Problems with CallManager and LDAP
I'm using CallManager 7.0 with LDAP
The LDAP configuration is correct and the CCM get 693 users. But using LDAP server browser with same user, pass and LDAP User Search, I can see 2000+ users. The customers don't known why and the AD administrator too. How can I proof to customers that the LDAP configuration is correct? Someone suspected of something?
Required Field: username
Required Field: XXXX
Required Field: DC=xxxx,DC=yyyy
Peterson
1 REPLY
Super Bronze
Re: Problems with CallManager and LDAP
Firstly, CCM will only look in and under the top level 'seach base' you define.
It will then only sync objects of type 'user' - it will also not sync any users that are disabled.
In order to get into the CCM DB, the mandatory attributes are userid, and lastname - so the fields these map to in AD (for example, sAMAccountName and sn) must be populated.
Finally, the field chosen for the userID must be unique for each record. If you use sAMAccountName, then it will be.
If you use another field - such as telephoneNumber - there is no guarantee that each user is unique, so not all users will sync in if multiple users have the same number (for example a switchboard number).
Aaron
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
294
