Problems after 4.1(3) to 5.0 migration
I had a 4.1(3) cluster working so good. I created a demo environment and did the migration to 5.0 throught DMA, etc.
After I have migrated the CCM to 5.0, I saw two distincts problems with Extension Mobility.
In the 7912, I can see the Services option in Menu and after I put the credentials, I get the error "Login Unsuccessful - [6] - Database Error".
In the 7940, when I click in Services Button, I get the error "HTTP 404 error".
When I use the IP Communicator, all works fine, the Services and the Extension Mobility login.
Can anyone help me?
Tks
1 REPLY
Re: Problems after 4.1(3) to 5.0 migration
Did you check the port number in the TOMCAT folder for the file I believe NMDV.server something like that as I had this issue with 4.1.2 and once I change the port number in that file from 8009 to 8010 it solved the problem.
110
