Problems with LD Calls that have "011" in the middle
Gentleman,
      Everytime a user on our system dials a regular long distance call with 011 in the middle (I.E. 1-212-550-1155) The call drops when the system tries to route it.  We are using CallManager ver 4.1.(3) with a 2811 Voice Gateway.
     The Route Patterns on the Callmanager are as follows:
For standard local and long distance calls -->  9.1[2-9]XX[2-9]XXXXXX
For International calls                              -->  9.011!
     When it hits the voice gateway to be sent off to the PRI we have the following configuration:
dial-peer voice 1002 pots
description dial-peer for Outgoing Calls to Paetec PRI Trunk
translation-profile incoming Inbound_Translation_Profile
translation-profile outgoing Out_Trans_Profile_for_Intl_Call
preference 1
destination-pattern 9T
incoming called-number .
direct-inward-dial
port 0/0/1:23
voice translation-rule 2
rule 1 /011/ // type any international plan any isdn
voice translation-profile Inbound_Translation_Profile
translate called 1
voice translation-profile Out_Trans_Profile_for_Intl_Call
translate called 2
Thanks!
Everyone's tags (2)
1 ACCEPTED SOLUTION
Re: Problems with LD Calls that have "011" in the middle
The problem is your rule, it changes ANY occurrence of 011 to null. You need to configure it to ^011 so it matches 011 only in the beginning of the dial string.
Match String
Replace String
Dialed String
Replaced String
/555/
4441212
44441212
44414441212
5551212
55541212
55514441212
Match the substring
/^1#/
1#456
456
Match 1# at the beginning and replace it with Null.
Number Translation using Voice Translation  Profiles
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a00803f818a.shtml
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Match String
Replace String
Dialed String
Replaced String
/555/
4441212
44441212
44414441212
5551212
55541212
55514441212
Match the substring
/^1#/
1#456
456
java
java
Thank you so much!  This problem was aggrevaiting me for a long time!
It was the perfect fix.
237
