Problems with CUE AA to CME extension.
mikeh
     I am running into an issue with my CME/CUE configuration where whenever a caller tries dialing an extension during the AA announcement (or from the dial by extension menu option), they get a message (I'm guessing from CUE) that the subscriber they are trying to reach is not available, and the system drops the call.  Whenever you dial the AA DN from an internal extension, using the AA to dial an extension works fine.
     This was working fine since I setup the system, but in the last few days has stopped working.  After taking a look at the ccsip messages, it appears that CUE is transferring to CME with a called-id of the main DID instead of the extension selected by the caller.  Our PSTN link is some SIP trunks (Nextiva).  Any ideas on where to go with this next will be greatly appreciated.
ccsip messages for a call coming off of the Nextiva SIP trunks through CUE, and dialing an extension (1103).
hlsm-2821#
Jul 24 19:26:40.823: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
REGISTER sip:trunking.voipdnsservers.com:5060 SIP/2.0
Via: SIP/2.0/UDP 10.1.10.12:5060;branch=z9hG4bK8A4BC5
From: <sip:xxxxxxxxx@trunking.voipdnsservers.com>;tag=4987AC8-25EE
To: <sip:xxxxxxxxx@trunking.voipdnsservers.com>
Date: Wed, 24 Jul 2013 19:26:40 GMT
Call-ID: 5AD392DA-F31E11E2-8002FDEF-396CC98A
User-Agent: Cisco-SIPGateway/IOS-12.x
Max-Forwards: 70
Timestamp: 1374694000
CSeq: 1326 REGISTER
Contact: <sip:xxxxxxxxx@10.1.10.12:5060>
Expires:  3600
Supported: path
Content-Length: 0
Jul 24 19:26:40.927: //2396/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 10.1.10.12:5060;received=23.31.253.222;branch=z9hG4bK8A4BC5;rport=63328
To: <sip:xxxxxxxxx@trunking.voipdnsservers.com>;tag=aprqhje8503-j2bd9k10081s2
CSeq: 1326 REGISTER
Contact: <sip:xxxxxxxxx@10.1.10.12:5060>;expires=46
Jul 24 19:26:44.207: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:xxxxxxxxx@10.1.10.12:5060 SIP/2.0
Via: SIP/2.0/UDP 208.73.146.xx:5060;branch=z9hG4bKi25tco10e800vntfg0i0.1
Accept: application/sdp, application/isup, application/dtmf, application/dtmf-relay,  multipart/mixed
Call-Id: pcst13746940041508191241310@192.168.201.118
Contact: <sip:xxxxxxxxxx@208.73.146.xx:5060;transport=udp>
Content-Disposition: session; handling=required
Content-Length: 238
Content-Type: application/sdp
CSeq: 1 INVITE
From: "WIRELESS CALLER"  <sip:xxxxxxxxxx@192.168.101.118:5060;otg=TG_CORE_GSX;pstn-params=808482808882>;tag=gK0911fe0e
In-Reply-To: 436809728_8630707@207.155.147.62
Session-Expires: 1800;refresher=uas
Supported: timer
To: <sip:5702665351@192.168.101.100>
Max-Forwards: 70
v=0
o=Sonus_UAC 32325 22772 IN IP4 208.73.146.xx
s=SIP Media Capabilities
c=IN IP4 208.73.146.xx
t=0 0
m=audio 32234 RTP/AVP 0 101
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=sendrecv
a=maxptime:20
Jul 24 19:26:44.219: //2397/CF0C4FE48A6C/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Wed, 24 Jul 2013 19:26:44 GMT
Call-ID: pcst13746940041508191241310@192.168.201.118
CSeq: 1 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
Jul 24 19:26:44.231: //2398/CF0C4FE48A6C/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:1191@172.20.100.20:5060 SIP/2.0
Via: SIP/2.0/UDP 172.20.100.10:5060;branch=z9hG4bK8A556C
From: "WIRELESS CALLER" <sip:xxxxxxxxxx@trunking.voipdnsservers.com>;tag=4988818-EFE
To: <sip:1191@172.20.100.20>
Call-ID: CF0F5D44-F3CD11E2-8A72FDEF-396CC98A@172.20.100.10
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 3473690596-4090302946-2322398703-0963430794
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1374694004
Contact: <sip:xxxxxxxxxx@172.20.100.10:5060>
Call-Info: <sip:172.20.100.10:5060>;method="NOTIFY;Event=telephone-event;Duration=2000"
Expires: 180
Max-Forwards: 69
Content-Disposition: session;handling=required
Content-Length: 193
v=0
o=CiscoSystemsSIP-GW-UserAgent 9413 868 IN IP4 172.20.100.10
s=SIP Call
c=IN IP4 172.20.100.10
t=0 0
m=audio 17280 RTP/AVP 0
a=ptime:20
Jul 24 19:26:44.259: //2398/CF0C4FE48A6C/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <sip:1191@172.20.100.20>;tag=cue26a9e987
CSeq: 101 INVITE
Content-Length: 0
Contact: <sip:1191@172.20.100.20:5060>
Jul 24 19:26:44.303: //2398/CF0C4FE48A6C/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
CSeq: 101 INVITE
Content-Length: 0
Jul 24 19:26:44.307: //2397/CF0C4FE48A6C/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
To: <sip:5702665351@192.168.101.100>;tag=4988864-3B7
CSeq: 1 INVITE
Contact: <sip:1191@10.1.10.12:5060>
Content-Length: 0
Jul 24 19:26:44.431: //2398/CF0C4FE48A6C/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 INVITE
Content-Length: 180
Call-Info: <sip:172.20.100.20:5060>;method="NOTIFY;Event=telephone-event;Duration=2000"
v=0
o=CiscoSystemsSIP-Workflow-App-UserAgent 1740 1740 IN IP4 172.20.100.20
s=SIP Call
c=IN IP4 172.20.100.20
t=0 0
m=audio 16908 RTP/AVP 0
a=rtpmap:0 pcmu/8000
a=ptime:20
Jul 24 19:26:44.439: //2398/CF0C4FE48A6C/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:1191@172.20.100.20:5060 SIP/2.0
Via: SIP/2.0/UDP 172.20.100.10:5060;branch=z9hG4bK8A647C
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Jul 24 19:26:44.447: //2397/CF0C4FE48A6C/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 1 INVITE
Supported: replaces
Supported: sdp-anat
Supported: timer
Content-Length: 241
v=0
o=CiscoSystemsSIP-GW-UserAgent 4827 3500 IN IP4 10.1.10.12
s=SIP Call
c=IN IP4 10.1.10.12
t=0 0
m=audio 19008 RTP/AVP 0 101
c=IN IP4 10.1.10.12
a=fmtp:101 0-16
a=ptime:20
Jul 24 19:26:44.547: //2397/CF0C4FE48A6C/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 1 INVITE
Supported: replaces
Supported: sdp-anat
Supported: timer
Content-Length: 241
v=0
s=SIP Call
c=IN IP4 10.1.10.12
t=0 0
c=IN IP4 10.1.10.12
a=fmtp:101 0-16
a=ptime:20
Jul 24 19:26:44.599: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:xxxxxxxxx@10.1.10.12:5060 SIP/2.0
Via: SIP/2.0/UDP 208.73.146.xx:5060;branch=z9hG4bKjr5gsu004gg1cqpml370.1
Content-Length: 0
CSeq: 1 ACK
Max-Forwards: 70
Jul 24 19:26:44.643: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Content-Length: 0
CSeq: 1 ACK
Max-Forwards: 70
Jul 24 19:26:49.103: //-1/xxxxxxxxxxxx/SIP/Msg/sipDisplayBinaryData:
Sending: Binary Message Body
Jul 24 19:26:49.103: Content-Type: audio/telephone-event
01 00 07 D0
Jul 24 19:26:49.107: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
NOTIFY sip:1191@172.20.100.20:5060 SIP/2.0
Via: SIP/2.0/UDP 172.20.100.10:5060;branch=z9hG4bK8A7C1F
CSeq: 102 NOTIFY
Max-Forwards: 70
Date: Wed, 24 Jul 2013 19:26:49 GMT
Event: telephone-event
Subscription-State: active
Contact: <sip:172.20.100.10:5060>
Content-Length: 4
.P
Jul 24 19:26:49.119: //0/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 102 NOTIFY
Content-Length: 0
Allow-Events: refer
Allow-Events: message-summary
Jul 24 19:26:49.183: //-1/xxxxxxxxxxxx/SIP/Msg/sipDisplayBinaryData:
Jul 24 19:26:49.183: Content-Type: audio/telephone-event
01 80 00 50
Jul 24 19:26:49.187: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 172.20.100.10:5060;branch=z9hG4bK8A81C08
CSeq: 103 NOTIFY
Max-Forwards: 70
Content-Length: 4
.P
Jul 24 19:26:49.199: //0/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 103 NOTIFY
Content-Length: 0
Allow-Events: refer
Jul 24 19:26:50.023: //-1/xxxxxxxxxxxx/SIP/Msg/sipDisplayBinaryData:
Jul 24 19:26:50.023: Content-Type: audio/telephone-event
01 00 07 D0
Jul 24 19:26:50.027: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 172.20.100.10:5060;branch=z9hG4bK8A913D3
CSeq: 104 NOTIFY
Max-Forwards: 70
Date: Wed, 24 Jul 2013 19:26:50 GMT
Content-Length: 4
.P
Jul 24 19:26:50.039: //0/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 104 NOTIFY
Content-Length: 0
Allow-Events: refer
Jul 24 19:26:50.103: //-1/xxxxxxxxxxxx/SIP/Msg/sipDisplayBinaryData:
Jul 24 19:26:50.103: Content-Type: audio/telephone-event
01 80 00 50
Jul 24 19:26:50.107: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 172.20.100.10:5060;branch=z9hG4bK8AAA03
CSeq: 105 NOTIFY
Max-Forwards: 70
Content-Length: 4
.P
Jul 24 19:26:50.119: //0/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 105 NOTIFY
Content-Length: 0
Allow-Events: refer
Jul 24 19:26:50.623: //-1/xxxxxxxxxxxx/SIP/Msg/sipDisplayBinaryData:
Jul 24 19:26:50.623: Content-Type: audio/telephone-event
00 00 07 D0
Jul 24 19:26:50.627: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 172.20.100.10:5060;branch=z9hG4bK8ABB06
CSeq: 106 NOTIFY
Max-Forwards: 70
Content-Length: 4
..P
Jul 24 19:26:50.639: //0/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 106 NOTIFY
Content-Length: 0
Allow-Events: refer
Jul 24 19:26:50.703: //-1/xxxxxxxxxxxx/SIP/Msg/sipDisplayBinaryData:
Jul 24 19:26:50.703: Content-Type: audio/telephone-event
00 80 00 50
Jul 24 19:26:50.707: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 172.20.100.10:5060;branch=z9hG4bK8AC2068
CSeq: 107 NOTIFY
Max-Forwards: 70
Content-Length: 4
..P
Jul 24 19:26:50.719: //0/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 107 NOTIFY
Content-Length: 0
Allow-Events: refer
Jul 24 19:26:51.223: //-1/xxxxxxxxxxxx/SIP/Msg/sipDisplayBinaryData:
Jul 24 19:26:51.223: Content-Type: audio/telephone-event
03 00 07 D0
Jul 24 19:26:51.227: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 172.20.100.10:5060;branch=z9hG4bK8AD1E73
CSeq: 108 NOTIFY
Max-Forwards: 70
Date: Wed, 24 Jul 2013 19:26:51 GMT
Content-Length: 4
.P
Jul 24 19:26:51.239: //0/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 108 NOTIFY
Content-Length: 0
Allow-Events: refer
Jul 24 19:26:51.303: //-1/xxxxxxxxxxxx/SIP/Msg/sipDisplayBinaryData:
Jul 24 19:26:51.303: Content-Type: audio/telephone-event
03 80 00 4B
Jul 24 19:26:51.307: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 172.20.100.10:5060;branch=z9hG4bK8AECE6
CSeq: 109 NOTIFY
Max-Forwards: 70
Content-Length: 4
.K
Jul 24 19:26:51.319: //0/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 109 NOTIFY
Content-Length: 0
Allow-Events: refer
Jul 24 19:26:57.343: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:xxxxxxxxxx@172.20.100.10:5060 SIP/2.0
Via: SIP/2.0/UDP 172.20.100.20:5060;branch=z9hG4bKaVwKPXymH1TKCGaU2g7LNg~~166
Max-Forwards: 70
To: <sip:xxxxxxxxxx@trunking.voipdnsservers.com>;tag=4988818-EFE
CSeq: 1 BYE
Content-Length: 0
Also: <sip:1103@172.20.100.10:5060;user=phone>
Jul 24 19:26:57.343: //2398/CF0C4FE48A6C/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: "WIRELESS CALLER" <sip:xxxxxxxxxx@trunking.voipdnsservers.com>;tag=4988818-EFE
Date: Wed, 24 Jul 2013 19:26:57 GMT
CSeq: 1 BYE
P-RTP-Stat: PS=681,OS=102096,PR=430,OR=68323,PL=0,JI=0,LA=0,DU=12
Content-Length: 0
Jul 24 19:26:57.351: //2397/CF0C4FE48A6C/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:xxxxxxxxxx@208.73.146.xx:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 10.1.10.12:5060;branch=z9hG4bK8AF1BEB
From: <sip:5702665351@192.168.101.100>;tag=4988864-3B7
To: "WIRELESS CALLER"  <sip:xxxxxxxxxx@192.168.101.118:5060;otg=TG_CORE_GSX;pstn-params=808482808882>;tag=gK0911fe0e
Min-SE:  1800
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1374694017
Expires: 180
Content-Length: 253
v=0
o=CiscoSystemsSIP-GW-UserAgent 4827 3501 IN IP4 10.1.10.12
s=SIP Call
c=IN IP4 10.1.10.12
t=0 0
c=IN IP4 10.1.10.12
a=fmtp:101 0-16
a=ptime:20
a=sendonly
Jul 24 19:26:57.579: //2397/CF0C4FE48A6C/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 10.1.10.12:5060;received=23.31.253.222;branch=z9hG4bK8AF1BEB;rport=63328
CSeq: 101 INVITE
Content-Length: 238
v=0
o=Sonus_UAC 32325 22773 IN IP4 208.73.146.xx
t=0 0
a=fmtp:101 0-15
a=recvonly
a=maxptime:20
Jul 24 19:26:57.587: //2397/CF0C4FE48A6C/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:xxxxxxxxxx@208.73.146.xx:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 10.1.10.12:5060;branch=z9hG4bK8B020A0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Jul 24 19:26:57.587: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
REFER sip:xxxxxxxxxx@208.73.146.xx:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 10.1.10.12:5060;branch=z9hG4bK8B1AB9
CSeq: 102 REFER
Max-Forwards: 70
Refer-To: sip:1103@10.1.10.12
Referred-By: <sip:xxxxxxxxx@trunking.voipdnsservers.com>
Content-Length: 0
Jul 24 19:26:57.727: //0/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 202 Accepted
Via: SIP/2.0/UDP 10.1.10.12:5060;received=23.31.253.222;branch=z9hG4bK8B1AB9;rport=63328
CSeq: 102 REFER
Content-Length: 0
Jul 24 19:26:57.731: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
NOTIFY sip:xxxxxxxxx@10.1.10.12:5060 SIP/2.0
Via: SIP/2.0/UDP 208.73.146.xx:5060;branch=z9hG4bKjr5gsu004gg1cqpml370ck0000g10.1
Content-Length: 20
Content-Type: message/sipfrag
CSeq: 3 NOTIFY
Event: refer
Subscription-State: active;expires=3600
Max-Forwards: 70
SIP/2.0 100 Trying
Jul 24 19:26:58.071: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 208.73.146.xx:5060;branch=z9hG4bKjr5gsu004gg1cqpml370ck0000020.1
Content-Length: 22
CSeq: 4 NOTIFY
Event: refer
Subscription-State: terminated;reason=noresource
Max-Forwards: 70
SIP/2.0 404 Not Found
Jul 24 19:26:58.227: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Content-Length: 20
CSeq: 3 NOTIFY
Event: refer
Max-Forwards: 70
SIP/2.0 100 Trying
Jul 24 19:26:58.571: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Content-Length: 22
CSeq: 4 NOTIFY
Event: refer
Max-Forwards: 70
Jul 24 19:26:59.227: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Content-Length: 20
CSeq: 3 NOTIFY
Event: refer
Max-Forwards: 70
SIP/2.0 100 Trying
Jul 24 19:26:59.571: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Content-Length: 22
CSeq: 4 NOTIFY
Event: refer
Max-Forwards: 70
Jul 24 19:27:01.227: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Content-Length: 20
CSeq: 3 NOTIFY
Event: refer
Max-Forwards: 70
SIP/2.0 100 Trying
Jul 24 19:27:01.571: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Content-Length: 22
CSeq: 4 NOTIFY
Event: refer
Max-Forwards: 70
Jul 24 19:27:01.775: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:xxxxxxxxx@10.1.10.12:5060 SIP/2.0
Via: SIP/2.0/UDP 208.73.146.xx:5060;branch=z9hG4bKjr5gsu004gg1cqpml370cd0000030.1
Content-Length: 0
CSeq: 6 BYE
Max-Forwards: 70
Jul 24 19:27:01.783: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
no deSIP/2.0 200 OK
Date: Wed, 24 Jul 2013 19:27:01 GMT
CSeq: 6 BYE
Reason: Q.850;cause=16
P-RTP-Stat: PS=430,OS=68323,PR=682,OR=102256,PL=0,JI=0,LA=0,DU=17
Content-Length: 0
ccsip messages for a call to the AA from an internal extension, and dialing by extension from there.
Jul 24 19:31:55.492: //2415/87BF34368A86/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 172.20.100.10:5060;branch=z9hG4bK8D83CD
From: "Mike Hilty" <sip:1103@trunking.voipdnsservers.com>;tag=49D47EC-1F91
Date: Wed, 24 Jul 2013 19:31:55 GMT
Call-ID: 88956F6B-F3CE11E2-8A8BFDEF-396CC98A@172.20.100.10
Min-SE:  1800
Cisco-Guid: 2277454902-4090368482-2324102639-0963430794
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1374694315
Contact: <sip:1103@172.20.100.10:5060>
Expires: 180
Content-Length: 194
v=0
o=CiscoSystemsSIP-GW-UserAgent 8960 6838 IN IP4 172.20.100.10
s=SIP Call
t=0 0
m=audio 17210 RTP/AVP 0
a=ptime:20
Jul 24 19:31:55.512: //2415/87BF34368A86/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <sip:1191@172.20.100.20>;tag=cue626ca961
CSeq: 101 INVITE
Content-Length: 0
Jul 24 19:31:55.552: //2415/87BF34368A86/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
CSeq: 101 INVITE
Content-Length: 0
Jul 24 19:31:55.628: //2415/87BF34368A86/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 INVITE
Content-Length: 180
v=0
o=CiscoSystemsSIP-Workflow-App-UserAgent 1638 1638 IN IP4 172.20.100.20
s=SIP Call
t=0 0
m=audio 16900 RTP/AVP 0
a=ptime:20
Jul 24 19:31:55.644: //2415/87BF34368A86/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 172.20.100.10:5060;branch=z9hG4bK8D9143E
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Jul 24 19:31:57.748: //-1/xxxxxxxxxxxx/SIP/Msg/sipDisplayBinaryData:
Jul 24 19:31:57.748: Content-Type: audio/telephone-event
01 00 07 D0
Jul 24 19:31:57.748: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 172.20.100.10:5060;branch=z9hG4bK8DA103E
CSeq: 102 NOTIFY
Max-Forwards: 70
Date: Wed, 24 Jul 2013 19:31:57 GMT
Content-Length: 4
.P
Jul 24 19:31:57.760: //0/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 102 NOTIFY
Content-Length: 0
Allow-Events: refer
Jul 24 19:31:57.764: //-1/xxxxxxxxxxxx/SIP/Msg/sipDisplayBinaryData:
Jul 24 19:31:57.764: Content-Type: audio/telephone-event
01 80 00 64
Jul 24 19:31:57.764: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 172.20.100.10:5060;branch=z9hG4bK8DB14A9
CSeq: 103 NOTIFY
Max-Forwards: 70
Content-Length: 4
.d
Jul 24 19:31:57.780: //0/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 103 NOTIFY
Content-Length: 0
Allow-Events: refer
Jul 24 19:31:57.896: //-1/xxxxxxxxxxxx/SIP/Msg/sipDisplayBinaryData:
Jul 24 19:31:57.896: Content-Type: audio/telephone-event
01 00 07 D0
Jul 24 19:31:57.896: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 172.20.100.10:5060;branch=z9hG4bK8DC78F
CSeq: 104 NOTIFY
Max-Forwards: 70
Content-Length: 4
.P
Jul 24 19:31:57.912: //0/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 104 NOTIFY
Content-Length: 0
Allow-Events: refer
Jul 24 19:31:57.912: //-1/xxxxxxxxxxxx/SIP/Msg/sipDisplayBinaryData:
Jul 24 19:31:57.912: Content-Type: audio/telephone-event
01 80 00 64
Jul 24 19:31:57.912: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 172.20.100.10:5060;branch=z9hG4bK8DD300
CSeq: 105 NOTIFY
Max-Forwards: 70
Content-Length: 4
.d
Jul 24 19:31:57.928: //0/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 105 NOTIFY
Content-Length: 0
Allow-Events: refer
Jul 24 19:31:58.288: //-1/xxxxxxxxxxxx/SIP/Msg/sipDisplayBinaryData:
Jul 24 19:31:58.288: Content-Type: audio/telephone-event
00 00 07 D0
Jul 24 19:31:58.288: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 172.20.100.10:5060;branch=z9hG4bK8DE10B0
CSeq: 106 NOTIFY
Max-Forwards: 70
Date: Wed, 24 Jul 2013 19:31:58 GMT
Content-Length: 4
..P
Jul 24 19:31:58.300: //0/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 106 NOTIFY
Content-Length: 0
Allow-Events: refer
Jul 24 19:31:58.304: //-1/xxxxxxxxxxxx/SIP/Msg/sipDisplayBinaryData:
Jul 24 19:31:58.304: Content-Type: audio/telephone-event
00 80 00 64
Jul 24 19:31:58.304: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 172.20.100.10:5060;branch=z9hG4bK8DFFEB
CSeq: 107 NOTIFY
Max-Forwards: 70
Content-Length: 4
..d
Jul 24 19:31:58.316: //0/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 107 NOTIFY
Content-Length: 0
Allow-Events: refer
Jul 24 19:31:58.616: //-1/xxxxxxxxxxxx/SIP/Msg/sipDisplayBinaryData:
Jul 24 19:31:58.616: Content-Type: audio/telephone-event
03 00 07 D0
Jul 24 19:31:58.616: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 172.20.100.10:5060;branch=z9hG4bK8E02464
CSeq: 108 NOTIFY
Max-Forwards: 70
Content-Length: 4
.P
Jul 24 19:31:58.632: //0/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 108 NOTIFY
Content-Length: 0
Allow-Events: refer
Jul 24 19:31:58.632: //-1/xxxxxxxxxxxx/SIP/Msg/sipDisplayBinaryData:
Jul 24 19:31:58.632: Content-Type: audio/telephone-event
03 80 00 64
Jul 24 19:31:58.632: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 172.20.100.10:5060;branch=z9hG4bK8E11702
CSeq: 109 NOTIFY
Max-Forwards: 70
Content-Length: 4
.d
Jul 24 19:31:58.648: //0/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 109 NOTIFY
Content-Length: 0
Allow-Events: refer
Jul 24 19:32:04.712: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:1103@172.20.100.10:5060 SIP/2.0
Via: SIP/2.0/UDP 172.20.100.20:5060;branch=z9hG4bKaVwKPXymH1TKCGaU2g7LNg~~169
Max-Forwards: 70
To: <sip:1103@trunking.voipdnsservers.com>;tag=49D47EC-1F91
CSeq: 1 BYE
Content-Length: 0
Jul 24 19:32:04.712: //2415/87BF34368A86/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: "Mike Hilty" <sip:1103@trunking.voipdnsservers.com>;tag=49D47EC-1F91
Date: Wed, 24 Jul 2013 19:32:04 GMT
CSeq: 1 BYE
P-RTP-Stat: PS=450,OS=72000,PR=300,OR=47523,PL=0,JI=0,LA=0,DU=9
Content-Length: 0
5 Replies 5
mikeh
Also, not sure if this helps or not, but all of the phones are SCCP phones (7940's)
The router is a 2821 running c2800nm-adventerprisek9-mz.151-4.M4.bin
The CUE is a AIM-CUE running Unity Express 3.2.2
The software versions are what came on the hardware platforms.  I have not updated either (trying to get by without a service contract on this hardware)
Mike Hilty
mikeh
Turned out that adding "transfer-mode attended" under "ccn subsystem sip" on the NAM-CUE resolved this issue.  Not sure why this worked originally without this command, but now it is working properly.  Would like to understand why this is the case.
Another update:
Changing the transfer-mode in CUE gives different behavior depending on the setting:
transfer-mode attended:  Allows the caller to dial an extension in AA, and have it ring the extension.  However, when that extension rings through to voicemail, the caller hears the AA message where it would have been if they had just stayed on the line without a selection.  Caller is unable to leave a voicemail message for any ephone-dn's.
transfer-mode semi-attended:  Caller gets the AA prompts all over again after dailing an extension number.  AA script starts from the beginning
transfer-mode blind refer or bye-also:  Caller gets the recorded message "The subscriber you are trying to reach is unavailable, goodbye." then the call is dropped.
I am looking for a solution where the caller is able to dial by extension, and be able to leave a voicemail message for that extension.
paolo bevilacqua
You trace below show that caller entered 1103, but then an external call was attempted to xxx, since you hidden numbers one cannot tell what is what. Possibly 1103 had CFA set to that number.
Received:
Max-Forwards: 70
To: <>xxxxxxxxxx@trunking.voipdnsservers.com>;tag=4988818-EFE
CSeq: 1 BYE
Content-Length: 0
Contact: <1191>
Also: <1103>
Sent:
SIP/2.0 200 OK
To: "WIRELESS CALLER" <>xxxxxxxxxx@trunking.voipdnsservers.com>;tag=4988818-EFE
CSeq: 1 BYE
Content-Length: 0
Sent:
To: "WIRELESS CALLER"  ;tag=gK0911fe0e
Min-SE:  1800
CSeq: 101 INVITE
Max-Forwards: 70
Contact:
Expires: 180
Content-Length: 253
v=0
s=SIP Call
c=IN IP4 10.1.10.12
t=0 0
c=IN IP4 10.1.10.12
a=fmtp:101 0-16
a=ptime:20
a=sendonly
The issue turned out to be related to the dial-peer configuration.
I previously only had one outbound SIP dial-peer that had a destination-pattern of .T
I configured dial-peers for ten digit, eleven digit, and 911 calling along with the .T dial peer, and now I am able to dial by extension/name out of the CUE AA.
