Problems with incoming dialpeer
I'm testing at the moment some dial-peers for Germany in my lab. One is to use a outgoing dial-peer without a 0 as destination-pattern. With them I have a couple of problems that the system is selecting the outgoing dialpeer also as incoming dialpeer at the ISDN interface. I have break down the problem in the lab to simple configuration where the issue appears.
Scenario is very simple. ISDN Interface 2/0 is conected to the service provider and to the CME is one phone on port 3/0 connected(number 20).
The config
voice translation-rule 1
rule 1 /^610268\(..\)/ /\1/
rule 2 /610268/ /20/
voice translation-profile ISDN
translate called 1
interface BRI2/0
no ip address
isdn switch-type basic-net3
isdn overlap-receiving T302 6000
isdn point-to-point-setup
isdn incoming-voice voice
isdn sending-complete
isdn static-tei 0
voice-port 2/0
compand-type a-law
cptone DE
timeouts interdigit 6
bearer-cap 3100Hz
voice-port 2/1
voice-port 3/0
cptone DE
timeouts initial 4
timeouts interdigit 2
bearer-cap 3100Hz
station-id name TEL
station-id number 20
caller-id enable
dial-peer voice 30 pots
#my outgoing dial-peer - for the first debug without "port 2/0"
destination-pattern ...T
dial-peer voice 50 pots
#this should be my incoming dialpeer
translation-profile incoming ISDN
incoming called-number 610268T
direct-inward-dial
dial-peer voice 11 pots
#in- and outgoing dialpeer for my analog phone
destination-pattern 20
port 3/0
Without "port 2/0" at the outgoing dial-peer an incoming call is matched correct to the incoming dial-peer 50. But if I add a the ISDN port to the outgoing dial-peer 30. An incoming call is immediately matched to dial-peer 30.
I don't understand why the incoming call is matched first to the "port" command. It should first match the incoming-called number.
Here the debugs "debug voice dialpeer"
debug without port 2/0 at dial-peer 30:
* *Mar 23 13:21:45.929: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=17600064700, Called Number=6102682, Voice-Interface=0x8432461C,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
   Peer Info Type=DIALPEER_INFO_SPEECH
   Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=50
   Calling Number=17600064700, Called Number=6102682, Voice-Interface=0x0,
   Peer Info Type=DIALPEER_INFO_FAX
*Mar 23 13:21:45.933: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Result=NO_MATCH(-1) After All Match Rules Attempt
*Mar 23 13:21:45.933: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=20, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=20
   Result=Success(0) after DP_MATCH_DEST
*Mar 23 13:21:45.933: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=11
*Mar 23 13:21:45.957: //-1/F911BAC48025/DPM/dpMatchPeersCore:
*Mar 23 13:21:45.961: //-1/F911BAC48025/DPM/dpMatchPeersCore:
*Mar 23 13:21:45.961: //-1/F911BAC48025/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=11
debug with port 2/0 at dial-peer 30:
Mar 23 13:22:38.487: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Timeout=FALSE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
*Mar 23 13:22:38.491: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=30
*Mar 23 13:22:44.501: //-1/186615328026/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=6102682T, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=6102682T
*Mar 23 13:22:44.501: //-1/186615328026/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=30
*Mar 23 13:22:44.509: //-1/186615328026/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=6102682, Peer Info Type=DIALPEER_INFO_SPEECH
*Mar 23 13:22:44.509: //-1/186615328026/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=30
- Please rate helpful posts -
Everyone's tags (1)
Hi , only thing that i can think of is ... "T" in your incoming dial peer (50) . my weird guess is router doesn't wait for "T" time to match dial peer when it can match it with dial peer 30 .
in first case ... (no port 2/0) ... only dial peer to which it could match has 'incoming called-number 610268T' where T says it to wait . so it waits and matches it when wait is over.
in 2nd case (with port 2/0) ... it has two dial peers .. one (dial peer 50) says it to wait for "T" time before matching , while other (dial peer 30) doesn't need to wait for  "T" time before matching . so it matches .
Now if I am wrong (which i strongly  feel i am , as i have never heard this crap before) , then it means .. presence of keyword "T" in any dial peer affects the router's dial peer matching time even for other dial peers ... and if we configure matching syntax as ".T" ... doesn't matter whatever number we dial ...router will surely wait for T time before matching dial peer .
so ... I don't know what is right and what is wrong . please guide me also .
Hi aman,
thanks for your reply.
I have replaced the "incoming-called number 610268T" with "610268.." and called 61026820. This is now work with the outgoing dial-peer configured to a port. So you're right.
But now I have the problem that the incoming dial-peer is not waiting for the overlap timer to collect the remaining digits
That's is a debug from a digit-by-digit calling to the number 610268-20
*Mar 23 14:53:12.171: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=600000419, Called Number=6102682, Voice-Interface=0x8432461C,
   Calling Number=600000419, Called Number=6102682, Voice-Interface=0x0,
*Mar 23 14:53:12.880: //-1/BF1FBFBC802A/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=61026820, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=61026820
   Result=Partial Matches(1) after DP_MATCH_DEST
*Mar 23 14:53:12.880: //-1/BF1FBFBC802A/DPM/dpMatchPeersMoreArg:
   Result=MORE_DIGITS_NEEDED(1)
*Mar 23 14:53:18.874: //-1/BF1FBFBC802A/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=61026820T, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=61026820T
*Mar 23 14:53:18.878: //-1/BF1FBFBC802A/DPM/dpMatchPeersCore:
*Mar 23 14:53:18.878: //-1/BF1FBFBC802A/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=30
*Mar 23 14:53:18.882: //-1/BF1FBFBC802A/DPM/dpMatchPeersCore:
*Mar 23 14:53:18.886: //-1/BF1FBFBC802A/DPM/dpMatchPeersCore:
*Mar 23 14:53:18.886: //-1/BF1FBFBC802A/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=30
Hi ,
thanks ,
is following link useful to you ?
http://www.cisco.com/en/US/tech/tk801/tk133/technologies_tech_note09186a00800b48cb.shtml
i think it is related to your problem .
VIP Super Bronze
Re: Problems with incoming dialpeer
You ca resolve this by using preferences on  the dial-peers. So give dial-peer 50 a lower preference  and dial-peer 30 a higher preference. SO dial-peer 30 will have preference 1 and dial-peer 50 can be left at the default of preference 0 . You then need to change the voice gateway dial-peer selection algorithm using the command
dial-peer hunt 2,
the dial-peer hunt available are as follows:
0—Longest match in phone number, explicit preference, random selection.
1—Longest match in phone number, explicit preference, least recent use.
2—Explicit preference, longest match in phone number, random selection.
3—Explicit preference, longest match in phone number, least recent use.
4—Least recent use, longest match in phone number, explicit preference.
5—Least recent use, explicit preference, longest match in phone number.
6—Random selection.
7—Least recent use 0—Longest match in phone number, explicit preference, random selection.
6—Random selection.
7—Least recent use
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Hi aokanlawon,
I tried it as you described it, but it's still the same problem. The call is directly matched to dial-peer 30
new configuration
preference 10
port 2/0
incoming called-number 610268T  ### I tried it with 610268.. and with 610268T
direct-inward-dial
dial-peer voice 51 pots
incoming called-number 6102680
direct-inward-dial
port 3/0
VIP Super Bronze
did you change your dial-peer hunt algorithm to 2?
Yes, I also configured dial-peer hunt 2. Just forgot to write here.
VIP Super Bronze
In this scenario, you need to avoid using overlapping patterns as I think this is the problem you are running into. So on your dial-peer 30 why dont you define a more specific dial-peer rather than ...T Or use should use a prefix to differentiate between your incoming and out bound calls..Eg dial-peer 30 can be destination-pattern 9T
Of course, this would be possible. But my target is to use it without a prefix.
By now I figured out this solution:
dial-peer voice 1000 pots
destination-pattern 6[^10268].T
no digit-strip
port 2/0
dial-peer voice 1001 pots
destination-pattern [0-5,7-9]..T
no digit-strip
port 2/0
I tried this  already a couple of days ago, but with this configuration I had some problems with incoming calls. I will make tomorrow some test and post the debug.
Why dont you just strip digits on the ISDN voice port?
rule 1 /^61026802/ /2/       (this will strip called number to 2. , so you might need to tweak this to include you whole DID                                              block)
voice translation-profile PSTN_Inbound
translate called 1
voice-port 2/0
translation-profile incoming PSTN_Inbound
destination-pattern 0T           (make this pattern whatevcer you want to make outbound PSTN calls, this is an example                                                   that uses 0 for extrenal calls)
progress_ind setup enable 3
incoming called-number .
fax rate disable
direct-inward-dial
port 2/0
port 3/0
Please remember to rate useful posts, by clicking on the stars below.
Hi minkdennis,
If i would do that, the nummber is translated before it arrived complete. Because we are using digit-by-digit calling in Germany, the first ISDN message is 610268 and a little bit later there is a second message with the 0 to complete the number to 61026820. So I need to wait in the dial-peer witht the T pattern for the complete number.
But in this case the the incoming call is matched to my outgoing dial-peer.
I tried it with this to prevent
no digit-strip
port 2/0
no digit-strip
port 2/0
But some calls are still routed to the dial-peer 1001 as incoming dial-peer.
694
