Community Member
Problems with VOIP calls
current set up
site 1
Router connected to PBX by E1
Site 2
router connected to PBX by E1
End to end to IP connectivity has been check and is working
Problem
when trying to make a VOIP call the user gets a dial tone from the router, after dialing the telephone number for a user at site 2 they get an engadged tone.
I have used the "gw-accounting" command to try and trouble shoot the problem but i not to sure of the output (see attachment).
Re: Problems with VOIP calls
You will need to add the following command in your Site 2 router.
Dial-peer voice 99999 pots
direct-inward-dial
incoming called-number .
port 1/0:15
Community Member
To help improve my knowledge
Can you tell me why i would need to add that command?
Community Member
Also this is my current config
Take a look at this document it explains this problem very well..
http://www.cisco.com/en/US/tech/tk652/tk698/technologies_tech_note09186a00800e00d0.shtml#topic2
104
