11-28-2011 06:08 PM - edited 03-16-2019 08:16 AM
Hi friends of Netpro!
I am trying to install the CUCM version 7 in a UCS c210m2 Server running ESXi 5.0 (only for study purposes), but I am having trouble with the installation,
in the display of the virtual machine I get the error that I attached in a picture.
I appreciate your help and collaboration.
11-28-2011 06:38 PM
Study what???ESXi 5??? or CUCM??? if the later avoid yourself problems and do this on ESXi 4.1
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
11-29-2011 01:28 AM
Ricardo,
First of all, no earlier versions than CUCM 8.0.2 are supported on UCS. http://docwiki.cisco.com/wiki/Unified_Communications_Virtualization_Supported_Applications
Also, as of now , UC over UCS is supported only with ESXi 4.1 ( not yet with ESXI 5.0. )
Please rate helpful posts.
GP.
11-29-2011 08:01 AM
Thank you very much for your comments and help GP.
11-29-2011 09:09 PM
Not a problem Ric. Thanks for the rating.
Cheers !!
GP
