Problems with cisco AS5300 GW (restart itself)
I Have 8 AS5300 GW what they works together in a prepaid calling cards plataform, and they works fine.
Sometimes one of they, begin with a memory trouble (ie. I can?t add a dial-peer, I receive the message "could not add peer") Them the AS5300 is trasformed in an inestable system, sometimes restart itself.
I look in another AS5300, and mayor of values of config are equals.
I can see what when I send "show call history voice brief" command in AS5300 with troubles the result is a list of a 500 records, and when I send the command in another AS5300 I see, only 50 records, can be the trouble it??
I want to know what command I use to modify the number of records of calls that display when I send the command "show call history voice brief"
regards
Ariel
  • IP Telephony
Green
Re: Problems with cisco AS5300 GW (restart itself)
I would open a TAC Case on this one for further investigation.
Hall of Fame Super Gold
Even before opening the case, check your 5300 are running the latest maintenance of choosen IOS version.
142
