Problems with 911
When users dial 9911 calls are being routed to a cell phone. This only happens at certain sites, could this be something with the gateways? Any help is appreciated. Thanks in advance
1 REPLY
Re: Problems with 911
Check the route plan report and see if there are any route. If you are using H323 gateways check Dial-peers
91
