Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Problems with database replication: Publisher vs subscriber ( CCM 6.1.2)
Hi all:
I was changing up the IP of mi CCM 6 cluster (publisher and a subscriber), but i see that doing that don't works wright, i decided to undo the changes that i done.
But now with the same configuration than before the publisher don't detects ok the subscriber.
In the subscriber i watch that the database is replicated but i watch it in my CM group both (publisher and subscriber).
I have the same parameters in my publisher.
But when via CLI in the publisher i perform an "show network cluster" it only appears my publisher and not my subscriber.
But in CLI doing the same instruction i obtain the publisher and ther subscriber.
What can i do?
How can i do to replicate correctly the database publisher in my subscriber.
Also when i execute "utils dbreplication status" in my publisher i obtain this response:
This command reads and writes database information from all machines and will take quite some time...please be patient.
-------------------- utils dbreplication status --------------------
Status cannot be performed when replication is down on the publisher, or on a cluster with a single active node; aborting replication status check operation
Output is in file cm/trace/dbl/sdi/ReplicationStatus.184115.out
admin:
Thanks in advance.
If you need more detail dont hesitate an Please tell me.
1 REPLY
VIP Super Bronze
Re: Problems with database replication: Publisher vs subscriber
Can you first of all check that the subscriber is still on your publisher...
Go to CCMadmin>system>server click on find.
Check to see that the subscriber is there and it has the correct ip address
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
186
