Community Member
Problems creating Voice applications on Cisco 2851
Hello everyone, i'm having some issues when loading a voice application on our 2851 (IOS 151-3.T4).
I've made an application that loads multiple scripts depending on some schedules. When i have to load multiple applications at the same time i encounter the following issue:
My program opens 2 sockets, for each of them loads a service application specifying the parameters for each application. when i use the show run command i find some of the parameter specified in the first application to be under the second one (and missing from the first one) is there any workaround for this problem? Is easy to reproduce it by opening 2 telenet session, start the configuration of 2 applications, when you write some parameter in the first declared application, if you look under the show run you find these parameter under the other application.
Thank you in advance.
Alessandro.
Everyone's tags (5)
1 REPLY
Hall of Fame Super Gold
Routers are supposed to be configured by only one session, not multiple ones.
209
