd call is coming in
Hi everyone,
We are having a bit of a frustrating problem right now. When a person is on the phone and has a new call coming in the only way they can put the call on hold is by seizing the incoming line.
Is there a way to enable the hold button in this state? What phone state is this?
Re: Problem with putting users on hold when a 2nd call is coming
Im not a voice guy though. I am under the impression that there was a Hot fix to support hold and transfer available in 5.1.0z.
did you check cisco's website for this ?
Not yet. I just got involved with this.
Thanks for the tip I will look into this.
As far as I know, there is no way to put a call on hold during the ringing state. Generally you want to answer the line and let the person know that you will be placing them on hold.
Hall of Fame Super Red
Hi Brian,
If you are trying to put Call # 1 on Hold so you can answer Call # 2 you should be able to just go ahead and select Call # 2 by pressing the associated Line Button and Call # 1 will automatically be put on Hold (just tried this and it works well!) I can also use the Hold Softkey for this action.
The call state for this would be Ring-In or Ringing.
Hope this helps!
Rob
Rob,
Just seizing the line won't help because the users don't want to necessarily answer the incoming call. We have people that have 30 lines on their phones which are constantly ringing. They are basically unable to place people on hold because they are always in a ring in state.
In 4.1 they were able to place a person on hold when there was a new call. In 5.1 they are not. The Hold Softkey isn't there and there is no way to put it into the Ring In state.
Looking at my old 4.1 server the hold key wasn't in the Ring In state there either. Yet the softkey was on the phone when a call came in.
Since you have so many calls coming into your business for CS, why not use CRS to handle the calls. It looks to me that it would be more feasible to have the calls queued and then handed off one by one as soon as the Customer Service agent becomes available.
That won't work. This isn't a call center. They are sales assistants that have numerous salepeople they are covering for.
hmm. Have you taken a look at the Business Attendant Console? Here is the link.. This may help.
http://www.cisco.com/en/US/products/ps7294/index.html
We have hundreds of people that are doing this. AC is not feasible for us.
Hi Brian,
Two more questions;
Exact Phone Firmware? And I'm guessing these are Shared Lines?
Rob
TAC was able to resolve the problem.
There is a setting called auto-line select. When this is enabled it automatically shifts focus to the incoming call which changes the phone to ring in state.
When you disable this feature it keeps focus on the existing line and your phone state remains connected. We have had our Call Managers up for 4 years and we have that feature disabled the entire time thus never dealing with this problem.
Thanks for the help guys.
I must have read your orginal post incorrectly. It appears that you wanted to have the abiltiy to put the first call on hold instead of the call ringing in. Was that what you were trying to do or am I still missing something?
163
