Problems with a T1 CAS back-to-back configuration with fxs port
Hi everybody!
I'm looking to acquire knowledge in IP telephony and VoIP. I'm testing some configuration back to back and I have some problems with a T1 CAS link.
Here is my situation:
On each side, I have two analog phones connected to a 2811 router. The routers are connected by a T1 CAS link (with a T1 crossover cable).
I can call a local number, but when I try to reach the remote phone, I get only one ring tone in the local phone, but no ring on the remote phone.
I tried on a T1-PRI connection and I have not problem.
The problem is that I do not do the commands "debug cas" on my router (the command is not present)
There is my configuration:
!! CME Router 1
network-clock-participate wic 2
isdn switch-type primary-ni
controller T1 0/2/1
framing esf
clock source line
linecode b8zs
mode cas
ds0-group 1 timeslots 1 type fxo-ground-start          <- I'm not sure about this type on each router
no shut
voice-port 0/3/0
signal groundStart
description 5000
station-id number 5001
no shut
voice-port 0/3/1
signal groundStart
description 5001
no shut
dial-peer voice 5000 pots
destination-pattern 5000
port 0/3/1
dial-peer voice 5001 pots
destination-pattern 5001
port 0/3/0
dial-peer voice 6000 pots
destination-pattern 6000
incoming called-number 500
direct-inward-dial
port 0/2/1:23
forward-digits all
dial-peer voice 6001 pots
destination-pattern 6001
direct-inward-dial
port 0/2/1:23
forward-digits all
end
!!  CME Router 2
network-clock-participate wic 1
controller T1 0/1/1
framing esf
clock source internal
linecode b8zs
mode cas
ds0-group 0 timeslots 1 type fxo-ground-start
no shut
voice-port 0/3/0
signal groundStart
description 6000
station-id number 6000
no shut
voice-port 0/3/1
signal groundStart
description 6001
station-id number 6001
no shut
port 0/3/0
port 0/3/1
incoming called-number 600
direct-inward-dial
port 0/1/1:23
forward-digits all
direct-inward-dial
port 0/1/1:23
forward-digits all
end
Thanks to read me, if you have any comments or help, don't hesitate!
Christophe
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Cannot connect fxo to fxo. One side must be fxs.
Thanks for your help Paolo,
This is so logical! I've think about this when i wrote this message...
I'm back on tuesday.
I'll try with one side fxo and fxs to the other!
thanks a lot
169
