Problems with PC-Port on CP7970
Hi outhere,
We use 109 CP7970 with 8-4-1, since an upgrade to 8-4-4S 106 phone work fine. 106 PCs connected on the phone work fine. Only 3 phones have problems. With "pc voice vlan access" "enabled" the 3 PCs can work. But this is not what we want! Can anyone help here?
Hall of Fame Super Gold
Re: Problems with PC-Port on CP7970
What is that you want? I do not recognize the command you mentioned.
Hi we face problems with pc-vlan settings directly on the phone.
now we are working with a tac to solve the problem
Now cisco find out that this behaivor is a bug!
CSCtr63996
Cisco present a solution for the problem, and they solved it!
420
