Community Member
problem with user's message in mailbox CUE7.1
End user has a CM ver 7.1.5 with NM- CUE 7.1, a few user has a problem with the messages that are listened when someone leaves a massage;
the extension number in past was assigned to other user (this extension was associated to mailbox).
After the reassignation of the extension the mailbox was deleted and created a new one, the user records all new prompts for his voicemail (we verified when user access to his voicemail via phone's button), but when someone leaves a message is listened the old prompts not the new ones of the new user.
I have checked the config of the mailbox , is exactly the same as the other so  I don't understand why the new prompts are not listen, the old user was delete completly.
any suggestion?
regards
Did you do a "show run" within the CUE module to verify if the previous user was completely removed?
Yosh
HTH Regards, Yosh
Community Member
Hi Yosh,
Yes,  I double check by GUI and sh run
regards
Try removing the "voicemail mailbox" via the CLI.
Yosh
HTH Regards, Yosh
Community Member
Hi yosh,
I've already done that but problem remains
regards
Can you share the config of voicemail box for one user who has an exsting issue.
thanks
Please rate all useful information
I hope to make sure under voicemail configuation
greating alternate
no tutorial
thanks
please rate all useful infromation
Hi Filiberto,
There is  a  resync option on the CUE GUI, try resyncing the CUCM & CUE.
Make sure that the new user has recorded his prompts correctly.
See if that works.
Kevin
Community Member
Hi Kevin,
I can't find resync option in CUE GUI,
by CLI do you know the command  CUE 7.1
regards
Community Member
kevin,
I solved the problem for prompt ,but the Ip phone's display shows New voicemail for XXXX, but XXXX is the name of the old user.
I don't know form where takes the old name. IP phone is a 6921
regards
106
