Problems with h323 trunk CME CUCM BE
Hi all,
I am configuring a trunk h323 between a CME 7,0 and a CUCM BE 6.1. The calls from the CUCM to the CME work's fine, but the calls from the CME that is turned aside to the voice mail, fails, the phone show the following error "number unknown".
The configuration of gateway h323 in the CUCM is configured a CCS that it has the partition of the numbers of the voice mail.
I have attached dial-peer config below.
dial-peer voice 1000 voip
destination-pattern 1...
session target ipv4:10.168.1.250
dtmf-relay h245-alphanumeric
codec g729br8
Any idea why so?
1 REPLY
Re: Problems with h323 trunk CME CUCM BE
this is when you dial the number or u press the message button ?
can you call any other number in CUCM?
153
