Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Problems dialling out from VG248 FXS
I am having problems with Analogue lines dialling out via FXS ports on a VG248
If the user dials an internal 4 digit extn number it connects ok as shown in the capture below
#term mon
*Mar 6 03:17:41.541: htsp_digit_ready(2/10): digit = 5
*Mar 6 03:17:41.849: htsp_digit_ready(2/10): digit = 4
*Mar 6 03:17:42.229: htsp_digit_ready(2/10): digit = 4
*Mar 6 03:17:42.429: htsp_digit_ready(2/10): digit = 7
*Mar 6 03:17:42.445: htsp_call_bridged invoked
*Mar 6 03:17:42.445: htsp_process_event: [2/10, FXSLS_CONNECT, E_HTSP_VOICE_CUT
_THROUGH]
1#
#htsp_call_feature:feature 6
However if they attempt to make a call over the PSTN, going via an ISDN gateway we get the following response and the call fails
*Mar 6 03:18:17.545: htsp_digit_ready(2/10): digit = 9
*Mar 6 03:18:20.185: htsp_digit_ready(2/10): digit = 0
*Mar 6 03:18:22.477: htsp_digit_ready(2/10): digit = 2
*Mar 6 03:18:24.141: [2/10] c2400_report_sig_state: ABCD = 0x4
*Mar 6 03:18:24.141: port 10 changed state new state = 4
*Mar 6 03:18:24.141: htsp_process_event: [2/10, FXSLS_CONNECT, E_DSP_SIG_0100]f
xsls_offhook_onhook, HF duration Max=1000, HF duration Min=150
*Mar 6 03:18:24.141: htsp_timer - 1000 msec
*Mar 6 03:18:25.141: htsp_process_event: [2/10, FXSLS_CONNECT, E_HTSP_EVENT_TIM
ER]fxsls_connect_wait_release_req
*Mar 6 03:18:25.141: htsp_timer_stop
*Mar 6 03:18:25.141: htsp_timer_stop3
*Mar 6 03:18:25.141: htsp_process_event: [2/10, FXSLS_WAIT_RELEASE_REQ, E_HTSP_
RELEASE_REQ]fxsls_waitrls_req_rls
*Mar 6 03:18:25.141: [2/10] c2400_set_sig_state: ABCD=4, timestamp=0, sys_time=
44390517
I have searched google and CCO but can find no reference to c2400_report_sig_state: ABCD = 0x4 ec.
Can anyone see what is happening and why ?
this is with MGCP and CCM 4.2.3
I have checked partitions/CSS etc and can see nothing wrong.
Users on IP Phones and VG224 gateways can dial all numbers ok.
Any ideas ?
1 REPLY
Silver
Re: Problems dialling out from VG248 FXS
This definately sounds like a partition/css issue. I would try making a special route pattern in the partition which is a 9.@ route pattern allowed out your gateway and remove all CSS assigned to the vg248 ports.
If this works, then it's a CSS issue and you can concentrate there.
I don't see why you wouldn't be able to make a call from a VG248 out an ISDN link.
You can also look at the trace files on the callmanager.
Lelio
203
