problems to send/receive Fax with FXS
I have UCM6.1 cluster in main office, in remote side I have around 60 IP phones.
I can dial between remote site and main office with FXS port, I can receive and send faxes between phones located in remote side but I can not send and received between main office and remote side and from PSTN
how can I solve this issue??
regards,
I have 8FXs port in a 2821.
Re: problems to send/receive Fax with FXS
Try adding these commands:
remote:
voice service voip
fax protocol none
modem passthrough nse codec g711ulaw
voice-port 0/0
input gain -5
output attenuation 3
main office:
voice service voip
fax protocol none
network-clock-select 1 t1 0/0/0
-nick
Hi nick,
thanks a lot for your tips
I still have problems when I try sending
fax in remote side.
my current configuration in main office of voice E1s is the next:
network-clock-participate wic 2
controller E1 0/2/0
framing NO-CRC4
clock source internal
ds0-group 1 timeslots 1-15,17-31 type r2-digital r2-compelled ani
cas-custom 1
country telmex
category 2
answer-signal group-b 1
caller-digits 4
groupa-callerid-end
controller E1 0/2/1
framing NO-CRC4
cas-custom 1
country telmex
category 2
caller-digits 4
groupa-callerid-end
remote
voice-port 0/0/0
input gain -5
cptone MX
description fxs Fax1236
voice-port 0/0/1
input gain -5
cptone MX
description fxs Fax1237
dial-peer voice 10 pots
destination-pattern 1236
port 0/0/0
dial-peer voice 11 pots
destination-pattern 1237
port 0/0/1
dial-peer voice 103 voip
destination-pattern 9[1-9].......
session target ipv4:161.61.210.1 ---->CM
dtmf-relay h245-alphanumeric
codec g711ulaw
ip qos dscp cs5 media
no vad
try
network-clock-select e1 0/2/0
204
