Problem with SIP trunk and B-ACD
Hi!
I have a problem with B-ACD on CCMe. B-ACD has two options: transfer to hunt group and dial by extension.
If I call to B-ACD from internal IP phone everything works fine (both options).
If call comes from SIP provider I can chose any option, but dial by extension works incorrect. First of all I don’t hear prompt «bacd_enter_dest.au». It is strange, because I here without any problem other prompts. And when I press extension number B-ACD collect only two digest, double one of them, add digit 2 and then place a call. Of cause called number is incorrect.
Main thing! If call comes from internal IP phone everything work fine. I hear prompt «bacd_enter_dest.au» and I can dial by extension.
Any ideas?
Topology:
SIP provider -- SIP (G711ulaw) --Incoming DP (SIP) --Outgoing DP (H323)-- H323 (G711ulaw)--B-ACD
Best regards, Sergey
Re: Problem with SIP trunk and B-ACD
Not sure what IOS ver. you have on the CME but this
should work fine later 12.4 IOS (CME 4.3/7.0 or later)
Its possible that dtmf method being negotiated for the
external call is not OOB/reliable.
Can u share your config along with following debugs for
one call?
deb sip mess | err
deb voip ccapi inout
deb voip application script | err
Pl. run these when there is no other call on the system
(if possible as these are very verbose and will impact sys
perf)
Capture in a logging buffer along with msec timestamping
and sequence num.
Pl. mention call flow and calling/called num.
Thank you very much for your attention.
The problem was solved. I have misconfigured dial-peer. This dial-peer was a reason of such strange behavior.
216
