Problems to register 69XX phones on CUCM
Hi all,
On this Branch we are having problems to register 69XX phones through a 512kbps frame relay link to HQ. Phones 79XX registers normally.  We know the problem is QOS, because without our QOS configuration the 69XX phones register normally. Anyone can see the problem through this QOS configuration??
class-map match-any VoIP
match access-group name VOIP
match dscp ef
class-map match-any Gold
match access-group 111
match dscp af31
policy-map LINK
class VoIP_IN
priority 154
police cir 154000
   conform-action set-dscp-transmit ef
   exceed-action drop
class Gold_IN
bandwidth 282
police cir 512000
   conform-action set-dscp-transmit af31
   exceed-action drop
class class-default
fair-queue
random-detect
interface Serial0/0
no ip address
max-reserved-bandwidth 90
encapsulation frame-relay IETF
frame-relay traffic-shaping
frame-relay lmi-type q933a
interface Serial0/0.201 point-to-point
ip address 200.10.10.10 255.255.255.252
frame-relay interface-dlci 111 CISCO
class FRAME_512
frame-relay ip rtp header-compression
ip access-list extended VOIP
permit ip 10.1.1.0 0.0.0.255 any
map-class frame-relay FRAME_512
frame-relay cir 512000
frame-relay bc 5120
frame-relay be 0
frame-relay mincir 512000
frame-relay fragment 640
service-policy output LINK
logging trap debugging
access-list 111 permit tcp any any range 2000 2002
access-list 111 permit tcp any range 2000 2002 any
Thanks a lot!!
are your 69xx configured to use sip? (because acl 111 'catches' sccp)
Please remember to rate useful posts, by clicking on the stars below.
No, It is SCCP.
519
