Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
problems with the cdr on a 2811
I´m having problems sending the cdr records to a ftp server.
The 2821 is running c2800nm-spservicesk9-mz.124-24.T1.bin and cme 7.1.
The symptom are those described in the CSCtb72550 caveat.
The release notes for the last IOS said "Workaround: Downgrade to a version of Cisco IOS software that does not contain the fix for CSCta23301 or push the CDR records locally to flash instead of to an FTP URL".
I would like to know if this issue is resolved (or not)  in the last ios.
Thanks.
2 ACCEPTED SOLUTIONS
Hall of Fame Super Red
Re: problems with the cdr on a 2811
Hi Rafael,
Here are the "Fixed-In" versions
Fixed-In Fixed-in
12.2(52)SE
15.0(1)M
12.4(20)T4
12.4(24.6)PI11p
12.4(24)YG
12.2(32.8.11)XJC273.8
12.4(24.6.5)PIB12
12.2(32.8.11)YST273.3.3
12.4(22)T3
15.1(24.6.8)PIL12
12.4(15)T10
12.2(32.8.11)SX297
12.4(24)MD
12.4(24.6)M0.1
15.1(24.6.3)PIL13
12.4(24)T2
12.2(32.8.1)YCA273.15
12.4(25b)M0.5
12.4(22)YE2
15.1(1)XB
12.4(24)YE
15.1(1.5.1)PIA13
15.1(1.7.1)PIA14
12.2(32.8.15)YCA273.10
12.2(33)SXI4
12.4(24)GC2
12.4(22)MDA4
12.4(24)MDA1
Cheers!
Rob
Hi Rafael,
Try Tools & Resources > Software Downloads
Tools & Resources
Download Software
Step 1Select ProductStep 2Select Software TypeStep 3Select SoftwareStep 4Download
  Routers > Cisco 2811 Integrated Services Router > IOS Software > 12.4.20T4
Release 12.4.20T4                Software  ( ED - Early Deployment )
Cheers!
Rob
Hi Rafael,
Fixed-In Fixed-in
12.2(52)SE
15.0(1)M
12.4(20)T4
12.4(24.6)PI11p
12.4(24)YG
12.4(24.6.5)PIB12
12.4(22)T3
15.1(24.6.8)PIL12
12.4(15)T10
12.2(32.8.11)SX297
12.4(24)MD
12.4(24.6)M0.1
15.1(24.6.3)PIL13
12.4(24)T2
12.4(25b)M0.5
12.4(22)YE2
15.1(1)XB
12.4(24)YE
15.1(1.5.1)PIA13
15.1(1.7.1)PIA14
12.2(33)SXI4
12.4(24)GC2
12.4(22)MDA4
12.4(24)MDA1
Cheers!
Rob
Hi Rob, where can I get one of following:
12.4(20)T4
12.4(22)T3
I do not see those files on the cisco page:
Hi Rafael,
Tools & Resources
Download Software
Cheers!
Rob
finally it works with the c2800nm-spservicesk9-mz.124-24.T3.bin.
but the gw-accounting file comand has a trick!.
1. you must define the ip of the ftp server with the ip host ftpserver xxx.xxx.xxx.xxx command
2. use the primary ftp command with the host defined with the ip host command.
3. for some reason I had to append an "/" to the name defined with the ip host ...  in the primary ftp command.
4. using the ip address instead of the ftp server name do not work.
Example:
ip host ftpserver 10.10.10.10
gw-accounting file
primary ftp ftpserver/ username test password test
609
