Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Problems with CUCM 6.0
Good afternoon. There was a problem of the following plan: At installation CUCM 6.0 " the corporate catalogue " and services on all phones 7940, 7960 does not work. On CUCM 6.0 services for each phone are registered, but phone answers, that " the host is not found " and the same message stands out at viewing " the corporate catalogue ". And on IP Communicator all works (and " the corporate catalogue " and services). The fresh insertion of phone has not helped. Prompt as well as where to correct. Thanks.
Bronze
Re: Problems with CUCM 6.0
For IP phone services, the "Host not found" error usually comes when name is used instead of IP address or unreachability.
Please find the following links which may help...
http://www.cisco.com/univercd/cc/td/doc/product/voice/assist/assist2/prod_ser/user_gd/user04.htm#xtocid21816
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a008009463f.shtml
Regards...
-Ashok.
With best regards... Ashok ----------- Pls kindly rate if helpful or answered your question.
Thanks. Works!!!
VIP Super Bronze
Bden,
ALways remember to rate post that are helpful especially one that resolves your issues. It encourages the person who helped you and it also provide good reference for others who emay experience similar issue as you did
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
111
