Problems dialing internationally
I have CME 4.2, we have two ways to dial internationally at our Japan site. one starts with 004 and the other starts with 001. The 004 works perfect. The 001 FAILS. BOth are hitting the 131 dial peer.
I need to know if this is a telco issue or if my config is having the problem. Attached is the config. Your assistance is appreciated.
Here is a debug isdn q931 and debug voip dialpeer
1st debug shows the 004101017164391083 work successfully.
2nd debug shows the 001101017164391083 FAIL.
1 REPLY
Re: Problems dialing internationally
i'm not familiar with the Japan dial plan but at least this shows the telco is disconnecting:
Jan 29 06:20:58.706: ISDN Se0/0/1:23 Q931: TX -> SETUP pd = 8 callref = 0x0096
Sending Complete
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98397
Exclusive, Channel 23
Called Party Number i = 0x80, '001101017164391083'
Plan:Unknown, Type:Unknown
Jan 29 06:20:58.842: ISDN Se0/0/1:23 Q931: RX <- CALL_PROC pd = 8 callref = 0x8096
Jan 29 06:20:59.482: ISDN Se0/0/1:23 Q931: RX <- DISCONNECT pd = 8 callref = 0x8096
Cause i = 0x879C - Invalid number format (incomplete number)
Progress Ind i = 0x8288 - In-band info or appropriate now available
TX -> transmit
RX -> receive
is this really how telco expects the call??
EDIT: found this related:
Invalid number format (address incomplete). This can happen when you are calling out using a network type number (enterprise) when you should be calling out Unknown or National.
java
if this helps, please rate
java
www.cisco.com/go/pdi
417
