Problems with CIPC registration - Host not Found
Hi all:
I'm having problems with my CIPC 7.0.2. I was using it on my CCM, as usual, but then I needed to change it to another CCM for testing. I had to erase config from CIPC. Once I came back to my CCM, it registers, but it does not take all the configurations (for instance, does not show ringtones, backgrounds other than default one, Corporate Directory, etc.) I have uninstalled several times, delete all registry keys, but it is still happening!!
As of now, I have uninstalled 7.0.2 and installed 2.1.4, and now I get a "host not found" everytime I click on "Services", "Directories", etc.
Help?
1 REPLY
Re: Problems with CIPC registration - Host not Found
Did you found a solution? I have a similar issue, I
can change between different CCMs but as soon I try to go the CCME it does no
t register, but goes always back to the last CCM.  Ona fre
sh computer, I have no issue to register to a CCME with the same config.
Martin
316
