Community Member
Problems with IP Phones Cisco 7921G joint to APs 1231
Hi Friends.
I have a big solutions of IP telephony with Cisco IP Phones 7920 and 7921G, the 7920 are working oerfect, but the 7921G are not???, I configured the 7921G, but the profile appears like INACTIVE??, I tried a lot of times to put the profile enable but it continues INACTIVE??. All of the IP phones are authenticates with Access Points in order to connect with its Call Manager. But 7921G does not work properly Could you help me. So I tried with the default profile with profile 1" and SSID "cisco" and use open authentication, but notihig happend.
Rafael Barba
Community Member
Re: Problems with IP Phones Cisco 7921G joint to APs 1231
Hi Friends.
Rafael Barba
Hi friend,
Inactive means that 7921G is not displaying any signal bar at the top of the screen, so seems like the 7921G is not making contact with de AP?
Can you tell the part number of the phones (7920 and 7921)?
- adrián.
Community Member
Hi Adrian. Thank you for your answer.
Let me tell you that the 7921G firmware is
App Load ID (CP7921G-MFG-A.7.LOADS)
Today I did a firmware upgrade to
App Load ID (CP7921G-1.0.4.LOADS)
With it firmware the Profile 1 i active, but you rigth beacuse I don't have any signal bar at the top of the screen.
(1)Cisco 7921G P/N:74-4956-04 Rev.-B0*
S/N: IAC120200KF
S/N: IAC120201IE
The IP Phone 7920 working perfect
(1) Cisco 7920 P/N: 74-2899-04 rev A0
Please tell me what must I do??
Thank You
Best regards
Rafael Barba
Hi Rafa,
The information that I like to know should be something like this:
CP-7921G-A-K9, CP-7921G-E-K9, etc.
Please find out for 7920/21s.
- adrián.
Hi Rafa,
What I want to know is if your 7921s have this part number:
CP-7921G-W-K9.
The W stands for World domain that uses the 802.11d protocol. May be your 7921 can't connect to your AP because it doesn't have support for 802.11d (by default) so try configuring this command:
#interface Dot11Radio0
world-mode dot11d country US both
- adrián.
Community Member
Hi Adrian.
You are right the part number of the all IP Phones 7921G are (CP-7921G-SW-K9-W Cisco 7921G Software, Rest of World 5).
I will put the command that you sent me into the radio0 and I will inform you the results.
Thank you.
Best regards
Rafael Barba
Community Member
Hi Adrian.
Thank you for your advice, let me tell you that the first IP Phone 7921G, is working perfect now?, I make some test with the others.
Thank you for your help.
Best regards
Rafael Barba
Hi Rafa,
Tell me when you finished tests with the others.
If this helps, please rate.
Best regards,
- Adrián.
Community Member
Hi Adrian.
The Next Monday I wiil the last test with the others, and I will inform you.
Tahnk you so much.
Best regards
Rafael Barba
416
