Problems integration with Nortel PBX through sip trunk, uri not recognized "phone-context=SIP_cdp.SIP_udp"
Dear colleagues,
the diagram shows below are originated because a problem with a integration between two PBX, Nortel and Broadsoft through sip trunk, the Nortel PBX forward the uri with the next format:
From: <sip:1607;phone-context=SIP_cdp.SIP_udp@sip.nextel.nextel.cl;user=phone>
But the Broadsoft can´t recongnize the "phone-context=SIP_cdp.SIP_udp", because this we put in the middle a Asterisk PBX, like a bypass, but with the same results, the Asterisk can recognize the "phonecontext=SIP_cdp.SIP_udp" and the call can´t perform.
Nortel says we cannot modify the uri, and Broadsoft says the platform can´t reconize this uri, for all this is the solution with gateways, Colleagues think that can be done the solution shows below?
Dear colleagues, is possible perform this comunication to fix this problem:
Phone(1607)------Nortel<------sip----->gwA<-----------h323----------->gwB<------sip------>Broadsoft------Phone(26861168)
voice     service voip voice service voip
allow-connections h323 to sip
allow-connections sip to h323
h323
sip
voice     class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729r8
codec preference 4 g729br8
dial-peer voice 1 voip
description     entrada de llamados desde NORTEL
voice-class codec 1
session protocol sipv2
session target sip-server
session transport udp
incoming called-number 2T
dial-peer     voice 2 voip
description hacia GW h323
service session
destination-pattern 2T
voice-class codec 1
session target ipv4:2.2.2.2(IP Gateway B)
sip-ua
sip-server ipv4:1.1.1.1(IP server Nortel)
voice     service voip
h323
sip
voice     class codec 1
description llamadas desde GW h323
service session
incoming called-number 26xxxxxx
voice-class codec 1
description llamadas hacia BroadsoftPBX
voice-class codec 1
destination-pattern 26xxxxxx
sip-ua
sip-server ipv4:3.3.3.3(IP server     Broadsoft)
Everyone's tags (3)
1 REPLY
why h323 between gwA and gwB ? make SIP
otherwise you need cube
588
