Problems with phone communication (SIP & SCCP)
Hi, On my current system I'm running some tests using 2 x 9971 (SIP) + 1 x 7965 on 2921 router. I can make outgoing phonecalls from any phone, I can receive phonecalls on 7965 (from any 9971 phone) but I can't make calls between 2 9971 units and from 7965 to 9971. Any idea why I have this problem?
Hall of Fame Super Gold
Likely something is configured wrong, but we can't tell what, because you have not included you relevant configuration.
Sorry about this. I though someone had this problem and may know the answer straight away. My config:
voice service voip
ip address trusted list
  ipv4 0.0.0.0 0.0.0.0
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
sip
  bind control source-interface GigabitEthernet0/1
  bind media source-interface GigabitEthernet0/2
  registrar server expires max 3600 min 3600
  localhost dns: SIP PROVIDER
  outbound-proxy dns:SIP PROVIDER
  no update-callerid
  sip-profiles 1000
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g728
codec preference 4 g726r16
video codec h264
voice class sip-profiles 1000
request ANY sdp-header Connection-Info remove
response ANY sdp-header Connection-Info remove
voice register global
mode cme
source-address ROUTER IP ADDRESS port 5060
max-dn 5
max-pool 20
load 9971 sip9971.9-1-1SR1
authenticate register
authenticate realm SIP PROVIDER
timezone 21
time-format 24
date-format D/M/Y
tftp-path flash:
create profile sync 0730901611676053
network-locale GB
ntp-server ROUTER IP ADDRESS mode directedbroadcast
camera
video
voice register dn  1
number 100
name FIRSTNAME LASTNAME
label FL - 100
voice register dn  2
number 101
name FIRSTNAME1 LASTNAME1
label F1L1 - 101
voice register pool  1
id mac PHONE MAC ADDRESS
type 9971
number 1 dn 1
voice-class codec 1
username FL password 123456
speed-dial 1 90111111111 label "COMPANY"
camera
video
voice register pool  2
type 9971
number 1 dn 2
voice-class codec 1
username F1L1 password 123456
camera
video
dial-peer voice 1 voip
description *** Incoming call to  - -- Generic -- - SIP Trunk ***
session protocol sipv2
session target sip-server
incoming called-number .T
dtmf-relay rtp-nte
dial-peer voice 1000 voip
description ** Incoming call from SIP trunk (Generic SIP Trunk Provider) **
translation-profile incoming INCOMING
translation-profile outgoing OUTGOING
incoming called-number SIP PROVIDER
voice-class codec 1
dtmf-relay rtp-nte
ip qos dscp cs5 media
ip qos dscp cs4 signaling
no vad
dial-peer voice 1001 voip
description ** star code to SIP trunk (Generic SIP Trunk Provider) **
destination-pattern *..
voice-class codec 1
voice-class sip dtmf-relay force rtp-nte
dtmf-relay rtp-nte
no vad
dial-peer voice 2000 voip
description OUTBOUND
translation-profile incoming SIP_Incoming
destination-pattern 9T
voice-class codec 1
dtmf-relay rtp-nte
no vad
sip-ua
credentials username SIP PROVIDER password 7 SIP PROVIDER realm SIP PROVIDER
authentication username SIP PROVIDER password 7 SIP PROVIDER
no remote-party-id
retry invite 2
retry register 10
timers connect 100
registrar dns:SIP PROVIDER expires 3600
sip-server dns:SIP PROVIDER
host-registrar
gatekeeper
shutdown
telephony-service
no auto-reg-ephone
pin 123456 override
max-ephones 20
max-dn 100
ip source-address ROUTER IP ADDRESS port 2000
system message COMPANY NAME
cnf-file location flash:
load 7945 SCCP45.9-1-1SR1S
load 7965 SCCP45.9-1-1SR1S.loads
load 7970 SCCP41.9-1-1SR1S
load 7971 SCCP70.9-1-1SR1S.loads
time-format 24
date-format dd-mm-yy
max-conferences 8 gain -6
web admin system name USERNAME secret 5 PASSWORD
transfer-system full-consult
directory entry 1 9011111111 name COMPANY
directory entry 2 0111111 name COMPANYNO9
create cnf-files version-stamp 7960 Jan 13 2012 12:38:29
ephone-dn  2  dual-line
number 202 secondary SIP PROVIDER no-reg both
label 202
description FIRSTNAME2 LASTNAME2
name FIRSTNAME2 LASTNAME2
ephone  1
mac-address PHONE MAC ADDRESS
username "F2L2" password 123456
speed-dial 1 90111111# label "COMPANY"
type 7945
button  1:2
pin 123456
If you need anything else please let me know.
I'm guessing this problem is harder then I expected. Anybody?
Take "debug ccsip message" with "term mon" for a failed call.
Output:
INVITE sip:101@ROUTER IP ADDRESS SIP/2.0
Via: SIP/2.0/UDP PHONE IP ADDRESS:5060;branch=z9hG4bK168a26c1
From: "FIRSTNAME LASTNAME" <100>;tag=ecc882b1480f003416165545-6db188e4
To: <101>
Call-ID: ecc882b1-480f000f-07610812-2058f5c3@PHONE IP ADDRESS
Max-Forwards: 70
Date: Tue, 17 Jan 2012 12:25:21 GMT
CSeq: 101 INVITE
User-Agent: Cisco-CP9971/9.1.1
Contact: <100>
Expires: 180
Accept: application/sdp
Allow: ACK,BYE,CANCEL,INVITE,NOTIFY,OPTIONS,REFER,REGISTER,UPDATE,SUBSCRIBE,INFO
Remote-Party-ID: "FIRSTNAME LASTNAME" <100>;party=calling;id-type=subscriber;privacy=off;screen=yes
Supported: replaces,join,sdp-anat,norefersub,extended-refer,X-cisco-callinfo,X-cisco-serviceuri,X-cisco-escapecodes,X-cisco-service-control,X-cisco-srtp-fallback,X-cisco-monrec,X-cisco-config,X-cisco-sis-5.1.0,X-cisco-xsi-8.0.1
Allow-Events: kpml,dialog
Content-Length: 566
Content-Type: application/sdp
Content-Disposition: session;handling=optional
v=0
o=Cisco-SIPUA 4580 0 IN IP4 PHONE IP ADDRESS
s=SIP Call
t=0 0
m=audio 23686 RTP/AVP 0 8 18 102 116 124 101
c=IN IP4 PHONE IP ADDRESS
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:102 L16/16000
a=rtpmap:116 iLBC/8000
a=fmtp:116 mode=20
a=rtpmap:124 ISAC/16000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=sendrecv
m=video 24402 RTP/AVP 97
b=TIAS:1000000
a=rtpmap:97 H264/90000
a=fmtp:97 profile-level-id=42801E;packetization-mode=0;level-asymmetry-allowed=1
a=sendrecv
*Jan 17 12:25:29.672: //274/2D6637CF80D0/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To: <101>
Date: Tue, 17 Jan 2012 12:25:29 GMT
CSeq: 101 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
*Jan 17 12:25:29.680: //276/2D6637CF80D0/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:101@PHONE IP ADDRESS:5060 SIP/2.0
Via: SIP/2.0/UDP ROUTER IP ADDRESS:5060;branch=z9hG4bKEA500
To: <101>
Call-ID: 2D6770B8-403D11E1-80D68BB4-5332D2E3@SIP PROVIDER
Supported: 100rel,timer,resource-priority,replaces
Min-SE:  1800
Cisco-Guid: 0761673679-1077744097-2161150900-1395839715
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1326803129
Contact: <100>
Expires: 180
Max-Forwards: 69
Content-Disposition: session;handling=required
Content-Length: 357
v=0
o=CiscoSystemsSIP-GW-UserAgent 3239 9064 IN IP4 ROUTER IP ADDRESS
s=SIP Call
t=0 0
m=audio 29358 RTP/AVP 0 8 19
c=IN IP4 PUBLIC IP ADDRESS
a=rtpmap:19 CN/8000
m=video 24378 RTP/AVP 119
b=TIAS:1000000
a=rtpmap:119 H264/90000
a=fmtp:119 profile-level-id=42801E;packetization-mode=0
*Jan 17 12:25:29.732: //276/2D6637CF80D0/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Giving a try
Via: SIP/2.0/UDP ROUTER IP ADDRESS:5060;branch=z9hG4bKEA500;rport=61112;received=80.229.165.140
To: <101>
CSeq: 101 INVITE
Server: OpenSIPS (1.6.2-notls (i386/linux))
Content-Length: 0
Received:
SIP/2.0 407 Proxy Authentication Required
Via: SIP/2.0/UDP ROUTER IP ADDRESS:5060;rport=61112;received=80.229.165.140;branch=z9hG4bKEA500
To: <101>;tag=fd79486175647ed1617969929fdaad02.5d24
CSeq: 101 INVITE
Proxy-Authenticate: Digest realm="SIP PROVIDER", nonce="4f1568d70000420297873fc5168fe3b618b379f3e11811af"
Server: OpenSIPS (1.5.3-notls (x86_64/linux))
Content-Length: 0
Sent:
ACK sip:101@PHONE IP ADDRESS:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Sent:
Via: SIP/2.0/UDP ROUTER IP ADDRESS:5060;branch=z9hG4bKEB1EBD
To: <101>
Min-SE:  1800
CSeq: 102 INVITE
Contact: <100>
Expires: 180
Proxy-Authorization: Digest username="SIP USERNAME",realm="SIP PROVIDER",uri="sip:101@PHONE IP ADDRESS:5060",response="a4037cb65d034dc4850363bbb6489201",nonce="4f1568d70000420297873fc5168fe3b618b379f3e11811af",algorithm=md5
Max-Forwards: 69
Content-Length: 357
v=0
s=SIP Call
t=0 0
a=rtpmap:19 CN/8000
b=TIAS:1000000
*Jan 17 12:25:29.792: //276/2D6637CF80D0/SIP/Msg/ccsipDisplayMsg:
Received:
R1003326#SIP/2.0 100 Giving a try
Via: SIP/2.0/UDP ROUTER IP ADDRESS:5060;branch=z9hG4bKEB1EBD;rport=61112;received=80.229.165.140
To: <101>
CSeq: 102 INVITE
Content-Length: 0
R1003326#
*Jan 17 12:25:34.924: //276/2D6637CF80D0/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 408 Request Timeout
Via: SIP/2.0/UDP ROUTER IP ADDRESS:5060;rport=61112;received=80.229.165.140;branch=z9hG4bKEB1EBD
To: <101>;tag=c4734c5d85c7ed191290cd06ad14c355-5855
CSeq: 102 INVITE
Content-Length: 0
*Jan 17 12:25:34.924: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Max-Forwards: 70
CSeq: 102 ACK
Content-Length: 0
*Jan 17 12:25:34.928: //277/2D6637CF80D0/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:101@PHONE 2 IP ADDRESS:5060 SIP/2.0
Via: SIP/2.0/UDP ROUTER IP ADDRESS:5060;branch=z9hG4bKEC185C
To: <101>
Date: Tue, 17 Jan 2012 12:25:34 GMT
Call-ID: 30883974-403D11E1-80D88BB4-5332D2E3@SIP PROVIDER
Min-SE:  1800
CSeq: 101 INVITE
Timestamp: 1326803134
Contact: <100>
Expires: 180
Max-Forwards: 69
Content-Length: 357
v=0
o=CiscoSystemsSIP-GW-UserAgent 9930 5858 IN IP4 ROUTER IP ADDRESS
s=SIP Call
t=0 0
m=audio 19190 RTP/AVP 0 8 19
a=rtpmap:19 CN/8000
m=video 32648 RTP/AVP 119
b=TIAS:1000000
*Jan 17 12:25:34.984: //277/2D6637CF80D0/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP ROUTER IP ADDRESS:5060;branch=z9hG4bKEC185C;rport=61112;received=80.229.165.140
To: <101>
CSeq: 101 INVITE
Content-Length: 0
*Jan 17 12:25:35.056: //277/2D6637CF80D0/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP ROUTER IP ADDRESS:5060;rport=61112;received=80.229.165.140;branch=z9hG4bKEC185C
To: <101>;tag=fd79486175647ed1617969929fdaad02.3d64
CSeq: 101 INVITE
Proxy-Authenticate: Digest realm="SIP PROVIDER", nonce="4f1568dc0000443b8f9419759275ea5498a472dce099c8eb"
Content-Length: 0
*Jan 17 12:25:35.060: //277/2D6637CF80D0/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:101@PHONE 2 IP ADDRESS:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Sent:
Via: SIP/2.0/UDP ROUTER IP ADDRESS:5060;branch=z9hG4bKED1288
To: <101>
Date: Tue, 17 Jan 2012 12:25:35 GMT
Min-SE:  1800
CSeq: 102 INVITE
Timestamp: 1326803135
Contact: <100>
Expires: 180
Proxy-Authorization: Digest username="SIP USERNAME",realm="SIP PROVIDER",uri="sip:101@PHONE 2 IP ADDRESS:5060",response="3e71129eb31c679e16db0b290f54e512",nonce="4f1568dc0000443b8f9419759275ea5498a472dce099c8eb",algorithm=md5
Max-Forwards: 69
Content-Length: 357
v=0
s=SIP Call
t=0 0
a=rtpmap:19 CN/8000
b=TIAS:1000000
*Jan 17 12:25:35.124: //277/2D6637CF80D0/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP ROUTER IP ADDRESS:5060;branch=z9hG4bKED1288;rport=61112;received=80.229.165.140
To: <101>
CSeq: 102 INVITE
Content-Length: 0
*Jan 17 12:25:36.060: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
*Jan 17 12:25:36.064: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
R1003326#
*Jan 17 12:25:40.308: //277/2D6637CF80D0/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP ROUTER IP ADDRESS:5060;rport=61112;received=80.229.165.140;branch=z9hG4bKED1288
To: <101>;tag=c4734c5d85c7ed191290cd06ad14c355-9942
CSeq: 102 INVITE
Content-Length: 0
*Jan 17 12:25:40.312: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Max-Forwards: 70
CSeq: 102 ACK
Content-Length: 0
*Jan 17 12:25:40.312: //274/2D6637CF80D0/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <101>;tag=67BFA0-930
CSeq: 101 INVITE
Reason: Q.850;cause=102
Content-Length: 0
*Jan 17 12:25:40.316: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
R1003326#ACK sip:101@ROUTER IP ADDRESS SIP/2.0
Date: Tue, 17 Jan 2012 12:25:32 GMT
CSeq: 101 ACK
Content-Length: 0
*Jan 17 12:25:42.156: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
OPTIONS sip:SIP USERNAME@ROUTER IP ADDRESS:5060 SIP/2.0
Via: SIP/2.0/UDP SIP TRUNK PROVIDER IP ADDRESS:5060;branch=0
To: sip:SIP USERNAME@SIP PROVIDER
Call-ID: b32b89b2-23251c16-61877@SIP TRUNK PROVIDER IP ADDRESS
CSeq: 1 OPTIONS
Content-Length: 0
*Jan 17 12:25:42.160: //278/34D7C09580D9/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: sip:SIP USERNAME@SIP PROVIDER;tag=67C6D4-1E5B
Date: Tue, 17 Jan 2012 12:25:42 GMT
CSeq: 1 OPTIONS
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Conte
R1003326#nt-Type: application/sdp
Content-Length: 148
v=0
o=CiscoSystemsSIP-GW-UserAgent 3953 4331 IN IP4 ROUTER IP ADDRESS
s=SIP Call
t=0 0
m=audio 0 RTP/AVP 18 0 8 9 4 2 15
Before, you mentioned about failure to call a SIP phones, never mentioned about SIP trunk.
Check that the SIP phone is registered, or include a trace again.
SIP trunk is working fine. I can make phonecalls from any phone and at the moment I have incomming phonecalls to go to SCCP phone and they are working fine as well. Problem is with phoning in to SIP phone.
The trace you posted begins with INVITE from router to phone.
It should begin with INVITE from ITSP to phone.
Please take the trace again correctly.
Hi Paolo,
is this waht you need:
Sent:
REGISTER sip:SIP TRUNK PROVIDER:5060 SIP/2.0
Via: SIP/2.0/UDP ROUTER IP ADDRESS:5060;branch=z9hG4bKC4A52E
To: <103>
Date: Wed, 18 Jan 2012 11:44:11 GMT
Call-ID: FE0B4FED-404D11E1-825C8BB4-5332D2E3
Max-Forwards: 70
Timestamp: 1326887051
CSeq: 854 REGISTER
Contact: <103>
Expires:  3600
Supported: path
Content-Length: 0
Jan 18 11:44:11.902: //4621/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 401 Unauthorized
Via: SIP/2.0/UDP ROUTER IP ADDRESS:5060;rport=61112;received=SIP TRUNK PROVIDER;branch=z9hG4bKC4A52E
To: <103>;tag=fd79486175647ed1617969929fdaad02.706d
CSeq: 854 REGISTER
WWW-Authenticate: Digest realm="SIP TRUNK PROVIDER", nonce="4f16b0b00000a3878d01a78a977ca08aa44be32b112089ea"
Content-Length: 0
Jan 18 11:44:11.906: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
1115
