Community Member
Problems with m first IP telephony impl. after Cisco-IP Certification
I am implemanting my first small IP telephony network, and I am having a lot of trouble doing it. The telephone I use are able to contact each other. I receive all my calls to the same phone (I have not yet implemented Voice messages), and I can make local calls to the outside, but I am not able to make long distance calls. I did read a lot on the "Dial-Peers", and Dial-Patterns, and transfer-pattern, and tried a lot of things, but still not able to do long distance calls.
So, if some one could look at my config-file and give me a hint on what is wrong, it would be appreciated.
Thank you.
Gabriel
P.S. Excuse my not too good english
Bronze
Re: Problems with m first IP telephony impl. after Cisco-IP Cert
I think all of your long distance calls are matching dial-peers 15, 17, and 19, and not sending the last digit, since they are a more specific match. Use the "show dialplan number 12125551212#" command to determine which dial-peers are matching and in what order.
Some other helpful show and debug commands:
show call active voice (Once a call is active)
show dial-peer voice summary
debug voice ccapi inout
Placing ONLY a series of the . wildcard in a dial-peer is never a good idea. You need to be more specific. If you're not going to have an access pattern like 9 then try some of these patterns:
1[2-9]..[2-9]...... (For LD)
[2-9]..[2-9]...... (For 10 digit local calls)
[2-9]...... (For 7 digit local calls)
Don't use both the 10 digit and 7 digit examples above together in the same dial plan since they will also not work well together. You need to determine which patterns work best in your area. I'm also making an assumption that your using the NANP.
It would also be a good idea to place preference values on your dial peers so the outbound calls are more predictable. Also, don't forget emergency services number.
Hope this helped.
Community Member
Thank you wery much, caus all of your tips help solve the problem.
I have re-arrange my dial-peer It works fine, but if you could confirm that it's good.
dial-peer voice 5 pots
destination-pattern [2-9]..[2-9]......
port 0/0/0
forward-digits all
dial-peer voice 7 pots
port 0/0/1
forward-digits all
dial-peer voice 9 pots
port 0/0/2
forward-digits all
dial-peer voice 15 pots
destination-pattern 1[2-9]..[2-9]......
port 0/0/0
forward-digits all
dial-peer voice 17 pots
port 0/0/1
forward-digits all
dial-peer voice 19 pots
port 0/0/2
forward-digits all
dial-peer voice 1 pots
preference 1
destination-pattern 911
port 0/0/0
forward-digits all
dial-peer voice 2 pots
preference 2
port 0/0/1
forward-digits all
dial-peer voice 3 pots
preference 3
port 0/0/2
forward-digits all
dial-peer voice 111 pots
destination-pattern 411
port 0/0/1
forward-digits all
dial-peer voice 112 pots
port 0/0/2
forward-digits all
dial-peer voice 113 pots
port 0/0/1
forward-digits all
Thank you again for your time
Bronze
This looks fine. The only other thing you should add are international dial-peers if you expect those types of calls.
Example:
dial-peer voice 1001 pots
destination-pattern 011T
port 0/0/1
prefix 011
The T wildcard is mainly for variable length pattern matching like international calls are. The prefix 011 command will add a 011 back onto the dialed number since pots dial peers will strip any specific leading digits that are not wildcards.
You're welcome. Glad to help.
Hall of Fame Super Gold
I have a tiny nitpick to rchilcote's good advice. When you make the international DP, add some dots (like 6 or 7) after the prefix:
destination-pattern 011......T
This will prevent misdialed calls with short numbers from even hit telco. Not much change, but right to have.
Have fun with your 1st IPT project!
150
