Community Member
Problem with Unity subscriber
Hello everybody,
I have an strange issue with the voice mail subscribers..I configure i voice subscriber and it doesnt work until i put on the function forward all to the voicemail. I restart the unity ,voicemail ports and nothing..
Thank you very much
1 REPLY
Re: Problem with Unity subscriber
what do you mean??
if you set CFB, CFNA to VM it doesn't work??
you're not providing enough info to help you
java
if this helps, please rate
java
www.cisco.com/go/pdi
100
