Community Member
Probleme with database during DMA export (CCM 4.1(3) ->CUCM 7.1.3)
hi all,
i'm planning to upgrade from CCM 4.1.3 to CUCM 7.1.3, after running DMA export i got those warning messages :
  Row: 275 SQL error: -746(25040)
   Error executing "update NumPlan set fkRoutePartition='ce56af2e-7658-41a0-9744-40b42f86069f' where pkid='aef96c30-888f-475f-88b3-176379b4f013'": [Informix][Informix ODBC Driver][Informix]Unspecified System Error =  -746. sqlerrm(25040)
      pkid                       aef96c30-888f-475f-88b3-176379b4f013  NOT MODIFIABLE
      fkRoutePartition           ce56af2e-7658-41a0-9744-40b42f86069f
      DNOrPattern                160
      tkPatternUsage             5  NOT MODIFIABLE
      CFBDestination
      CFNADestination
      fkRouteFilter
      tkNetworkLocation          1
      fkDigitDiscardInstruction
      PrefixDigitsOut            1
      BlockEnable                false
      tkMixer
      CalledPartyTransformationMask
      fkCallingSearchSpace_SharedLineAppear  61779b5b-6941-4527-88ce-5baf31640078
      fkDialPlan
      fkCallingSearchSpace_Translation
      CallingPartyTransformationMask  03766XXXX
      PatternUrgency             false
      tkStatus_useFullyQualCallingPartyNum  0
      fkCallingSearchSpace_CFB
      fkCallingSearchSpace_CFNA
      DialPlanWizardGenID
      UserHoldMOHAudioSourceID
      NetworkHoldMOHAudioSourceID
      CallForwardExpansionMask
      tkAutoAnswer               0
      PersonalRoutingEnabled     false
      DeviceFailureDN
      fkCallingSearchSpace_DeviceFailure
      CallingPartyPrefixDigits
      fkCallingSearchSpace_MWI
      fkVoiceMessagingProfile
      CFBVoiceMailEnabled        false
      CFNAVoiceMailEnabled       false
      CFDFVoiceMailEnabled       false
      fkAARNeighborhood
      withTag
      withValueClause
      Description
      CFNADuration
      tkPatternPrecedence        5
      CFAPTVoiceMailEnabled      false
      CFAPTDestination
      tkReleaseCauseValue        0
      fkCallingSearchSpace_CFAPT
      tkPresentationBit_ConnectedLine  0
      tkPresentationBit_CallingName  0
      tkPresentationBit_ConnectedName  0
      tkPresentationBit_CallingLine  0
      SupportOverlapSending      false
      CFAPTDuration
      isCallable                 true
      fkCallManager
      AlertingName
      AuthorizationCodeRequired  false
      AuthorizationLevelRequired  0
      CFBIntDestination
      CFBIntVoiceMailEnabled     false
      CFNAIntDestination
      CFNAIntVoiceMailEnabled    false
      ClientCodeRequired         false
      CSSForCFA
      fkCallingSearchSpace_CFBInt
      fkCallingSearchSpace_PFF
      fkCallingSearchSpace_PFFInt
      PFF_CFB                    false
      PFF_CFNA                   false
      PFFDestination
      PFFIntDestination
      PFFIntVoiceMailEnabled     false
      PFFVoiceMailEnabled        false
      fkCallingSearchSpace_Reroute    NOT MODIFIABLE
      fkMatrix_Presence          ad243d17-98b4-4118-8feb-5ff2e1b781ac
      fkCallingSearchSpace_CFNAInt
      IsMessageWaitingOn         false
      OutsideDialtone            true
      DeviceOverride             false
      AllowCTIControlFlag        true
      AlertingNameASCII
      resetToggle                false
      tkReset                    2
      AARDestinationMask
      AARKeepCallHistory         true
      AARVoiceMailEnabled        false
      CFHRDN
      CFHRIntDN
      CFHRIntVMEnabled           false
      CFHRVMEnabled              false
      CFURDestination
      CFURIntDestination
      CFURIntVoiceMailEnabled    false
      CFURVoiceMailEnabled       false
      fkCallingSearchSpace_CFHR
      fkCallingSearchSpace_CFHRInt
      fkCallingSearchSpace_CFUR
      fkCallingSearchSpace_CFURInt
      fkCallingSearchSpace_revert
      HRDuration
      HRInterval
      ikNumPlan_ParkCode
      RevertDestination
      CFHRDuration
      tkDeviceSecurityMode_MinimumAllowed
      tkCFACSSActivationPolicy   0
      fkResourcePriorityNamespace
      tkNumberingPlan_Called     0
      tkPriOfNumber_Called       0
      tkPriOfNumber_Calling      0
      tkNumberingPlan_Calling    0
      fkDevice_IntercomDefault
      DNOrPatternIPv6
      tkStatus_PartyEntranceTone  2
      ParkMonForwardNoRetrieveDN
      ParkMonForwardNoRetrieveIntDN
      ParkMonForwardNoRetrieveIntVMEnabled  false
      ParkMonForwardNoRetrieveVMEnabled  false
      fkCallingSearchSpace_PkMonFwdNoRet
      fkCallingSearchSpace_PkMonFwdNoRetInt
      ParkMonReversionTimer
and the message:
Row: 1046 SQL error: -746(35259)
   Error executing "update PhoneButton set ButtonNum=22 where pkid='7926e6fd-7c8f-4966-8fa8-5c37c669f738'": [Informix][Informix ODBC Driver][Informix]Unspecified System Error =  -746. sqlerrm(35259)
      pkid                       7926e6fd-7c8f-4966-8fa8-5c37c669f738  NOT MODIFIABLE
      fkPhoneTemplate            b7371212-0ddc-4fa2-9abd-37bd8848ad7c  NOT MODIFIABLE
      ButtonNum                  22
      tkFeature                  255
      Label                      None
      ParamN1                    14
      ParamN2
      ParamT1
      ParamT2
      isFixedFeature             false  NOT MODIFIABLE
      resetToggle                false
      tkReset                    2
i don't know what possible cause coulbe behind those messages and whether it's ok to ignore them or not.
if you have any idea how to deal with those messages, i would really appreciate it.
Thx in advance
Bilal
Super Bronze
Re: Probleme with database during DMA export (CCM 4.1(3) ->CUCM
Hi Bilal
The first error you listed says it can't add a record with a reference to 'ce56af2e-7658-41a0-9744-40b42f86069f'. Usually this means there is an error earlier in the log files where the route partition with PKID 'ce56af2e-7658-41a0-9744-40b42f86069f' was not imported, so items cannot reference it.
Commonly problems are caused by the use of special characters in descriptions, or very long descriptions.
Can you check for any errors that mention 'ce56af2e-7658-41a0-9744-40b42f86069f' in them earlier in the file, or post back the whole error file?
Aaron
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Community Member
Hi Aaron,
thx for your quick response, in attached the whole warning file
just for info, i already correct some errors due to some special caracters in CallSeachSpaces and CSSs errors were eliminated.
the warning in the log file remain insolved, if i have to change some decription with special caracters, i don't where to modified them.
thx u for your help,
300
