Problems installing CUCM 7.0
I'm trying to install CUCM 7.0 in a raw HP Proliant G6 with five 500GB SCSI hard disks and 32 GB RAM.
After booting with the distribution DVD and after answering the question about existing RAID, the process aborts saying "No devices found".
Please help...
H. Miranda
Red
Re: Problems installing CUCM 7.0
CUCM has specific hardware requirements.  You can't just throw it on to any machine.
See: http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_device_support_tables_list.html
Michael
http://htluo.blogspot.com
I don't see that server as supported for 7.0
Supported Cisco Unified Communications Manager  Releases by Server
http://www.cisco.com/en/US/partner/prod/collateral/voicesw/ps6790/ps5748/ps378/prod_brochure0900aecd8062a4f9.html
Also you need to match the specs here:
HP Server Solutions
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/ps5748/ps378/product_solution_overview09186a0080107d79.html
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
188
