Community Member
Problems with incoming calls in a mobile PRI
Hello, we have a mobile PRI (Vodafone) connected to a H.323 gw (2821) in a CCM cluster scenario (version 5.1). When a external user calls the root number of the PRI followed of the internal extension, the call there should be stablished directly. The call isn't stablished between both phones, but the gateway establishes the connection through the PRI and waits ten seconds. If the caller dials the internal extension the call is stablished. If not, the call is rejected.
My config:
card type e1 0 0
controller E1 0/0/0
pri-group timeslots 1-31
interface Serial0/0/0:15
no ip address
isdn switch-type primary-net5
isdn overlap-receiving
isdn incoming-voice voice
isdn sending-complete
no keepalive
no cdp enable
voice-port 0/0/0:15
cptone ES
Thans. Best Regards.
2 ACCEPTED SOLUTIONS
Hall of Fame Super Gold
Re: Problems with incoming calls in a mobile PRI
Hola,
configure:
dial-peer voice 1 pots
incoming called-number .
direct-inward-dial
You must also make sure that the called number matches extensions, or use a translation rule.
Please rate post if it helps!
Hola,
yes it's DID. DID is when you are given the called extension, doesn't matter with how many digits.
Configure as indicated before and you will be fine.
As an appreciation to those providing answers, please rate useful posts with the scrollbox below!
Hola,
configure:
direct-inward-dial
Community Member
Hi Paolo, really it isn't a DID, because the Telco gives me only the extension. For example, if the root number is 666123456, the user dials 6661234561809, and the Telco gives me only 1809.
Attachment debug1 shows how the call gets disconnected when it shouldn't.
Attachment debug2 shows how the call gets through when I redial the extension (1800) again. That behaviour is not what it should be.
Regards.
Hola,
Community Member
Hola Paolo, you were right. I posted without really testing your advice. It's working fine now, thank you very much. You are uber!
Best regards.
De nada. Thanks for the appreciation and good luck!
Community Member
Hola Paolo, we have detected another problem: if we dial only the root number it sounds a continous tone, and during ten seconds we can dial an extension or an external phone (obviously we can't permit that). How could we block this calls?
Muchas gracias.
Please send output of "debug isdn q931" with "term mon" when you call the root number. I need to see what number, if any, is sent in this case.
159
