Community Member
Problems with VG204
Hi guys,
I am newbie in VG systems and i dont have any docu, i need to congiure 4 faxes with a cme in a VG204, my problem is to find some help to configure this VG and what i need to add in my CME, the ethernet interface its done and works well but i dont know the config for voice-port 0 , 1 , 2 and 3. (The 4 faxes).
Thx in advance and sorry for my bad english.
Green
Problems with VG204
Here is is a useful snip from the cme config guide:-
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeadm/cmebasic.html#wp1248589
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
Problems with VG204
Hi Juan,
Hope this link helps you out:
https://supportforums.cisco.com/thread/2127686
Here is an example of the configuration you will need to do. (This is not layed out in exact order)
On the VG204
Interface VLAN 1
IP Address 10.0.0.1
sccp local VLAN 1
sccp ccm 1.1.1.1 identifier 1 priority 1 <----- The IP Address here would be the IP Address of your CUCME
sccp
sccp ccm group 1
bind interface VLAN 1
associate ccm 1 priority 1
stcapp ccm-group 1
stcapp
ccm-manager config server 1.1.1.1
ccm-manager config
ccm-manager sccp
ccm-manager sccp local VLAN 1
For every FXS port create a dial-peer as seen below:
Dial-peer voip 1 pots
service stcapp <---- This is what puts the FXS port under SCCP control.
port 0/0/0
On the CUCME (Pre-configured)
Configure the VG204 Gateway on CUCME as seen below:
voice-gateway system  1
network-locale FR
type VG224
mac-address 1234.5678.9999
voice-port 0-23
create cnf-files
For the analog phone you can configure auto-registration if you wish to or manually add the phones.
Automatically register ephones:
Under the Telephony-service add the following command
auto assign 1 to 24 type anl
— Use the type keyword  if you have other phone types in the system and you want only  the  analog endpoints to be assigned to ephone-dns automatically.
To add a ephone manually read the following:
The VG202 and VG204 voice gateways use the MAC address of the Skinny   Call Control Protocol (SCCP) local interface to define unique MAC   addresses for each voice port by using the last 9 digits of the SCCP   local interface of the voice gateway.
For example, if the source interface MAC address is 000C.8639.5833,  the  MAC address of the voice port MAC address will be C863.9583.3XXX.  In the  preceding example, the last 9 digits of the SCCP of the local  VG202 or  VG204 voice gateway become the first 9 digits of the voice  port MAC  address after dropping the leading 000.
The last 3 digits of the voice port MAC address is the slot number   (3-bit) + subunit number (2-bit) + port number (7-bit) in hexadecimal   format. You combine the digits to get the last three MAC address digits.
For example, the voice-port 0/0 is slot number 0 (000): subunit 0 (00) and port number 0 (0000000). By stringing the digits together, you get the following: 0000 0000 0000 = 0 0 0. This means that if the source interface MAC address is 001f.cac3.b3f8, the MAC address of voice port 0/0 will be 1FCAC3b3f8000
http://www.cisco.com/en/US/docs/routers/access/vg202_vg204/software/vg2_vg4_voip_ps2250_TSD_Products_Configuration_Guide_Chapter.html#wp1059863
Ephone example:
ephone 1
device-security-mode none
mac-address 1234.5678.9000
button 1:1
ephone 2
mac-address 1234.5678.9001
button 1:1
Kevin
157
